FAQ: Official wheel "SPACER" thread!
Old Jun 18, 2014 | 09:28 PM
  #1181
CJs_Z33's Avatar
CJs_Z33
Default V1 Touring wheels with 20mm/32mm spacers
Front:
Rear:
Sits flush front and back
Old Jul 24, 2014 | 12:51 PM
  #1182
kakirk30's Avatar
kakirk30
So I just got new wheels and I had to settle on 19x8.5 +15 in the front. The back is fine at 19x10 +20. So I was going to get a spacer for the front. I was looking at a Project Kics 20mm spacer. Would that be ok without any rubbing or anything. Also if it matters I have 245/35/19 tires in the front.
Thanks, Kaleb
Old Aug 1, 2014 | 06:09 AM
  #1183
ARRRT's Avatar
ARRRT
hi, everyone!
just a quick question to be sure:
bought z1 slip-on 20 mm spacers along with longer 70 mm studs
do i need to buy a new set of open ended lug nuts, or can i reuse stock ones?
my rims are v2 touring...
my logic tells me that oem studs are about 46 mm and my new ones are 70, so the 20 mm spacers should clear the difference, but to be completely sure, i think it'll be better to ask)))
sorry for my english - i'm a foreigner)))
Old Aug 10, 2014 | 08:42 PM
  #1184
sickZ31/Z33's Avatar
sickZ31/Z33
Default Another Z1 Motorsports broken spacers
I also thought everything Z1 Motorsports made were quality parts as well, but here's what just also happened to me .. Removed my rear wheels last night because I'm going to be swapping its tires and here's the awful seen I saw
My rear driver side spacer: BROKEN as well
My rear passenger side isn't much better either. You can see the cracks showing around the hub centric ring. It won't last much longer.
Like OP, when I purchased these, they were brand new along with their extended studs. Have had them on for less than 2 months. Not a single track event or even a canyon run. Extremely disappointed about how weak these spacers are. I haven't removed my front wheels since my front tires haven't showed up yet but I'm not expecting any better. I hope Z1 Motorsports fixes this problem from the spacers they're currently selling.
Old Aug 12, 2014 | 02:36 PM
  #1185
NTrunz22's Avatar
NTrunz22
Default Wheel spacers
Anyone know what size spacers to get to make the wheels stick out alittle more on the Z don't have it dropped yet the specs 19x9.5 245/35 front and 275/25 19x11 rear an suggestions
Old Aug 12, 2014 | 06:54 PM
  #1186
craig12895's Avatar
craig12895
We will need wheel offsets in front and rear before we can even make a suggestion
Old Aug 13, 2014 | 12:27 AM
  #1187
NoQuestionZ's Avatar
NoQuestionZ
25 series sidewalls!!!!???
"Low pro so low look like I'm ridin on blades"- Fiddy Cent
Old Aug 13, 2014 | 04:49 AM
  #1188
travlee's Avatar
travlee
Master
get the correct offset of wheels and you wouldn't need spacers..... just sayin
might want to check out the stretched tire section, sounds like you are going to be "one of those guys"
can you even stretch a 25 series to fit on a 11" wheel? my initial thoughts are its not possible
Old Aug 13, 2014 | 04:54 AM
  #1189
StuLax18's Avatar
StuLax18
General & Tech Moderator
Size spacer you need = how far you want it to stick out - how far it currently sticks out.
Old Aug 13, 2014 | 04:56 AM
  #1190
Classy's Avatar
Classy
That isn't even TH math
Old Aug 13, 2014 | 05:21 AM
  #1191
Syner's Avatar
Syner
hellasunk with extreme positive camber is the new thing.
get with the times, fogey.
Old Aug 13, 2014 | 05:24 AM
  #1192
Classy's Avatar
Classy
Old Aug 13, 2014 | 05:26 AM
  #1193
Syner's Avatar
Syner
Originally Posted by Classy
Old Aug 13, 2014 | 05:27 AM
  #1194
350zHalleck's Avatar
350zHalleck
in some weird way I kinda like that
Old Aug 13, 2014 | 05:28 AM
  #1195
Syner's Avatar
Syner
i do too.
Old Aug 13, 2014 | 05:36 AM
  #1196
travlee's Avatar
travlee
Master
it looks pigeon toed
and retarded
Old Aug 13, 2014 | 05:42 AM
  #1197
Syner's Avatar
Syner
and retarded
you look pigeon toed
and retarded,
Old Aug 13, 2014 | 05:46 AM
  #1198
travlee's Avatar
travlee
Master
oh no you didn't..... I will get my second babies mommas cousins husbands sisters ex on you... he stay up thera
Old Aug 13, 2014 | 05:49 AM
  #1199
Syner's Avatar
Syner
he lives in canada? what's his name? i might know him.
Old Aug 13, 2014 | 05:53 AM
  #1200
350zHalleck
you're a retarded pigeon.
