Unofficial Enkei Wheels Thread
Old Mar 29, 2011 | 05:35 AM
  #661
rich2342's Avatar
rich2342
those tires look a bit stretched. What size? Any better rear/side shots?
Old Mar 29, 2011 | 08:12 PM
  #662
Creepin!'s Avatar
Creepin!
245/35/18 275/35/18 I'll post some more pics in a bit
Old Mar 29, 2011 | 08:36 PM
  #663
terrasmak's Avatar
Same wheel combo, i run a 275/35 up front.
Old Mar 30, 2011 | 10:07 AM
  #664
LeMansZCa's Avatar
LeMansZCa
Default My RPF1 at Laguna Seca
So.. here is the problem child, REVIVED! (Scott and I were scratching our heads)
Setup:
F- 9.5x18, 255x35 Toyo R888, 2.4 camber
R- 10.5x18, 274x35 Toyo R888, 2.0 camber
I was able to fix the rubbing by stiffening up the Koni's on front and rear + a fender roll. I think the R888 275's runs a lil wider...
Awesome day at Laguna seca and pushing it my the limit!!
Many thanks to Scott and Z car garage to help me set this up!
Old Mar 30, 2011 | 10:25 AM
  #665
rich2342's Avatar
rich2342
^Awesome pic... Wheels look pretty aggressive, but hard to tell with the pitch.
Old Mar 30, 2011 | 10:35 AM
  #666
terrasmak's Avatar
Setup:
What springs, what spring rate , how lowered are you ? The pic shows your car with the suspension fully bottomed out. Do you have bump stops?
With my set up, the only place i can rub up front is the fender lip. Fully bottomed, my tire slightly touches the inner fender well plastic ( i removed my spring and fully compressed my suspension for testing) The rear on mine has a mile of clearance.
Old Mar 30, 2011 | 11:06 AM
  #667
LeMansZCa's Avatar
LeMansZCa
Thanks! I bought Tein springs long time ago.. don't really remember the spring rate. It was lowered close to an inch. I don't have bump stops. I didn't feel the car fully bottoming out. Luv those Koni Yellows!
Old Mar 30, 2011 | 11:14 AM
  #668
terrasmak's Avatar
Half your front and rear tire are tucked and the mud flap is almost on the ground. Spend a couple hours removing springs, looking at your travel limits, seeing what is causing the problem. It helps for setting things up.
Old Mar 30, 2011 | 12:10 PM
  #669
Junkster's Avatar
Junkster
Anyone know which vendors still sell the limited edition "gunmetal" RPF1's?
Old Mar 30, 2011 | 01:46 PM
  #670
yellowxhoodie's Avatar
yellowxhoodie
18x9.5 +15 225/40 F
18x10.5 +15 255/35 R
Old Mar 30, 2011 | 02:10 PM
  #671
LeMansZCa's Avatar
LeMansZCa
that's mo fo low!
Old Mar 30, 2011 | 02:44 PM
  #672
yellowxhoodie
Old Mar 30, 2011 | 11:32 PM
  #673
terrasmak's Avatar
http://www.flickr.com/photos/61208532@N05/5575899281/http://www.flickr.com/photos/61208532@N05/5575899281/ by http://www.flickr.com/people/61208532@N05/
One of each wheel, 255/40 front and 275/40 on the rear, i wanted it to understeer for her first event. Typically i run my other RPF1's up front with 275/35's on them.
Old Mar 31, 2011 | 01:26 PM
  #674
AadosX's Avatar
AadosX
Couple pics of mine...
18x9.5/10.5 +15 with 275/35 & 295/35
Lowered on Eibach Sportlines with -2 camber front and -2.7 camber rear
Next alignment I'm going to go with closer to -2 camber rear because these 295's are creating a little understeer despite the 275's up front.
Old Mar 31, 2011 | 02:29 PM
  #675
brandon3434's Avatar
brandon3434
Sick...And I've been on that dyno too! What were your numbers? Z1Motorsports is a cool place, you ever been to ZNationals?
Old Mar 31, 2011 | 02:31 PM
  #676
terrasmak's Avatar
Understeer will partially be caused by the difference in camber, move the fronts so they have more camber than the rear. These are for the track right? -2.7 front and -2 to -2.2 rear will help a lot, and give you better traction out of a corner as you unwind the wheel.
Old Mar 31, 2011 | 02:38 PM
  #677
AadosX's Avatar
AadosX
Thanks man! Your Z is one of my favorites, easily one of the cleanest around here. But I'm a little partial hah.. Black Nismos are my favorite. =)
279/242 with cat-back exhaust and long tube intakes last time. I go there a bunch.. it's only about an hour and a half from me. I was at Z Nats last year.. and I've been to two 370Z meets (one was just two weeks ago). They're starting to know me by name around there heh.
Yes this I know, thanks for the tips! I picked my numbers based upon the stock Z alignment specs also having more camber in the rear than front. I thought it was odd but wanted to start there and then go from there. I'm going to do the spring-mount mod soon and when I go back in for alignment I'm going to go even camber all around this time. I think on the Z, more camber up front might be a little much. Plus I can't adjust camber in the front and don't want to bother with aftermarket front control arms since the current -2 front camber is fine with me.
This is my daily driver btw, but I do autocross when I get the chance. Right now the lack of LSD is causing the biggest problems lol.. And I would like some sway bars too.
Old Apr 1, 2011 | 06:25 PM
  #678
Chi-TownWarrior's Avatar
Chi-TownWarrior
Hello All,
I've hit a point where I've gotten my head wrapped around numbers trying to figure out what I want.
I got 18x9.5/10.5 RPF1s on order. I want to run tire wise Bridgestone RE-11 265/40 front and a 275/40 rear. I want to avoid that stretched look. I saw Scotts350 say 275 looks stretched, but looking at tire calcs a 265-275/40 is almost perfect for the F/R. But looking at a 285/40 or 35 seems too big and too small. The thing that is really killing me is percentage differences regarding the speedo, and I'm trying to keep that as close to stock as possible. I can go on for almost forever on numbers, but yeah........... I'm lost.
Looking around at peoples suggested camber I feel a 2-2.5 is where I want to be with a daily driver with a few track days here and there.
So please critique this.
Someone please help a brother out.
Old Apr 1, 2011 | 06:38 PM
  #679
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Originally Posted by Chi-TownWarrior
Hello All,
265/40 is to much tire for the front (4.8 mm taller than stock 225/45). I ran a 255/40 on my 9.5 fronts and it was just right with no stretch; it's also the closest you can get to stock specs regarding the speedometer reading. The 275/40 is also preferred in the rear if you are concerned about the speedometer but be prepared to roll your fenders if you purchased the +15 offset.
Old Apr 1, 2011 | 07:39 PM
  #680
Chi-TownWarrior
Yeah a 255/40 is about spot on, but the RE-11s don't come in that size. Oh well, I'll have to find another tire (I don't like to mix and match). They make a 255/35, but I'm not sure how off that'll be with a 275/40 in the rear. Fender rolling isn't a concern of mine. The car is going to get repainted anyways.
