FP Exclusive 1st: The VQ35HR Dissected
Old May 7, 2007 | 08:10 AM
  #201
bboypuertoroc's Avatar
bboypuertoroc
Heat-breaker? LOL
Good finds so far... just waiting on eval of the rods/pistons/etc.
Old May 7, 2007 | 02:18 PM
  #202
amgtortoise's Avatar
amgtortoise
Does the new VQ35HR have a rod lenght of 151.6mm vs 144mm VQ35DE? The longer rod lenght allows the engine to go to 7500rpm reaching a piston speed of 20.35m/s, a new performance standard on the 3.5L.
Old May 7, 2007 | 03:01 PM
  #203
6894kevin's Avatar
6894kevin
Originally Posted by Sharif@Forged
The external slave cylinder is gone, as is the entire clutch fork..yippie. I think our clutch pedal engagement issues are over and done with.
Internal slave cylinder, with direct actuation of the TO bearing...very nice!
Ok I am not a wealth of knowledge when it comes to trans and especially clutches and all the mechanics. But I think I follow what you did. A few questions though, did it take a product that was already available or did you make this set up. Sorry if this is a dumb question, but ya never know till ya ask. Also who and where did you get this set up from. I just want to be prepared if the clutch problem strikes me.
Also personal opinion on the stock set up and why it is giving problems is welcomed to??
Cheers
Kevin
Old May 7, 2007 | 03:16 PM
  #204
Mansmind's Avatar
Mansmind
Kevin, FWIW they're claiming the clutch problem was an air pocket in the hydraulic system. While that seems a little over-simplified, I can't really argue with them.. that's sort of what it acted like when I had the issue.
If I understood the above post, I don't think Sharif actually did anything to the clutch, this is the new design on the 07s.
John
Old May 7, 2007 | 05:01 PM
  #205
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Correct...I was just describing the revised clutch mechanism on the 07's. But now i hear people are having issues with the 07's as well. I have this funny feeling...that the majority of the issue is just air in the system, that was never removed when the cars were put together.
Old May 7, 2007 | 05:42 PM
  #206
bboypuertoroc
In other words... bleeding it out might be able to cure the problem.
Old May 7, 2007 | 08:31 PM
  #207
andypandy's Avatar
andypandy
hmm.. looks awfully similar... retrofit anyone?
Old May 7, 2007 | 11:35 PM
  #208
Miche350Z's Avatar
Miche350Z
so what parts can we use for the de?
Old May 8, 2007 | 01:41 PM
  #209
nismology1's Avatar
nismology1
Don't quite see how rod length has any effect on piston speed. If the stroke is the same, it has to travel the same distance in the same amount of time. The points at which peak piston acceleration occurs is all that changes; average piston speed does not. The primary advantage to having a longer rod is that it reduces the rod angle, which reduces thrust loads on the cylinder walls. This lowers friction and promotes smoother and quieter engine operation.
Old May 8, 2007 | 02:31 PM
  #210
gabez33's Avatar
gabez33
+1111111
Old May 9, 2007 | 06:38 PM
  #211
Sharif@Forged
Forged Performance
Unfortunately, not a whole lot. The cost involved in doing a transplant would be cost prohibitive. Would be better off just building up your DE.
Old May 10, 2007 | 12:26 AM
  #212
KhanMan's Avatar
KhanMan
So then what are the parts that we could use on our car with out it being super costly.
Old May 10, 2007 | 12:29 AM
  #213
andypandy's Avatar
andypandy
sharif, can you post a picture of the lower plenum collector? i may have a hunch that the lower connector can be used onto the de. if not, perhaps a small spacer that can connect the de heads and the hr LPC would work.
Old May 10, 2007 | 07:53 PM
  #214
warmmilk's Avatar
warmmilk
any chance of those collector pics now?
Old May 12, 2007 | 09:04 AM
  #215
xDIEGOx's Avatar
xDIEGOx
Any updates?
Old May 12, 2007 | 11:54 AM
  #216
toca07's Avatar
toca07
does the 06 and back lsd work in the 07
Old May 12, 2007 | 03:12 PM
  #217
Sharif@Forged
Forged Performance
The collector is off getting mocked up for a fuel system...no pics for now.
Old May 12, 2007 | 05:02 PM
  #218
the7ferret's Avatar
the7ferret
Oie! Im back! haha
I have been missing for a while here... School and work are a pain!
First off good work forged... Keep em comming...
Now this proably has already been addressed but is this the engine in the GTR? From the looks of it since it seems to be reinforced for boost thats my assumption...
Old May 13, 2007 | 07:16 AM
  #219
Sharif@Forged
Forged Performance
Originally Posted by the7ferret
Oie! Im back! haha
The fundamentals should be close, but the GT-R engine will be a different displacement, lower compression, completely different intake, and reinforced even more....probably have variable valve lift as well, and bunch of other goodies.
Old May 13, 2007 | 07:19 AM
  #220
myG35zx's Avatar
myG35zx
Wouldn't the 2008 coupe's 3.7 be the GTR's in NA form?
