2006 350z cam sensor
Old 06-05-2018, 08:31 AM
jangel350z
jangel350z's Avatar
Default 2006 350z cam sensor
I replace the cam sensors but still have the alarm P0345 BANK 2 and I changed the crankshaft sensor still the same problem ,can I get some help , Thanks
Old 06-05-2018, 08:38 AM
Is your car a stick or auto ? The stick car has 2 sensors on each bank
Old 06-05-2018, 08:40 AM
jangel350z
jangel350z's Avatar
Yes its a stick
Old 06-05-2018, 10:05 AM
khnitz
khnitz's Avatar
Then, since you have a stick, did you replace both cam sensors on each bank?
Old 06-05-2018, 05:11 PM
Spike100
Spike100's Avatar
When I experienced the problem you describe, I had to replace both camshaft sensors and both crankshaft sensors. I started by replacing only one bank (identified by the code), but the fix was replacing all four sensors. My car had close to 90k miles when I did this.
Old 06-06-2018, 07:47 AM
jdmfetish
jdmfetish's Avatar
if you have a factory intake , see if the tube that has the PVC hook up on the tube itself, is cracked .
Old 06-06-2018, 11:16 AM
eZg
eZg's Avatar
maybe use Nissan sensors?!?
Old 06-07-2018, 06:39 AM
WYZIWYG
WYZIWYG's Avatar
Use the OEM Nissan sensors and save yourself the headache. If one is bad, replace all of them plus the crankshaft. Mine went at about 114k[?]
Old 06-07-2018, 11:30 AM
jangel350z
jangel350z's Avatar
Thanks everyone and I did replace with nissan part but the other sensors I will replace with nissan parts and let you know if this solved the problem
Old 09-22-2018, 03:53 PM
onevq35de
onevq35de's Avatar
Did it solve the problem?
I just got a pending code p0345. Hard start on warm engine and power is lagging a little in low rpms.
How many of ya'll that have had this code had to replace all the cam and crank shaft sensors?
aarrgghh
04-20-2018 04:38 PM
rizeld
10-03-2017 04:51 PM
shadowoffair
06-25-2017 11:29 PM
guamboy
10-03-2016 12:06 PM
FairZWell
10-02-2016 06:13 PM
Quick Reply: 2006 350z cam sensor
