Highest mileage HRs
Old Mar 1, 2009 | 04:08 PM
  #141
Smackin's Avatar
Smackin
07 7400 miles
2nd gear grinded till about 4k, but has been fine since then. Car is driving great. It started puttering yesterday but that could just be bad gas.
Mods: HFC/CAI/NISMO exhaust
Old Mar 1, 2009 | 06:37 PM
  #142
juve_350z's Avatar
juve_350z
had an 03 with 93k miles on it traded for an 08 had the 08 for 2 months and already have 5k on it i got it with 13 miles.. i had no problems with my 03 in 3 years i had it now with my 08 i got my first problem my a/c doesnt work it does not get cold and i alredy checked if i had a leak or something and i didnt so tomorrow probably going to take it to the dealership.
Old Mar 2, 2009 | 06:48 AM
  #143
Stogge's Avatar
Stogge
Hello,
I have 20k on my 2007... So far...
- Slave Cylinder Replaced- 19k
- Loud clunking noise listened to by the dealership, and the said it was completely normal... They said they just have loud clunky clutches? Anyone else heard this?
Old Mar 2, 2009 | 11:11 AM
  #144
Da Monsta's Avatar
Da Monsta
Originally Posted by Stogge
Hello,
Yep, completely normal
Old Mar 4, 2009 | 06:15 PM
  #145
Candymaker's Avatar
Candymaker
21900ish miles
Rattle in dash
Airbag sensor
Slight flywheel chatter
Grinds occasionally in 3rd and 5th when cold
Paint chips ftl
Summer tires were "cupping"
2 recent more annoying issues:
Just as I let off the clutch into gear there's a popping sound from the pedal area.
Vibration in front right corner at 40+mph. Need to get this checked out by the dealer at next oil change
Are any of these discouraging me from loving and driving my car? No way!!!
I think the mod bug bit me - as soon as the vibration is gone I'll scratch that itch
Old Mar 15, 2009 | 03:26 PM
  #146
pistols07Z's Avatar
pistols07Z
2007 with 33k miles. Not one problem. (knock on wood)
I do want to complain about the window switch panel on the driver side door, the finish it peeling off and chipping. Also the finish on the radio **** is worn... Pisses me off!
Old Mar 17, 2009 | 07:40 PM
  #147
JK_HRZ's Avatar
JK_HRZ
08 HR
19k miles - 2nd slave cylinder replaced. >.> piece of ****.
5th grinds
Old Apr 3, 2009 | 03:52 PM
  #148
blaster9's Avatar
blaster9
07 w/ 17K...got it used with 13k so i have no idea if the slave cylinder has been replaced. Do you guys know a way of finding out? What are the symptoms of it needing to be replaced?
Driver window has had about 3 hiccups not wanting to go up.
Tach stuck one time for about 10 minutes.
Some wierd vibrating sound around 1900 rpms cant figure out what it is or where its coming from
Old Apr 5, 2009 | 07:58 AM
  #149
SuPERSak's Avatar
SuPERSak
07 350z....
--35K ish
--Slave cylinder replace...... (@15K)
--Wierd noise coming from front wheels when going up a bump..... (Strut bar was loose)
--Clutch makes poppng noise....... (GAY)
--Loud chatter when in nutruel....... (Listen by the dealership and called in to Tech support and took it up to reginal and they all claim it's normal but the sound is soo loud that it makes the Z look bad.. But I can't do nothing)
--Driver window goes up but likes to come back down when hot outside......(I think it's hitting the blk plastic the wrong way when it's hot ?? WEIRD)
--Airbag sensor (Only when a passenger sit the airbag turns off) <-- I have to get it fix by stealership
Old Apr 5, 2009 | 08:17 AM
  #150
KS0385's Avatar
KS0385
2008 Base, About to hit 12,000.
-Rattles in doors and trunk with the music and Bass up.
-Factory exhaust was too quiet. Had to replace at 6500.
-Hit a huge pothole at 60mph on Christmas. Bent rim. No cracks. Got it repaired. Tire was fine.
Old Apr 5, 2009 | 08:29 AM
  #151
candyandy's Avatar
candyandy
my 08 had 5700 miles before my wheel bearing started to tear off.
Old Apr 19, 2009 | 04:46 PM
  #152
snoody's Avatar
snoody
i have a 07 with 36,200 miles
my driver door makes a sound when i open it
clutch makes a cliking sound
cel is on from test pipes
airbag senser
cliking from clutch pedel
axils makes a cliking sound also when in revers
front bumper was phukd from the bugs
Old Apr 19, 2009 | 05:58 PM
  #153
jace350z's Avatar
jace350z
Got my 07 6mt in Aug. of 07 13,5xx miles. No real problems. The metal piece on the shifter **** fell off. True dual exhaust and intake and coilovers that rattle.
Old Apr 19, 2009 | 07:11 PM
  #154
Peak350's Avatar
Peak350
07 with 23k miles.
In the last 2k I've lost a wheel bearing and the slave cylinder again.
I'm starting to get annoyed with the minor issues the car exhibits. Every time I drive it I get over it, but its still annoying when its sitting broken.
Old Apr 19, 2009 | 08:56 PM
  #155
Three Fifty Z's Avatar
Three Fifty Z
07 Enthusiast - 27k miles.
Slave cylinder recall.
My seat squeaks when I turn.
Overall, I'm very pleased with the car, I'm literally in love with it.
Old Apr 19, 2009 | 10:01 PM
  #156
kyx4n's Avatar
kyx4n
07 Base
13k Miles
no problems.. i think.. Airbag light is the only thing
but considering i used to drive a shitty Focus with so much noise and rattling, there might be some problems just that i don't notice it
btw
Originally Posted by blaster9
07 i have no idea if the slave cylinder has been replaced. Do you guys know a way of finding out? What are the symptoms of it needing to be replaced?
Call the dealer and give them your VIN or whatever and they should be able to see if the car has done the recall...
Old Apr 20, 2009 | 09:42 AM
  #157
Coldcat83's Avatar
Coldcat83
There is a recall for the sensor go to the dealership they will replace it for free.
Blaster9:no problems.. i think.. Airbag light is the only thing
Old Apr 20, 2009 | 09:54 AM
  #158
07_350z_JP's Avatar
07_350z_JP
Originally Posted by 07_350z_JP
07 -purchase 5/07----27K as of 10/31/08
Slave Cylinder Recall at -------------18k
Semi truck sound noise in 1st finally acknowledged as faulty tranny since new
replaced under waranty-----------------20K
Faulty TPSM--- Replaced --------------24K
Im getting the fuel light on and tank only takes 14gal to fillup as well--Ill take it in next week----started at 25k
Hatch shocks seem really weak-- after popping open I used to lift maybe 2-3 inches and then it opended by itself all the way ---- I have to lift it about 3/4 of the way otherwise it wont go beyond 1/2 open.----started at 20k---progressivley worse
Adding to my list - 32.5K Now 4/20/09
--Water puddles under passenger seat anytime it rains.Im talking 2 inches!At dealer for 3 days now they cant find the source.I never noticed it before because the car was always garaged but I kicked the car out to work on my FI e30s in garage.
**Update Windshield seals will be replaced- they were fried/brittle at all 4 corners. Under warranty**
--Rear shock mount/shock rattles over speed bumps/road bumps.**UPDATE:Will be replaced shock and mount under warranty**
--Dash Rattle behind cubby -**Update:No solution -problem not replicated at dealer**
--Hatch shocks really really weak.See above..**UPDATE:Will be replaced both shocks under warranty**
Car is at dealer for 3 days now. So Ill post what they find-replace
UPDATES:4/21/09
Old Apr 20, 2009 | 10:01 AM
  #159
Sensi09's Avatar
Sensi09
Works Concepts
28K on a '07HR.
Still haven't done the slave cylinder recall, but it runs fine. A few rattles from what I think is the passenger side door. Loose exhaust tip which rattles when cold
Went in for an oil change the other day, but ended up getting a major service. Need new front brakes. I was okay with just pads and resurfacing rotors at the time, but after some hard driving this weekend, not sure if the rotors are still serviceable.
Old May 29, 2009 | 04:03 PM
  #160
Swimminggerman's Avatar
Swimminggerman
smack the door where the power window controls are, should reconnect it, i had that when i first bought it, pulled over cos it was raining. thought "youve gotta be sh*tin me" ive not had a problem yet. oh yeah 14,554 on an 07
