87mm TB Project
Old Jul 10, 2013 | 03:51 PM
  #141
XChacalX's Avatar
XChacalX
Originally Posted by Fixxxercask
Thanks again for all your help. I totally understand now. I should have no problem getting this working now. Unfortunately, I just put the stock TB and intake back on. I have another race coming up soon and I putting the car on the dyno tomorrow. I need to make sure I'm not over 265whp. My race is in 2 weeks at Mid Ohio. After that race, I will put it back on again and make more adjustments. I have a very good understanding of what to do now too. I have been talking with Jared from Uprev too via email. I am very confident I can get it working 100%. Once that happens, I will buy some PPE longtubes and wait for mw9 to make the custom plenum. When he is done, I want to slap all that on the car and see where we are at.
your welcome I knew something was wrong.
Once you understand how Uprev work , its no black magic.
Old Jul 11, 2013 | 03:26 AM
  #142
Fixxxercask's Avatar
Fixxxercask
Originally Posted by Classy
Jared is super smart, one of the other tuners tuned my 350z after the NA build, I was disappointed by numbers and a bad stalling issue, so I asked for Jared to tune it and he made another 30 hp and 45 tq and the stalling issue was mostly resolved. He really knew his stuff and I really respect him. That being said, he might be the only person working there I respect...
WOW! That is quite a difference. The other guy must have had no idea what he was doing.
Old Jul 11, 2013 | 03:44 PM
  #143
Classy's Avatar
Classy
All I am saying you are in good hands with Jared's Advice
Old Jul 20, 2013 | 07:55 AM
  #144
Fixxxercask
Sorry for no updates. I've been working to get the car ready for the race next weekend. The following week I get back though, I will get back to work on this. I am confident I can get it working now.
I took my car to get put on the dyno the other day too. Engine is dying for sure. It only made 239 first pull. I brought my Uprev with me and messed with some tuning. This particular shop did not have Uprev, but he let me use my laptop and we kind of tuned it together. Ended up getting 248 and about 13 more ft lbs when we were done. Car made 260whp a couple years ago with less mods, so its def dying. Working with that guy at the dyno shop though, I learned a lot about the MAF tuning and some other things. It shouldn't be a problem. I have really high hopes.
Old Jul 20, 2013 | 08:34 AM
  #145
Classy's Avatar
Classy
Poor motor! I think it needs a 11:1 refresh! Not that it has ever made any more power but it will wake up the motor at least
Old Jul 20, 2013 | 09:21 AM
  #146
Fixxxercask
Yea it has about 3 years of road racing on it and 76k miles. Compression slowly gets lower every year. Plans to rebuild this winter which is the whole reason for this thread; to get all the bugs worked out with this so I know it will be good to go when the motor is built. I'm thinking 12:1
Old Jul 20, 2013 | 11:34 AM
  #147
Classy's Avatar
Classy
What fuel do you plan on using for 12:1? What class will you go into after the motor build?
Old Jul 20, 2013 | 01:01 PM
  #148
SurraTT's Avatar
SurraTT
so when you put the tb on are you getting any codes? i wish i had osiris but i dont.
im doing some testing and the car runs insane with the ls 90mm.
Old Jul 21, 2013 | 03:56 AM
  #149
Fixxxercask
I will be using the same fuel I use now. 104 unleaded Sunoco GT Plus.
I did get some codes early on. I posted the code number in this thread somewhere, but it was Throttle Actuator codes. Once I got it working better, I was no longer getting any codes.
Old Jul 22, 2013 | 09:56 AM
  #150
str8dum1's Avatar
str8dum1
can you expand on this?
Old Jul 22, 2013 | 12:21 PM
  #151
SurraTT's Avatar
SurraTT
took it for a test drive and it pulls quite a bit better. going to dyno soon to get actual gains over my 75mm.
Old Jul 22, 2013 | 03:18 PM
  #152
Fixxxercask
Interested to see your gains over the 75. Did you change anything else when you went to the 90mm TB?
Old Jul 22, 2013 | 03:24 PM
  #153
SurraTT's Avatar
SurraTT
no just the 90mm, still running 4" intake pipe.
im planning to have the stock 75mm on, then switch to 90 and tune some all on the dyno. to see the real difference.
Old Jul 23, 2013 | 11:52 AM
  #154
str8dum1's Avatar
str8dum1
so you have it running properly just on uprev? who made the adapter plate?
This is way more interesting than the 75mm tb. more details and pics.
Old Jul 23, 2013 | 12:37 PM
  #155
Fixxxercask
Agreed
The 87mm that I have is practically PNP as far as needing to tune the TB voltages. I never changed anything in the TB table and it worked fine. I just need to work on getting the 4" intake working and larger MAF. Updates on that to come next week.
Old Jul 23, 2013 | 12:45 PM
  #156
Classy's Avatar
Classy
I look forward to that, I am done with VQ's but it doesn't stop me from wishing I had mine to try this on...
Old Jul 23, 2013 | 05:42 PM
  #157
SurraTT's Avatar
SurraTT
Agreed
thats what i dont get. everyone else that tried this tb gets the codes and they dotn just go away. but you are saying you got the code. left battery un hooked for day. and now the tb works good, and you havent adjusted the tb map in Osiris?
no i dont have osiris. 02 maxima ecu is not supported.
i'm using haltech, i made the adapter prototype just for testing. no more info till i dyno test to see if its worth messing with. but my initial test drive
Old Jul 24, 2013 | 01:46 AM
  #158
Fixxxercask
Yea, the car went into limp mode. The big issue I had all along was incorrect wiring. Once that was corrected and I left the battery disconnected over night it fired right up. Now, my car is not really driven on the street. I drove it around the block a few times and came back into the garage and I still did not have a code. It is very possible that if I actually took it out on regular roads and drove it around town I could get one, but I am not sure.
...and no, I did not change anything in the TB table. I think I will end up having to though to smooth some things out. It was a tad bit sluggish at low RPM, but that also could be other things. Not sure. After my race this weekend, I will be getting back to it.
Old Jul 31, 2013 | 03:52 AM
  #159
Fixxxercask
Race went ok this past weekend. Rained out Saturday and finished 1st on Sunday with almost beating the tracker record.
Got the TB and intake all back on the car last night. Gonna spend some time putting the finishing touches on it tonight hopefully and try and take a short video.
Old Jul 31, 2013 | 08:35 AM
  #160
Classy's Avatar
Classy
Not bad for that tired old motor!
