UTEC 'Upgrade?'
Old Aug 5, 2008 | 04:05 PM
  #361
frankie945's Avatar
frankie945
Look what this program did to my desktop.. I have tried everything to get it back to normal with no luck any ideas? black and white bars all the way down my screen
[IMG][/IMG]
Old Aug 5, 2008 | 06:54 PM
  #362
athenG's Avatar
athenG
Did you copy all the files to the right location and I assume you did register them just like the install files says right? This is weird but the first time I had some error on the installation so I tried to download it again and decompress it and it finally worked... Try downloading it to a different PC and decompress it somewhere... I know it doesnt make any sense but that worked for me.. also try to login with a different user and see if it work, maybe your user profile is corrupt so it is giving you different problems...
Old Aug 5, 2008 | 07:42 PM
  #363
chopperman's Avatar
chopperman
Do they have somthing like this for the F con?
Old Aug 6, 2008 | 06:50 AM
  #364
athenG's Avatar
athenG
Fcon is locked so you cant do any LOGGING through your own or make any changes...
Old Aug 6, 2008 | 07:44 AM
  #365
frankie945's Avatar
frankie945
the same error keeps coming up everytime i try to connect it says continue or quit. I have reformated my notebook and reinstaled uti and still the same sometimes it connects but mostly get that error and when it does connect everything works on the dashboard and logger 1 but it glitches and frezzes sometimes. I am using windows XP.
Old Aug 6, 2008 | 08:43 AM
  #366
athenG's Avatar
athenG
What version are we talking about?
Old Aug 6, 2008 | 09:24 AM
  #367
frankie945's Avatar
frankie945
the newest ver. I couldn't get 2.7.5 to work thats when it mess up my notebook
Old Aug 6, 2008 | 09:53 AM
  #368
athenG's Avatar
athenG
Did you follow the direction carefully to the dot and register the ocx and dll file after copying it to the system32 folder? since you have formated your Laptop arleady I would try it again since you have a clean Laptop now. Trust me you will love UTI if you can make it work.
Old Aug 6, 2008 | 10:01 AM
  #369
frankie945's Avatar
frankie945
Never registered it I'll give it another try. Did you get the uti me to work I tried it no luck the screen go's blank for a sec and nothing happens when I try to open logs.
Old Aug 6, 2008 | 11:49 AM
  #370
athenG's Avatar
athenG
That is why... There is a txt file that come with the 2.7.5 for installation procedure for every OCX and DLL files. You cant just unzip the file and start running the program. Like I said, installation procedure is pretty much a manual process since you have to copy them to the right folder and you have to register the dll's. I have never used the UTI-ME since I usually look at the raw logs when making adjustment. I just use the UTI because of the audible and the auto logging feature (especially the knock count logs). It is also easier to do a spot checking with the matrix table for the A/F, Boost, Timing, IDC..etc... but when I need to make adjustment I still like looking at the raw logs.
Old Aug 6, 2008 | 01:20 PM
  #371
chopperman's Avatar
chopperman
Is there a way that I can get it to display on a 7" screen? I would like to view a/f, egt etc.. on a screen.
Old Aug 6, 2008 | 02:03 PM
  #372
KPierson's Avatar
KPierson
Since 99.9% of the people in the thread are running UTECs this probably isn't the best place to ask this question - you should start a new thread.
Old Aug 29, 2008 | 10:35 AM
  #373
QuadCam's Avatar
QuadCam
UPDATE:
We should be seeing a fix to the UTI3 within a few days.
Old Aug 29, 2008 | 10:42 AM
  #374
Jime's Avatar
Jime
According to Jeff its tomorrow.
Old Aug 30, 2008 | 07:27 AM
  #375
QuadCam's Avatar
QuadCam
originally, but there are still some nagging issues for the VQ35 application when using "dashboard" mode.
Old Aug 30, 2008 | 11:44 AM
  #376
QuadCam's Avatar
QuadCam
Looks like everything is good now. I have been testing the newest UTI for jeffsoftware.com and looks like he has everything worked out. With any luck, the new software will be available for download shortly.
Old Aug 30, 2008 | 07:50 PM
  #377
QuadCam's Avatar
QuadCam
the new software for UTI3 is up and available for download at www.jeffsoftware.com
Old Sep 1, 2008 | 08:29 AM
  #378
frankie945's Avatar
frankie945
Good day to do some logging I will download this ver. And give it another try thanks for the heads up QuadCam
Old Sep 1, 2008 | 11:35 AM
  #379
merlin3's Avatar
merlin3
still worthless as usual, would be nice if he'd fix it to work with the aem wideband like it's supposed to.
Old Sep 1, 2008 | 12:30 PM
  #380
QuadCam's Avatar
QuadCam
mine works perfectly.......sorry ot hear about your AEM. Have you tried reporting the bug?
