Cluster lights up but gauges not working (video included)
Old 12-10-2017, 04:21 PM
bcoffin23
bcoffin23's Avatar
Default Cluster lights up but gauges not working (video included)
Backstory: Car was sitting for a few years, battery was totally dead when I found it. I have nursed the car back to life, but when I fire her up, none of the gauges on the instrument cluster work. The cluster is illuminated, however.
Any suggestions on where to start? I know next to nothing about wiring and the search function isn't doing me to well for this.
File Type: mov
Old 12-12-2017, 09:40 AM
bcoffin23
bcoffin23's Avatar
anyone?
Old 12-13-2017, 05:22 PM
CK_32
CK_32's Avatar
I know my RPM guage did the same thing on my Z randomly. But it fixed it self.
Have you tried a ECU reset? Checked the fuses?
Old 12-13-2017, 05:55 PM
bealljk
bealljk's Avatar
check your fuse in the interior fuse box ... first one on the bottom I believe ...
Old 12-14-2017, 07:34 AM
i8acobra
i8acobra's Avatar
Received 1,267 Likes on 1,015 Posts
A/C and meter amp. It's in the center stack, under the radio.
Old 12-14-2017, 09:01 AM
bcoffin23
bcoffin23's Avatar
Battery was dead and car sitting for a while. Since then, I have not had the car running for more thank 1-2min at a time. How long did yours take to fix itself?
bcoffin23
bcoffin23's Avatar
Is the fuse to both the lights and the cluster functionality? The cluster completely lights up, just all the dials are dead.
Old 12-14-2017, 09:02 AM
bcoffin23
bcoffin23's Avatar
What should I be looking for there? Practically my whole dash is removed and the A/C has been deleted.
Old 12-14-2017, 09:05 AM
bealljk
bealljk's Avatar
when I had this issue (which I blindly removed that fuse) my dials did not function (speed/rpm/fuel/temp) but it still lit-up and my low-fuel light came on. For as easy as checking that fuse is, do it first - could save you a ton of time!
Old 12-14-2017, 09:33 AM
bcoffin23
bcoffin23's Avatar
Will do! Thank you
Old 12-14-2017, 11:49 AM
i8acobra
i8acobra's Avatar
The white box with the ribbon cable that sits under the radio. It needs to be plugged in. If you removed it, the gauges won't work.
The following 2 users liked this post by i8acobra:
bealljk (12-15-2017), CK_32 (12-14-2017)
Old 12-14-2017, 12:14 PM
bcoffin23
bcoffin23's Avatar
I think that you may have solved my problem. I have a white box sitting in the car not plugged into anything.
Old 12-14-2017, 07:51 PM
CK_32
CK_32's Avatar
One turn off and one turn on. Mine did it while I was at work. Got home turned it off and tried again and it was fine.
Old 12-18-2017, 08:50 AM
bcoffin23
bcoffin23's Avatar
Plugged it in,and presto! All my gauges started functioning. Many thanks!
The following 2 users liked this post by bcoffin23:
i8acobra (12-18-2017), Iam_LAZ (02-16-2023)
justboughtaz
02-12-2021 04:09 AM
nismoracer_206
02-24-2015 06:41 AM
Dr.Paulyy
06-08-2014 05:11 PM
Z33hr6spd
12-09-2009 06:13 PM
damen
01-30-2005 09:20 PM
Quick Reply: Cluster lights up but gauges not working (video included)
