Shop Builds Temp moving posts for some clean up of this section.
Intense Motorsports: 1013rwhp / 876.32 torque at 29psi 4.2L Stroker 350z
Old Jun 23, 2008 | 12:45 PM
  #101
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by thawk408
+1
This motor would take 8k to the face and not even blink.
yeah, but keep in mind that the engine already had a lil incident, and if it goes its not like intense build it so the level of confidence isnt the same as if they had otherwise.
I think chris heads are stock, maybe cams, but If chris decides not to do it, I will
i like my valve train
Hal: At what rpms do you hit max power with your stroked vq?
Old Jun 25, 2008 | 05:15 AM
  #102
mazzoo's Avatar
mazzoo
The heads are fully built with a Seven angle valve job and more. I have Tomei Cams.
Old Jun 25, 2008 | 06:57 AM
  #103
IIQuickSilverII
oh bad ***!i just remember you did told me that .... pretty bad *** quick...hope you are able to sort things out on the engine.
Old Jun 25, 2008 | 07:49 AM
  #104
Asian Invasian's Avatar
Asian Invasian
holy ****..
Old Jun 25, 2008 | 07:56 AM
  #105
XKR's Avatar
XKR
No doubt this car is way too fast My question is...what gas was used on the 1000hp run and on the 600hp run. Also...whats the most HP on pump gas??
Old Jun 25, 2008 | 08:04 AM
  #106
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Wongy's G35 daily map makes over 700whp on pump gas alone.
Quicksilver: not sure from memory, over 7000rpm
Old Jun 25, 2008 | 08:15 AM
  #107
IIQuickSilverII
thats very nice hal i really like wongys car
fromt he dyno shown in your zig
it doesnt look like over 7000rpms..not sure if there was another dyno posted i missed if so my bad
... the 641 whp run was on pump gas at 10psi which was on spring pressure...
Since traction is already an issue at those numbers i dont know chris decided to have a higher psi run on pump gas. The 1000whp run def was on c16 i am sure
Old Jun 25, 2008 | 08:20 AM
  #108
Dynosty's Avatar
Dynosty
^that dyno is a year old... much has changed including head/cam package and power output now
also keep in mind, the dyno chart you see is not representative of power at those RPM's, due to being on a load bearing dyno and having an unlocked converter for the automatic transmission.
Old Jun 25, 2008 | 08:22 AM
  #109
IIQuickSilverII
yeah i am sure there is somethign newer i missed(i jsut havent see it, pm me with it )
I know you running 4.0L too rather than the 4.2L
Old Jun 25, 2008 | 12:18 PM
  #110
XKR's Avatar
XKR
Same question for Mazzoo's Car..
Old Jun 25, 2008 | 12:25 PM
  #111
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Jorge answered your question.
Old Jun 25, 2008 | 12:26 PM
  #112
mazzoo's Avatar
mazzoo
I really don't know. I am in Houston and was not there during the run. Maybe one of the guys at Intense can give you this information if they read this.
Old Jun 25, 2008 | 12:31 PM
  #113
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Shortly after the 641whp pull, Intense did another pull that made approx 780whp @ 15PSI, IIRC. I'm not sure if that was done with pump gas or C16 though.
Old Jun 25, 2008 | 02:59 PM
  #114
XKR's Avatar
XKR
OK thanks....I thought Jorge was talking about Wongys car
Old Jun 25, 2008 | 03:20 PM
  #115
IIQuickSilverII
yeah sorry, i tried to answer too many questions in a sentence basically
Old Jun 25, 2008 | 04:48 PM
  #116
turismo's Avatar
turismo
How and when are you picking up the car?
Old Jun 26, 2008 | 05:30 PM
  #117
mazzoo's Avatar
mazzoo
Not sure when I will pick up the car. AEBS gave us 4 to 6 weeks for the block work and then Intense has to get everything back together.
My truck and trailer have been in PHX this whole time. So when it's time to bring the car home that’s how it will be done.
Old Jun 27, 2008 | 01:11 AM
  #118
spddmn124's Avatar
spddmn124
holy chit!!!
Old Jun 27, 2008 | 01:53 PM
  #119
mysterymann's Avatar
mysterymann
Nice looking body kit and damn thats a lot of power
Old Jun 28, 2008 | 07:33 PM
  #120
Chef-J's Avatar
Chef-J
Booooosstt!!
