My New 07 VQ35HR! POWER
ive had the car for 4 years i know how to launch it
heres a video i made cause someone dident belive u can power through traction control http://www.youtube.com/watch?v=zwGK7TFi6pE
it was wet i have another video somewhere of my new exhaust set up doing a few launches i try not to launch to hard to consurve my tires or i leave traction contol on and pull through maybe ill make a video tommarow before i go in for tires if it dont rain
On topic though..
Before I got my Z (21k mi), the previous owner had the slave replaced under warranty.. I think it was a recall.. But, under a hard launch, mine still sticks to the floor. I'm hoping the SS Clutch line and ATE SB will fix that though.
OP I know you posted this a while back but the squeeking you refer to might actually be some of the plastic panels in your trunk lid. If you havent fixed or figured it out yet, pop your trunk and start pressing on each plastic panel lining your trunk window. You should here a pop and the squeeking will be fixed. This is a common problem for some reason.
UPDATE::
All I did was bleed clutch with new brake fluid!
Pedal doesn't drop or grind gears!
Changed tranny fluid, no more whine!! Thinking of switching to MOTUL or REDLINE im currently using mobil 1
I reccomend anyone with these problems to start with fluid.
i have a zex 2007 350z full nitrous kit specific for my HR motor un opened still in box heat sealed in factory plastic with 2 10lb tanks one from zex and one traditional blue NOS i need to sell considering i just got my license taken away and need to pay off tickets and fyi i did all the research and nos is 100x safer then turbos considering u stay under a 75 shot witch comes in my un-opend kit and i am the same way my is no show all go (: (a sleeper)
