brake boosting a TT 350z.
Old Apr 12, 2007 | 04:37 PM
  #101
KPierson's Avatar
KPierson
Yeah, who needs brake lights one the highway anyway?
Old Apr 12, 2007 | 09:20 PM
  #102
Havok_RLS2's Avatar
Havok_RLS2
Umm... I'd like to keep that feature if possible.
Old Apr 13, 2007 | 07:50 AM
  #103
boostintt's Avatar
boostintt
Originally Posted by Sharif@Forged
Phunk, if you still want to keep your brake lights functional, you might try doing this instead.
If you unplug the VDC harness behind your ABS junction box near your brake resevior, you can brake boost. If you plan to wire up a switch, I would do it here, and just kill power to that module with the switch. This way, you can break boost, and still keep your break lights functional for the street. Your speedo is killed, but who cares.
And damn...break boosting from a roll is really really fun!
is that the grey goin into black harness?
i tried... abs vdc and slip came on but i was not able to brake boost.... is this the right one?
Old Apr 13, 2007 | 07:11 PM
  #104
KPierson's Avatar
KPierson
Well, I brake boosted my TT tonight.
Its too early to tell if there will be any long term problems, but for a short term solution it definately works.
No ABS/VDC/Slip lights. Full functioning ABS/VDC/Slip and full functioning brake lights.
What I need to do is completely disconnect the wire from the ECU and see how long it takes to throw a code. I can then make sure that with the addition of this module that the code isn't thrown. I drove around for about 30 minutes tonight and no lights yet.
Old Apr 13, 2007 | 07:18 PM
  #105
QuadCam's Avatar
QuadCam
so,.............How did it feel to brake boost the G? is it more of a lanching sensation as compared to when you just mash the gas?
Old Apr 13, 2007 | 09:33 PM
  #106
KPierson's Avatar
KPierson
OK, took my car to the 'track' tonight and got to test the brake boost against an '02 Z06 'Vette.
The car is absolutely amazing when brake boosting. When I dropped the pedal my car was like a rocket. I only managed to pull a 1/2 car or so on him, but it was still a good run none the less.
I drove it another 2 hours or so and still no lights. I'll hook my code scanner up tomorrow and see if any abnormalties exist.
Old Apr 13, 2007 | 09:55 PM
  #107
KPierson's Avatar
KPierson
Here is a graph I made.
You can see the RPMs fall (dark blue) as the throttle position increases (light blue). This indicates that the brakes have been applied.
Boost (pink) stays constant the entire time.
Old Apr 13, 2007 | 11:00 PM
  #108
AboostedG's Avatar
AboostedG
Twin Spoolin
That's awesome man, glad you're making progress. That will be tight for those F/I people, if you can get it all worked out.
Old Apr 14, 2007 | 04:09 AM
  #109
MardiGrasMax's Avatar
MardiGrasMax
Do you think this will allow an 5AT NA car to brake torque launch harder since the ECU wont know you are on the brakes and throttle at the same time and close the throttle plate???
Old Apr 14, 2007 | 11:08 AM
  #110
KPierson's Avatar
KPierson
I'm guessing that it would
Old Apr 16, 2007 | 09:15 AM
  #111
KPierson's Avatar
KPierson
I checked for codes yesterday and found none. I've brake boosted it several times and it works great. I think I need a new set of pads.....
Old Apr 16, 2007 | 09:25 AM
  #112
QuadCam's Avatar
QuadCam
so, when does the module go on sale?
Old Apr 16, 2007 | 01:48 PM
  #113
KPierson's Avatar
KPierson
I'm not sure, I guess it depends on what kind of interest there is.
I had to make some significant hardware changes to make a 12vdc output, so I'll need to make some new circuit boards. I can't imagine more then 4-5 people wanting this though, there simply arn't many people who want to brake boost.
Old Apr 16, 2007 | 02:53 PM
  #114
JRoC's Avatar
JRoC
Ive been following this thead since its been started. I will deffiently be one of the first customers
Old Apr 16, 2007 | 03:01 PM
  #115
MardiGrasMax
If it will let the 5AT folks launch like they should, you could sell more their too.
Old Apr 16, 2007 | 04:17 PM
  #116
QuadCam's Avatar
QuadCam
Kevin,
It won't just be for the FI crowd. it'll allow all G/Z owners to be able to do a nice burnout at the track.
Old Apr 16, 2007 | 05:23 PM
  #117
KPierson's Avatar
KPierson
Well, that portion is untested. I'll get with SFLG35 and see if he is willing to test it out. He has a NA 5AT.
Old Apr 23, 2007 | 04:31 PM
  #118
sflg35's Avatar
sflg35
KP Technologies
should hopefully have it in the next week and a half provided that kevin gets it mailed out by the end of the week.
Old Apr 27, 2007 | 07:17 AM
  #119
KPierson's Avatar
KPierson
I've got the test modules ready to send out to Dan. Hopefully he will get them my mid next week and be able to try them out in a timely manner.
Old Apr 27, 2007 | 08:21 AM
  #120
Enron Exec's Avatar
Enron Exec
How do ppl heal-toe but cant brake boost. Just wondering.
