car wont start HELP!!
Old Aug 12, 2011 | 12:14 PM
silvertouringz's Avatar
silvertouringz
Default car wont start HELP!!
I was using my cobb accesport, and when i tried to upload a map and i got an error. now I can't get the car to start, and attempts to reflash/uninstall are unsuccessful..It cranks, but doesn't turn over. The radiator fan spins though, same like it does during flashing. No codes present. I had my car towed..please help! It's my DD, and I am in a very harsh situation..
Old Aug 12, 2011 | 01:03 PM
bmccann101's Avatar
bmccann101
Have you called cobb yet?
Old Aug 12, 2011 | 01:17 PM
silvertouringz
im overseas, emailed them...very very f-ed up situation
Old Aug 12, 2011 | 01:38 PM
str8dum1's Avatar
str8dum1
have you tried unpluggin the battery for a lil bit?
also check your ecu fuse behind the battery box. the fans will run but car wont start if that fuse is blown.
Old Aug 13, 2011 | 03:55 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The fans natively default on, and the ecu tells them to turn off. If they are constantly on with the key on, then the ecu is not telling them to turn off. This could be due to the ecu not having a map at all, ecu not getting power (blown fuse or unplugged ecu harness), or ecu failure.
If the map upload failed, it is most likely that the ecu does not have a valid map installed now. Your fix will be specific to Cobb, so it would be best that you call/email them. FYI, I believe they do not "support" the 350Z application anymore. Best of luck. Please post up if they give you a fix to this problem so others will know.
Old Aug 13, 2011 | 05:14 AM
djamps's Avatar
djamps
This happened once with my Upev, and disconnecting the battery for 30 minutes took care of it. Not sure if it will work with Cobb but maybe worth a shot.
Old Aug 13, 2011 | 06:29 AM
Bmurray350z's Avatar
Bmurray350z
Any luck OP? or did you die
Old Dec 10, 2012 | 09:54 PM
fairladyz13's Avatar
fairladyz13
i know this is an old thread but does anyone know how to fix this issue? i tried putting the stock map back on my ecu and now my car wont start either and i need someone to tell me what to do.
Old Dec 10, 2012 | 10:36 PM
fairladyz13
also my fans are running as mentioned, i think it currently has no map but i am stuck and dont know what to do at this point because i cant ship this to my buyer until it is resolved
Old Dec 17, 2012 | 08:43 AM
AndrewMHo's Avatar
AndrewMHo
Disconnect the battery and wait a little and reconnect.
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
