UTEC 'Upgrade?'
Old Apr 1, 2008 | 01:33 PM
  #261
mw9's Avatar
mw9
Originally Posted by athenG
I got on their website but you can't do anything. Its just 1 page.
Old Apr 1, 2008 | 03:27 PM
  #262
athenG's Avatar
athenG
/\Select UTI and send your payment and you'll get an email with the ID and password to logon.
I have downloaded the Beta5 but my RPM doesn't work!! I see my A/F, Ignition, Coolant Temp, IAT, Boost but no RPM. It still doesn't' have an option to log everything like the current version were you can hit the Start Log and it will log everything even Idling. Any body used Beta5 yet?
Old Apr 1, 2008 | 04:43 PM
  #263
str8dum1's Avatar
str8dum1
ya my rpm doesnt work either, so much for dashboard.
will look at beta 5
Old Apr 1, 2008 | 05:07 PM
  #264
athenG's Avatar
athenG
will look at beta 5
What version are you using? 2.7 work for me but not the Dashboard.
Old Apr 1, 2008 | 05:22 PM
  #265
MardiGrasMax's Avatar
MardiGrasMax
beta 3.4 works pretty much okay, except the autologging dosent work more than once for me. Beta 3.5 would not connect for me this morning, I'll try later.
Old Apr 3, 2008 | 12:28 PM
  #266
str8dum1's Avatar
str8dum1
ya 2.7.5 with no dashbaord, or any of the new beta versions without RPM
Old Apr 3, 2008 | 01:03 PM
  #267
Jime's Avatar
Jime
I also tried 3.5 today Matt, same results, 3.4 is still working.
Old Apr 3, 2008 | 01:05 PM
  #268
athenG's Avatar
athenG
RPM work too?
Old Apr 3, 2008 | 03:23 PM
  #269
Jime's Avatar
Jime
RPM work too?
Yes
Old Apr 3, 2008 | 04:11 PM
  #270
str8dum1's Avatar
str8dum1
it works in both dashboard and logger? Mine works in logger but not dashboard.
Old Apr 3, 2008 | 05:56 PM
  #271
MardiGrasMax
JIM!!! Glad see your up and running!!!
Old Apr 14, 2008 | 07:27 PM
  #272
jining's Avatar
jining
Anyone get their AEM Eugo to work with the 3.5 beta? Mine just sits @ 9
Old Apr 15, 2008 | 08:46 PM
  #273
jining's Avatar
jining
Got mine to work finally! With 2.75.. weird
Few questions:
Any idea what offset would be desirable for my wideband to match up? Its located right after the downpipe. Options are 0/100/200/300/400/500 milliseconds.
Also any idea what the "WB o2 Placement" means? Options are Normal/Move/Copy... no idea what they mean.
Thanks!
Aaron
Old Apr 23, 2008 | 01:45 AM
  #274
black ghost Alt's Avatar
black ghost Alt
guys on this page, r u reffering to UTI or MPS_UTECLogger ?
and which one is better with no problems and have support ?
I just got my UTEC installed and ready to tune
I want to use one of these nice GUI loggers ? which one to go with ?
Thank you
Old Apr 23, 2008 | 05:42 AM
  #275
athenG's Avatar
athenG
Thank you
WE are talking about UTI. UTI has a lot more extra than MPS and cheaper. MPS don't have Dashboard Mode were you can see your IAT, no Audible, no Auto logging probably more. I havent used MPS in a long time but can't remember if it can compensate for the delay for the A/F. I looked at my old MPS logs and there was also a delay so this i not just a UTI thing.
Old Apr 23, 2008 | 06:22 AM
  #276
JonnyC's Avatar
JonnyC
Yeah, your best bet is UTI, version 2.7.x. The beta version just isn't quite there yet.
Old Apr 23, 2008 | 07:27 AM
  #277
black ghost Alt
the new versions of MPS has a dashboard look here
does the UTI capable of connecting to any O2WB sensors ?
anyone compared both the new versions of UTI vs MPS ?
thank you
Old Apr 23, 2008 | 07:53 AM
  #278
athenG's Avatar
athenG
thank you
What I meant of Dashboard Mode is were you can see IAT and Coolant temp. Same as Dashboard in Utec where you can see your Intake temp and Coolant temp. Believe me UTI has more bells and whistles compare to MPS. With MPS you have to manually log so you'll have one big raw data, with UTI all you have to do is power it on and once it detect you are doing a Pull then it will automatically log it for you, it will also automatically log if it detect knock. It is nice to have a separate file for your knock and makes it easy to find it.
Old Apr 23, 2008 | 08:29 AM
  #279
black ghost Alt
Thank you for the clarification
just last two question:
for the MPS they claim that
"While there may be other LogMappers available to process UTEC logs, only the UTECLogger's integrated LogMapper has the EXCLUSIVE feature in that runs in "real-time" from data gathered from the UTEC as you drive! This allows you to visually see your LogMap being built right before your eye's.
what about the UTI ?
and does the UTI supports the use of O2WB sensors ?
Thank you
Old Apr 23, 2008 | 09:01 AM
  #280
athenG's Avatar
athenG
UTI has all of them and more... the only thing MPS has an advantage over UTI is the Wideband support. I don't think UTI support PLX , Zeitronix and TechEdge. If you have Innovate, Turboxs Tuner and I think even AEM then you should be good with UTI.
Edit: who cares about real time? I can barely look at my gauge when driving..lol This is the reason why we do logging, to eventually look at the data later on.
