will these tires work?
Old May 28, 2009 | 12:45 PM
acidnitr0's Avatar
acidnitr0
Default will these tires work?
i have read the stick on the VDC but i am still a little confused. i have on 04 preformance with OEM 18".
currently i am running 225/45 in the front and 245/45 in the rear.
i am in need of some new tires in the rear but am in kind of a hard spot right now with money.
i found a pair of 255/40/zr18 at a really good deal locally, but im not sure if this tire will throw my VDC off...
looking for some advice if i should pick these up or if i should wait it out and replace the rears with the same size tires?
thanks for the help...
Old May 28, 2009 | 01:06 PM
scotts300's Avatar
scotts300
The 255/40/18s rears (>26.0") will be ever-so-slightly taller than the fronts (<26.0"). If you don't mind turning off the VDC until you get new (shorter, like 245/40/18) fronts, don't worry about it.
Old May 28, 2009 | 01:08 PM
acidnitr0's Avatar
acidnitr0
thanks for the fast reply.. the front are fairly new with less then 2k miles on them so i dont see that happening any time soon... i guess i better hold off until i can afford getting the right size.
Old May 28, 2009 | 01:14 PM
You may as well call this 4-square which I do not recommend.
Old May 28, 2009 | 04:05 PM
zerafian's Avatar
zerafian
so you want the 255's in the rear? If so youll be fine, it shouldnt cause a prob
Old May 28, 2009 | 05:07 PM
Spike100's Avatar
Spike100
You won't have any problem with your VDC-equipped Z running 225/45-18" front with 255/40-18" rear.
If the tires are a good deal, buy 'em and mount 'em; those rears will run well within this setup.
--Spike
Old May 28, 2009 | 05:48 PM
Spike100's Avatar
Spike100
David,
I read your message and would like to offer these comments. Of course, any of this is very arguable.
If you go all-square (or near all-square) with a VDC-equipped car:
  • Never mount a taller tire on the front than the rear. That always fails with a VDC-equipped car. I believe that you would agree with that statement.
  • If you go all-square, you should go with the OEM rear size (overall diameter), and avoid a smaller OD. For example, mount 245/45-18” all-around, but do not mount 245/40-18” all-around. I’m not sure if you agree with this statement.
My comments and advice is based in personal experience running various types and sized tires. I am interested in your comments.
--Spike
Old May 28, 2009 | 06:22 PM
acidnitr0's Avatar
acidnitr0
It's not that Im wanting to run the 255/40 but the tires were a good deal. On the other side of it I don't want to run something that will affect VDC or performance.
Thanks everyone for there post. I also see we have some that say it will work and some that say it won't.
Old May 28, 2009 | 07:14 PM
Spike100's Avatar
Spike100
Stop worrying about this. It will work just fine with your VDC-equipped car.
--Spike
Paul.
Oct 16, 2015 07:34 PM
Shane86
Sep 17, 2015 05:33 PM
