Cranks no start
Old Dec 10, 2019 | 05:08 AM
George Greve's Avatar
George Greve
Default Cranks no start
I know this is been asked so much.
heres my issue, I purchased this 04 G35 disassembled, I have spent the last month working on getting it back together so I could see how it runs.
I have only replaced gaskets on motor, including intake, v/c gaskets upper and lower pan gaskets, rear main seal, plugs.
new clutch ect.
I got driveline back in all wired back up,new plugs,battery, fresh fuel ect. Found couple issues 2 coil packs and cam sensor. Swapped out. Security light goes out when cranking over and when key is turned on.
This car will crank all day, gets fuel,spark and air but not starting. I'm at a loss. Scanner has no codes,and finding no information.
I have a couple short videos but not sure how to upload.
Old Dec 10, 2019 | 06:03 AM
jhc's Avatar
jhc
General & Tech Moderator
Have you confirmed the NATS (anti-theft feature) is working correctly - does the flashing red light on the dash go off?
Post your video on YT. All you have to do is paste the hyperlink in a post, it will embed itself. Gl!
Old Dec 10, 2019 | 06:08 AM
George Greve
the light does work and does go off when key is turned on
Old Dec 10, 2019 | 06:14 AM
George Greve
Never posted there before, but try george Greve on Yt. See if that posted
Old Dec 10, 2019 | 02:23 PM
George Greve
ok, so I have managed to get it to start and run, however I unplugged crank sensor for this to work. My question is the sensor or a flywheel issue?
Old Dec 10, 2019 | 04:29 PM
SPID3R's Avatar
SPID3R
Have you checked for codes or are you running blind
Old Dec 10, 2019 | 04:37 PM
George Greve
Have no codes at all. That's been issue. I read somewhere that someone had unplugged crank sensor and it started.
it was shot in dark for me,and paid off.
That's why I'm asking if sensor or flywheel?
Old Dec 11, 2019 | 03:26 AM
SPID3R's Avatar
SPID3R
I read that if it is the crank sensor, sometimes moving the car or putting it in 5th or 6th while cranking will fire the vehicle.
try that as a troubleshooting technique.
Also, cleaning the sensor and electrical pigtail may help. Was the sensor full of oil? Which sensor did you pull/ driver or passenger?
Old Dec 11, 2019 | 06:17 AM
George Greve
Didn't unplug cam sensors, unplugged crank sensor that is bottom of trans and engine. It was dirty but cleaned it before I installed it.
Djd0020
Dec 27, 2018 12:13 PM
iiLLuSiiV
Nov 21, 2018 04:21 PM
Bak3rme
Jul 10, 2017 11:34 AM
tclark90
Nov 7, 2016 06:55 PM
Nolan23
Mar 1, 2016 03:20 PM
