NorCal Autocross
Old Feb 19, 2011 | 11:11 AM
  #181
christoc's Avatar
christoc
Wet wet wet.... we both gambled wrong and stuck with rcomps. Thank u to grant for helping me put the street tires on for my last run.
Nismo was weighed, will let Grant report results. I will weigh mine tomorrow
Old Feb 19, 2011 | 12:56 PM
  #182
Shamu's Avatar
Shamu
Well day one was interesting? Chris and I made call to run slicks as it stopped raining and course was drying out. However we had major delays which allowed cold rain (40 degrees) to fall just as we started.
I was Zed sledding on my new Hoosiers! Nothing like fresh Hoosiers on cold wet surface. I spun and overshot turns all 3 runs. Chris went to streets his 3 run and took 5 or 6 seconds off his times on slicks!
Just to prove I'm a bit of a nut I drove home on a6s. Oppps it was snowing! Whoo hooo! Actually just light dusting on the road and tires did fine.
Tororrow should be a much better day! I still had fun just can do without the cold and wet.
Grant
Old Feb 19, 2011 | 03:25 PM
  #183
03threefiftyz's Avatar
03threefiftyz
Grant,
What did the nismo weigh in at?
Old Feb 19, 2011 | 04:19 PM
  #184
christoc's Avatar
christoc
Sorry I should have said "Will let Grant report results if he wants to "
Old Feb 19, 2011 | 05:43 PM
  #185
christoc's Avatar
christoc
Write up from today's event w/ Video from 1st and 3rd runs
http://www.project350z.com/Articles/...011-Day-1.aspx
Old Feb 19, 2011 | 06:20 PM
  #186
Shamu's Avatar
Shamu
Grant,
3260 lbs with 15 gallons of fuel and my helmet in the car. Not as bad as I thought it would be. 53% front and 47% rear weight dist.
I need to figure out how to fix the fuel starve issue on 370z so I don't need to have 15 gallons in the tank. I could easily lose 60-70 lbs of fuel weight if I could run a few gallons.
Old Feb 19, 2011 | 06:38 PM
  #187
03threefiftyz
Sucks that the 370's have the fuel starvation problem. I can just about run mine dry without running into a problem. That 90-100lbs of extra weight in gas sucks.
Old Feb 19, 2011 | 07:42 PM
  #188
christoc's Avatar
christoc
I run mine with 0 miles to empty for most events.
Old Feb 19, 2011 | 09:11 PM
  #189
Shamu's Avatar
Shamu
It will be interesting to see what your car weighs. Iknow my wife's 350 roadster weighs more than the 370z. You have definite fuel weight advantage. Also curious about weight distribution.
Old Feb 20, 2011 | 01:05 PM
  #190
03threefiftyz
In for updates! I am guessing you guys are running in the afternoon today since you were early yesterday.
Old Feb 20, 2011 | 04:44 PM
  #191
Shamu's Avatar
Shamu
Nope divisional runs same order both days. We were first ones out on a drying but still damp, cold and muddy course. hard get power down and I had lots of trouble controlling tail out of corners.
I use SS Porsche GT3 guys as my benchmark. Yesterday they slaughtered me by more than 5 seconds today I was within about 3.
Chris and I had our fastest runs on third try. He got me by a few tenths.
I know for me I need to change stock springs, dampers and sway bars. Aside from slight bump in power and and OS Giken LSD my car is pretty much stock. its not terrible but it sits too high and suspension tends to lurch a bit when I make fast transitions. It doesn't smoothly transition, it sort of uloads and loads in a nonlinear way that good dampers and springs will eliminate.
I'm really hoping I get good news on the classing of my 370 Nismo because no way will this car ever be competitive in ASP. If I don't get good news I may just throw a blower on it and go to SSM.
Old Feb 20, 2011 | 08:21 PM
  #192
christoc's Avatar
christoc
I weighed today, 3062lbs.
For a full list of the current configuration check out the blog post http://www.project350z.com/Articles/...ivisional.aspx
Old Feb 21, 2011 | 05:35 AM
  #193
Shamu's Avatar
Shamu
Results posted. Actually my scratch time was better than I thought compared to others. Right in there with a couple GT3's, Cayman S and BSP M3. Still almost dead last with ASP pax. Man SFR indexed class is not for the feeble. There is some driving talent in that class.
Picture of the car on Saturday
Old Feb 21, 2011 | 02:26 PM
  #194
03threefiftyz
Grant....any in car footage from the weekend?
Old Feb 22, 2011 | 06:46 AM
  #195
scotts300's Avatar
scotts300
UFO autox on Sunday. The weather looks chilly, but sunny.
Old Feb 22, 2011 | 07:32 AM
  #196
Shamu's Avatar
Shamu
I'm not very good at following through on that kind of stuff. My co driver in San Diego will likely want to video so I will have something in April.
My "snow cam" did grab this picture Saturday afternoon on the road to my house in the Santa Cruz mountains. Note this was taken only 4 miles from the Pacific ocean in Central California at an elevation of about 1500 feet! Should give you a sense how cold it was Saturday at our event which was about 30 miles from where I snapped this picture.
Old Feb 26, 2011 | 07:33 PM
  #197
christoc's Avatar
christoc
Good luck for those of you hitting the UFO event tomorrow. I'll be at the SCCA Event on 3/6, but am out of town for tomorrow's event.
Old Feb 26, 2011 | 07:39 PM
  #198
03threefiftyz
Finally got around to putting in my cusco RS 1.5way LSD........bloody hell that thing is grabby in the slow turns. I thought I broke something. Quieted down a bit after the fluid got up to temp.
Old Feb 26, 2011 | 10:49 PM
  #199
scotts300's Avatar
scotts300
Thanks! Looks like it'll be a little chilly!
Which fluid? See ya tomorrow.
Old Feb 27, 2011 | 06:46 AM
  #200
03threefiftyz
PA90.
