Unofficial Enkei Wheels Thread
Old Oct 9, 2012 | 09:04 AM
  #1481
scotts300's Avatar
scotts300
Originally Posted by thespottedcow
I think the oem wheels are around a 30 offset, 45 is too high, its not going to look great, and I wouldnt go with a 7.5 wide rim, get something wider..
Depends on which wheel you're referring to. They come in 7.5 - 10" width.
Originally Posted by Azzerare
Hey guys, I found a good deal on some Enkei RSVs but I don't know enough about them to determine whether or not they'd be a good fit for the Z.
They're used and the seller listed only the following:
size is 18x7.5
they are 5 lug universal
and of course pictures.
I was able to dig up the following from an older online posting for a similar wheel sale (same model) :
Offset: +45
Bolt pattern: 5x112 & 5x114.3
I assume that means that the offset is the same on both the front and rear wheels and +45 seems high to me...
Can someone that knows more about wheels chime in on what you think?
My main concern is that they'll be even more recessed in the rear wheel well than the oem touring v1 wheels are, with such a high offset, which I do not want. Then again, I don't know near enough about wheels...
7.5 is also a bit thin, I think, but did I mention that its a great price?
Ideally I'd pick up a decent used set of lightweight works for under 2k but I don't have that to play with right now and these seem like they could keep me happy until spring.
Thanks in advance!
-Adam
They could work - likely with a spacer - as winter wheels. Or, if they are a steal and you're willing to invest in some good spacers - they can work with some chubby tires. The sizes are not ideal, but some Zs do come stock with 17x7.5 front and 17x8 rear wheels.
If you want a cheap set of nice wheels, I do have a set of OEM chrome wheel (premium option) with tires.
Old Oct 10, 2012 | 02:57 PM
  #1482
TuckerE36's Avatar
TuckerE36
Originally Posted by Cux350z
+1 to everything S671 said.
-1 to Tucker
OP....youre an idiot noob. You have been on here for less than a month and are already overposting. I have seen your post/name pop up in the last week. Welcome to my ignore list.
The OP was simply asking a question. And as for the OP overposting!? Who the hell cares...You don't have to read his posts, and if he's on your "ignore list" why are you even posting on his thread in the first place??
It's *** holes like you and S671 that makes people refrain from using forums in the first place especially when they're just asking a simple question. Go be a dick on some other forum...
Old Oct 10, 2012 | 03:14 PM
  #1483
SR71's Avatar
SR71
Lead Super Moderator
It's *** holes like you and S671 that makes people reframe from using forums in the first place especially when they're just asking a simple question. Go be a dick on some other forum...
Its "refrain" you dolt. Grow some thicker skin or go be a baby on another forum, we're stocked up here.
-S671
Old Oct 10, 2012 | 06:38 PM
  #1484
vndr09's Avatar
vndr09
I see what you did there
You are saying that this forum is already full of babies, such as yourself?
Old Oct 10, 2012 | 07:59 PM
  #1485
mr. sparco's Avatar
mr. sparco
Originally Posted by z33_cliff
I haz enkei wheels too now
Did you put the wider tires in front? Rears look narrow and stretched.
Old Oct 11, 2012 | 03:07 AM
  #1486
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
+1 That's what I noticed as well.
Old Oct 11, 2012 | 12:53 PM
  #1487
805350z's Avatar
805350z
Not mine, clearly But anybody else waiting for prices on the rs05RR?
Old Oct 11, 2012 | 04:25 PM
  #1488
mr. sparco's Avatar
mr. sparco
Reminds me of the late 90s supertouring look that everyone wanted. Too many skinny spokes.
Old Oct 11, 2012 | 05:23 PM
  #1489
yellowxhoodie's Avatar
yellowxhoodie
has potential, that car just doesnt flow at all.
Old Oct 11, 2012 | 11:22 PM
  #1490
SoCal07HR's Avatar
SoCal07HR
I am!!! 18x10.5 +22! 18x11 +16! Can't wait!
Old Oct 12, 2012 | 10:52 AM
  #1491
scotts300's Avatar
scotts300
I'm interested in a bunch of them, depending on cost and final (actual) weight.
Old Oct 12, 2012 | 12:45 PM
  #1492
terrasmak's Avatar
22 pounds going off the JDM website
Old Oct 23, 2012 | 08:35 AM
  #1493
iKevinz's Avatar
iKevinz
Old Oct 23, 2012 | 08:36 AM
  #1494
Bmurray350z's Avatar
Bmurray350z
unique color combo. is it the 9.5/10.5 +15 setup? what size tires?
Old Oct 23, 2012 | 08:44 AM
  #1495
iKevinz's Avatar
iKevinz
Yeah its 9.5/10.5 +15. Tires are 255 40 18 and 275 40 18
Old Oct 24, 2012 | 06:03 AM
  #1496
ny350zat's Avatar
ny350zat
Default best size rfp1s???
hey guys im pretty new to this forum and ive done alot of reading but well here goes my question..winter is coming up so im saving up to get a set of 18' rfp1 wheels....i have tokico d specs and the tokico red springs not installed in the car yet but i will most likely install them after the winter is done, all the offset options are confusing me so what are some aggresive specs i can go with after lowering the car (about 1 inch drop in the front and 1.5 inch in the rear) please recommend wheels size and offset and also tire size
i will most likely not track the car more than twice a year
thanks guy
Old Oct 24, 2012 | 07:15 AM
  #1497
Flo-ridaZ33's Avatar
Flo-ridaZ33
16"
Old Oct 24, 2012 | 07:29 AM
  #1498
terrasmak's Avatar
What is the common that everyone runs as seem in the Enkei wheel thread?
Old Oct 24, 2012 | 08:05 AM
  #1499
ny350zat's Avatar
ny350zat
most people run 18x9.5 front and 18x10.5 rear which is fine but the offset is whats confusing me and also the tires, i dnt really wanna roll my fenders but i also dnt want a weak tire spec
Old Oct 24, 2012 | 08:18 AM
  #1500
terrasmak's Avatar
What offset is available in that width with out bolt pattern ?
BTW a rolled rear is about a 15 to 20mm difference in offset, you need a roll.
