The wait is over.....Stillen Header Dyno results!!!
Old Sep 4, 2008 | 04:33 PM
  #101
A.H's Avatar
A.H
I hear the exact same thing with my headers but its not an exhaust leak so don't worry about that. Most noticable when you start the car up and its at idle. Sounds badass imo
Old Sep 4, 2008 | 05:05 PM
  #102
KS0385's Avatar
KS0385
Is it just me or do those look kinda poorly designed? Almost worse than the stock manifold.
There is more of an angle in pipes "1" and "2" than in the stock ones. And why would they not just make them as straight as possible and have then go into the holes as I show for each pipe? Do they have to be the same length for efficiency? Or does the air have to pass through the pipes into the the exhaust pipe at the same time? (I really doubt it) I know that twists and turns in fluids cuts efficiency.
(Here's my proposed design)
If I am wrong or missing something let me know.
Old Sep 4, 2008 | 05:17 PM
  #103
bboypuertoroc's Avatar
bboypuertoroc
There's this thing called equal length...
Old Sep 5, 2008 | 04:58 AM
  #104
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
....and it tells you absolutely nothing. Equal length has it's benefits and its detractions. That is why there is also a thing called unequal length There are alot of considerations to make when designing headers and manufacturing headers - it's quite involved actually and relative to many other aspects of the engine.
KS0385 - you are right to a point, but remember, we have somewhat limited space to contend with as well. So often times, one has to engineer less than ideal bends in order to clear prexisting conditions.
Old Sep 5, 2008 | 05:04 AM
  #105
plumpzz's Avatar
plumpzz
Originally Posted by Z1 Performance
correct - been that way for years and years now - we only work on stuff we own in house
and damn my spelling errors!!! We NEED the edit buttons back!
I have an edit button..
Look i just edited.
Old Sep 5, 2008 | 09:47 AM
  #106
infinite's Avatar
infinite
Finally we're able to edit our post again. The bends are probably for clearance issues
Old Sep 12, 2008 | 08:31 AM
  #107
YOGURT!'s Avatar
YOGURT!
great numbers.. that car is impressive with the mods you have.. wish i had the HR
Old Feb 23, 2009 | 08:57 PM
  #108
2007 Z's Avatar
2007 Z
Right you are. But in this case I would say that equal length is more beneficial than not. The numbers are clearly better. I believe the bends were done purposely to create equal length.
Old Mar 9, 2009 | 04:04 PM
  #109
tomtom's Avatar
tomtom
is that STILLEN headers on the top and look shorter than the stock?
Old Sep 17, 2010 | 12:02 PM
  #110
srsairbags's Avatar
srsairbags
Question
do we have stock vs Stillen header internal diameter specs to compare ? ? ?
Old Sep 17, 2010 | 01:02 PM
  #111
Lakeside's Avatar
Lakeside
My stock headers are in the garage. Those I could measure. But I never did measure the Stillen's! Its a very visible differance I can tell you that.
Old Sep 17, 2010 | 03:13 PM
  #112
srsairbags's Avatar
srsairbags
Question
im assuming them to be larger by a few mms (2-5 mm) . . like a gradual increase . . . or is it like the inlet port itself is larger than the stock ?
Old Sep 17, 2010 | 04:44 PM
  #113
Lakeside's Avatar
Lakeside
Ports & tubes are larger.
Old Sep 17, 2010 | 06:05 PM
  #114
srsairbags's Avatar
srsairbags
Question
ok . . this maybe a noob question, . . . if the ports are larger then wont it make the stock cats and some hfcs unusable ?
Old Sep 17, 2010 | 06:26 PM
  #115
T_K's Avatar
T_K
Flanges and bolt holes still match up.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
