Slip Light...
Old Oct 26, 2013 | 09:34 AM
Nismo Arkansas's Avatar
Nismo Arkansas
Default Slip Light...
So I am new to the forum, have done some searching but wanted a quick response...
I have an '08 NISMO and have recently noticed under high load I have seen the slip light come on and the electronics kick in. This has happend at WOT in like 4th gear so I know the tires were not breaking loose. Does the light come on when the clutch is slipping? I have read the clutch on this car is weak and as a second part, if the clutch is the root cause, what type is a good replacement for the Nismo. Thanks!
Old Oct 26, 2013 | 12:37 PM
JCITY's Avatar
JCITY
What size tires are on your Nismo?
Old Oct 27, 2013 | 07:17 AM
bb17's Avatar
bb17
This happened to me when I had only replaced my rear tires which were worn down. Turns out the diameter of the new tires was too great of a difference from the front and it kept messing up with traction control. TCS mostly kicked in at 4th and 5th gear when doing sweeping curves on the highway at 70 mph. Kind of scary when it kicks in unexpectedly.
Once I replaced the fronts the problem went away.
Old Oct 30, 2013 | 04:59 PM
Tenacious T's Avatar
Tenacious T
What size tires are you running? I'm running 285's in the rear but stock in the front... haven't encountered this issue
Old Oct 30, 2013 | 05:39 PM
dcains's Avatar
dcains
You need to look at overall diameter (or circumference, if you prefer) of the tire, which is a function of both width and aspect ratio.
Old Nov 8, 2013 | 06:45 AM
FlipCpt45's Avatar
FlipCpt45
I just simply don't run TCS when it's dry or when I want to have fun. Leave it on if it's raining.
I'm running 265-35-18F / 275-35-18R
Old Nov 8, 2013 | 07:17 AM
Italianjoe1's Avatar
Italianjoe1
With a 285/30 /19 on the rear and stock 245/40/18 fronts, you will have this issue. When I went to a 285/35/19 on the rear it does not happen, the rears are now slightly larger than OEM.
If you have larger than stock diameter front tires it will exaggerate the condition as well. The system is pretty sensitive to the changes, I had the exact same high-speed sweeping corner issue with the slightly smaller rear tires.
Old Nov 9, 2013 | 06:08 PM
Nismo Arkansas
Tires may be the answer... Thanks! looking at a new set as I type...
Old Nov 15, 2013 | 05:35 PM
Nismo1534's Avatar
Nismo1534
Ah Ha! This always happens to me in 4th. I used to believe the car thought it was losing traction or something like that (due to the increased acceleration from the turbos), like the car was confused why it was accelerating so hard in 4th, but tires makes much more sense, thanks.
Old Dec 29, 2013 | 03:20 PM
Nismo Arkansas
Just to close this one down... Italian Joe was dead on, new tires with the size set-up and no more 4th gear slip!! :0 Thank you sir!
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Paul.
Oct 16, 2015 07:34 PM
NFAC
Sep 26, 2015 10:11 PM
