UTEC 'Upgrade?'
Old Apr 29, 2008 | 10:25 AM
  #301
black ghost Alt's Avatar
black ghost Alt
interesting..
if you wouldn't trust UTEC at all then go with a full stand alone or the greddy e-manage ultimate.
I'm surprised that there are no such a support for UTEC
these are really great EMS for our cars + evos +wrxs
Old May 12, 2008 | 12:28 PM
  #302
mw9's Avatar
mw9
You guys still having luck with UTI. Just got the utec and tuner installed. Just want to make sure you guys think its worth the $20. Is 2.8 still the latest software for the utec and I did to update my utec will a base map, the guy I bought it off of had a twin turbo setup. I can't seem to find a base map on their website to upload, just intake and exhaust numbers, which I guess you have to type them in by hand, Thanks again for all the help
Old May 12, 2008 | 01:15 PM
  #303
JonnyC's Avatar
JonnyC
Just used UTI yesterday (version 2.7.X) and it's working awesome! I absolutely love it. It's working great with my Innovate LC-1 wideband with the delay set to 100 milliseconds.
As for the maps, they can't be found here - http://www.turboxs.com/utec350zupdate.htm
Old May 12, 2008 | 02:37 PM
  #304
athenG's Avatar
athenG
Can you use Dashboard Mode?
I could not make the Dashboard work for the life of me and when I was getting ready to give up and bought the Tuner, now the Dashboard Mode work for me now connecting via Tuner. Now I can log IAT, Coolant, A/F, Boost, RPM..etc with Ver. 2.75 and I'm happy.
Old May 12, 2008 | 02:54 PM
  #305
merlin3's Avatar
merlin3
not sure if you guys know or not but new version of uti out. I have it installed but haven't tried it yet, trying to finish waxing the car for zdayz first.
Old May 12, 2008 | 05:43 PM
  #306
mw9's Avatar
mw9
Originally Posted by jining
Got mine to work finally! With 2.75.. weird
Few questions:
Any idea what offset would be desirable for my wideband to match up? Its located right after the downpipe. Options are 0/100/200/300/400/500 milliseconds.
Also any idea what the "WB o2 Placement" means? Options are Normal/Move/Copy... no idea what they mean.
Thanks!
Aaron
The guys who are using the tuner, what milliseconds are you having the best luck with. Or how do you determine what one to use?
Old May 12, 2008 | 09:24 PM
  #307
JonnyC's Avatar
JonnyC
Actually, I haven't tried Dashboard mode - just off of Logger-1. Advantage to doing Dashboard? Everything is working great though...including using UTI-ME.
Old May 13, 2008 | 03:31 AM
  #308
Havok_RLS2's Avatar
Havok_RLS2
Ooooo.... Good questions!
Old May 13, 2008 | 05:50 AM
  #309
athenG's Avatar
athenG
With Dashboard mode logger-1 will also contain IAT and Coolant temp if you select them.
Old May 13, 2008 | 06:24 AM
  #310
chopperman's Avatar
chopperman
Are you guys using the UTI, UTI-ME or the Log Analyzer. Or all three?
Old May 13, 2008 | 10:06 AM
  #311
JonnyC's Avatar
JonnyC
^ oo...no wonder I wasn't getting IAT logged I'll have to give that a shot.
^ I'm not using the tuner, and I'm not sure how other people are doing it, but at least with my external wide band, I chose 100 ms, then 300, then 500 and did some logging with each. I simply started logging while cruising, let off hard on the throttle, and then stopped logging. Looking at the logs I looked for when the drop of the injector duty cycle matched up with the leaner AFR. It seems like 200 ms worked for me. Again, I have no clue how the delay stuff works with the Tuner.
Well, you really only need UTI. I'm using UTI-ME to edit my maps outside of the car, and I didn't plan on going with the Log Analyzer (although that would be nice).
Old May 13, 2008 | 09:56 PM
  #312
raditz's Avatar
raditz
Log Analyzer is a great software too!
Old May 14, 2008 | 07:19 AM
  #313
JonnyC's Avatar
JonnyC
athenG - Dashboard mode didn't work. Just sat there doing nothing once connected :-/
Old May 14, 2008 | 07:26 AM
  #314
athenG's Avatar
athenG
lol.. I thought you are one of the lucky ones.... It does work with the Tuner though.
Old May 14, 2008 | 11:34 AM
  #315
merlin3's Avatar
merlin3
has anyone tried the newest version of uti with an aem wideband. It will not read my wideband even though I can connect to it fine on hyperterminal. I'm starting to get pissed because none of the last releases have worked with my wideband so I'm working why I paid for the software.
Old May 14, 2008 | 11:45 AM
  #316
black ghost Alt
guys im using the UTI 2.75 and the logger is working 100% but not the dashboard
can any body help me for this target A/F ? what should it be for a full bolt on car N/A ?
Thanks
File Type: zip
PumpGas.zip (310 Bytes, 18 views)
Old May 14, 2008 | 12:16 PM
  #317
jining's Avatar
jining
Are you using the beta? Mine didnt work with the beta, try 2.75 it worked for me and my uego
Old May 14, 2008 | 04:03 PM
  #318
Jime's Avatar
Jime
The new version UTI-3 v0.9.0 works fine with the exception of no RPM in Dashboard and occasional lockups.
Old May 14, 2008 | 06:04 PM
  #319
athenG's Avatar
athenG
Email jeff coz I told him I get this problem and he said it was the first time he heard it. I too have problem with no RPM with the beta and that kinda defeat the purpose of logging. This is the reason I'm staying with 2.75 right now.
Old May 14, 2008 | 06:06 PM
  #320
Nexx's Avatar
Nexx
Originally Posted by black ghost Alt
interesting..
emanage.
