FP Exclusive 1st: The VQ35HR Dissected
Old May 4, 2007 | 08:26 PM
  #181
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
hmm....what to take apart next....
It takes a special kind of customer, to allow us to totally dismantle his 250mile brand new VQ35HR engine...thanks Jeremy!
Old May 4, 2007 | 08:29 PM
  #182
Gumpdriver's Avatar
Gumpdriver
LOL now lets just put it back together in one piece.
Old May 4, 2007 | 08:39 PM
  #183
lowrider's Avatar
lowrider
Subscribing Great Stuff!!!
Old May 4, 2007 | 11:48 PM
  #184
Skorch's Avatar
Skorch
Very cool thread! I hope there will be a couple turbo kits available by the end of the year.
Old May 5, 2007 | 05:08 AM
  #185
Rogue350z's Avatar
Rogue350z
!!HR TT!!
750 miles, 150 on the dyno. No big deal, doing what I can to help the community.
Car is at the body shop for a couple of months so we got time to play.
J
Old May 5, 2007 | 05:44 AM
  #186
Gumpdriver's Avatar
Gumpdriver
J
J, you gotta keep use up dated on all of the cars changes. Only seen a couple of pics. of the WB I know you have more.
Old May 5, 2007 | 05:48 AM
  #187
tomiegunzz's Avatar
tomiegunzz
Wow.
Old May 5, 2007 | 07:03 AM
  #188
Rogue350z's Avatar
Rogue350z
!!HR TT!!
De, I am not sharing.
Don't want to spoil the surprise.
J
Old May 5, 2007 | 12:14 PM
  #189
KhanMan's Avatar
KhanMan
thank you J and thank you Sharif!
Old May 5, 2007 | 02:29 PM
  #190
Mansmind's Avatar
Mansmind
I took a look at this block today. It appears to be MUCH stronger at the bottom, as you can kind of see in the pics.
Old May 5, 2007 | 06:22 PM
  #191
kel's Avatar
kel
this engine is setup just like the vk45de everything from cam sensors, cooling, even the fuel rails the only difference is that after the fuel travels across the other side it has a return line
Old May 5, 2007 | 07:26 PM
  #192
g356gear's Avatar
g356gear
Sharif....2 questions...
1) Is the fuel system the same with no return line to the tank?
2) How do the rods and pistons look....thicker rods and ringlands?
Old May 5, 2007 | 08:59 PM
  #193
Sharif@Forged
Forged Performance
Still a returnless fuel system, but the rail is fed from the front.....but still the good'ol returnless system
Causual inspection of the rods (we havent disassembled the rotating assembly...yet) indicates they look very similar to last year's rods. We can only hope they are stronger. The piston tops and sides are not visible for now.
But holy mother.....the block and integrated mains/girdle are MUCH stronger and more ridge. It makes the VQ35DE look like its missing some parts or something.
Old May 5, 2007 | 09:02 PM
  #194
Sharif@Forged
Forged Performance
Originally Posted by 6894kevin
In your break down did you notice any upgrades or fixes for the clutch and master cylinder on the 07. I have read like 5 different peoples issues with the clutch. And some of them have had to get them replaced already. Some are saying a bad batch of fluid others are saying design issues. I just was wondering what is your take on the situation and if you had any insight on major problems and/or upgrades and fixes to the situation.
Cheers
Kevin
The external slave cylinder is gone, as is the entire clutch fork..yippie. I think our clutch pedal engagement issues are over and done with.
Internal slave cylinder, with direct actuation of the TO bearing...very nice!
Old May 6, 2007 | 02:04 AM
  #195
andypandy's Avatar
andypandy
damn... with that in mind, perhaps sleeving the block would be unnecessary for mid to high forced induction power levels.
good looking out, sharif.
Old May 6, 2007 | 09:33 AM
  #196
Sharif@Forged
Forged Performance
That is exactly what I was thinking.
Old May 6, 2007 | 12:13 PM
  #197
gambino's Avatar
gambino
Forgive me for not reading the entire thread, but I have one question after reading the first post. You said he made 265whp and that was a 17hp gain? I am just slightly confused because my stock 07 was dynoed on friday and made 266.9whp on what most have said is a very tough dyno to make good numbers on.
Old May 6, 2007 | 12:16 PM
  #198
Sharif@Forged
Forged Performance
We use a DynoDynamics dyno, and we not use any additional Dynojet corrections, to pump up the number. 06's baseline at about 215whp on our dyno, since it reads very low.
Unfortunately, dyno comparisons are fraught with error, so we dont even try it. We did the before dyno, and the after dyno...and that is the gain we posted.
Old May 6, 2007 | 12:27 PM
  #199
gambino's Avatar
gambino
cool, gotcha. I figured that was the case, just thought I would check. Plus, this was my first dyno on any of my cars ever, so part of me just wanted a chance to bring that up
Old May 7, 2007 | 07:17 AM
  #200
Sharif@Forged
Forged Performance
No problem at all...our dyno is affectionate termed the "heat-breaker:.
