Stock Tire Size Replacement Question?
Old May 17, 2005 | 11:29 AM
jcbaile1's Avatar
jcbaile1
Question Stock Tire Size Replacement Question?
I have a 2003 350Z Performance with stock 18's and want new tires and was wondering if i could use 235/40/R18 on the front and 255/40/R18 on the rear. I am curious if they will fit on the wheels and also if it will mess up the VDC. Any help would be nice.
Old May 17, 2005 | 11:33 AM
karmstro's Avatar
karmstro
I am in the same situation. But, I am thinking about going with 245/40/18 up front and 255/40/18 in the back. This gives me around a half inch stagger from front to back. VSC should be ok with it I hope!!
Old May 17, 2005 | 10:14 PM
froggy's Avatar
froggy
What about 245-40-18 front & 255-45-18 rear
http://www.miata.net/garage/tirecalc.html
Old May 18, 2005 | 04:50 AM
karmstro's Avatar
karmstro
I was looking at that more tire sizes that way. However that puts the stagger at like 1.2ish or something. A bit much for the VDC
Old May 18, 2005 | 12:29 PM
froggy's Avatar
froggy
You're right(1.3), stagger required: .5 - .75 ...help...
Old May 18, 2005 | 04:49 PM
03FIDDYZ's Avatar
03FIDDYZ
wish i could help i need new tires to so im going to keep an eye on this thread
Old May 18, 2005 | 05:56 PM
karmstro's Avatar
karmstro
My 3 cents….
With the 245/40/18 front and 255/40/18 rear I think the stagger is 0.4, which should be fine with VDC when compared to the (0.5-0.75) requirement. This setting should also reduce the under-steer known to be a problem with the Z’s balance on the twisties. I think the requirement is kind of loose though. You can naturally deviate outside of the ideal setting with the OEM sizes tires just from the simple wear of the tire (the fronts wearing more then the rears). So, I think I will be in the clear! The disadvantage is that there are few tire selections in these sizes. There are a few on tires.com but I think I am going to go with the BFGoodrich g-Force T/A KDW 2 at tirerack. From what I have read these are good tires, last fairly long, are a little noisy. But, I doubt they will make the horrible cupping noise that I now have on my fronts currently!!
Old May 19, 2005 | 07:23 AM
froggy's Avatar
froggy
Rule number one (by Sticky):
If you increase or decrease your tire size over 3% of stock size (in outsize rolling diameter) it will affect your ABS braking system and VDC. Simply put, your car will sense the back wheels are rotating too quickly for example and the ECU will think you are spinning your tires/losing traction which will possibly cause your car to brake or cut off the throttle. I recommend you keep the margin within 1.5%
255-40-18rear looks small compare to 245-40-18front
Braking rules is tempting,kdw2:just do it
Old May 19, 2005 | 12:23 PM
froggy's Avatar
froggy
Check this (old) post: Tire sizes for stock 18's. Need some info for new tires ( Multi-page thread 1 2 )
Old May 19, 2005 | 12:41 PM
karmstro's Avatar
karmstro
try again
Old May 20, 2005 | 11:49 AM
froggy's Avatar
froggy
https://my350z.com/forum/wheels-and-tires/38006-tire-sizes-for-stock-18-s-need-some-info-for-new-tires.html
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
