Nitrous Oxide Too soon, jr.
Nitrous carnage
Old May 3, 2010 | 09:08 AM
cornbread's Avatar
cornbread
Default Nitrous carnage
I have had the chance to rebuild a few blown motors from turbo/sc Z/G's over the last few years. This is the first one that’s blown from nitrous. After getting 35psi in #6 and 80 after the oil trick i knew it had to be broken ring land. Anyway i pulled the motor out and ripped the head off and this is what i found.
This happened while using a 75shot zex kit. The #2 piston also had pieces of the lower ring land broken off but compression was around 10psi. I’m doing a full forged block, and hopefully convince the owner to get a WB AF gauge and something to tune the car with. Ill add more pictures as I go should have in done in just over a week.
Old May 3, 2010 | 09:34 AM
Ruthless18x's Avatar
Ruthless18x
Wow man. Were they using a RPM window switch when that happened?
Old May 3, 2010 | 09:42 AM
cornbread's Avatar
cornbread
From what i could tell its running off a toggle switch.
Old May 3, 2010 | 10:55 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Most ZEX systems operate off of TPS voltage. They have an arm / disarm switch and then fire automatically at a certain voltage.
Old May 3, 2010 | 10:56 AM
ArcticT's Avatar
ArcticT
Could that be from hitting the rev limiter while spraying without a window switch?
Old May 3, 2010 | 02:11 PM
Ruthless18x
I know I had a Zex system. Zex also makes and recommends a rpm window switch.
Old May 4, 2010 | 07:53 AM
wizard's Avatar
wizard
Ouch! Were you running a progressive controller or no? Is it a direct-port or single-port set up?
Old May 4, 2010 | 03:57 PM
izit26's Avatar
izit26
Looks like my old 96 Neon. I was running a 75 shot, dry, with an on/off switch. It got stuck on after a run. LOL. To be 20 again.
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
amg_diananet
Nitrous Oxide
Sep 19, 2003 08:30 PM
cyberz350
Nitrous Oxide
Jun 20, 2003 06:05 PM
EmpiricalGMan
May 26, 2003 06:39 PM
