Official Aggressive Wheels & Fat Tires Thread
Old Jul 5, 2011 | 08:57 PM
  #2201
scotts300's Avatar
scotts300
Originally Posted by 2004Black350z
Scott WHat would u recommend then? I have same setup(wheels specs wise) As soon as i get a front bumper ill be attacking the tires plus drop etc. I have 295 35s in the rear now. Will be switching the fronts from 245 2 265 35 i guess. I will be lowered on prob GF210s. Looking for a mild MILD drop just to help with fender spacing. I really need a rear spacers so what u think? I dont track/drag. just a DD
I don't think spacers are needed at all with that big tire, but with a good rear roll, you could probably run a 10mm bolt-on spacer. There is a lot of room in the front - you could go 275/35/18 even. Use the 10mm spacers that you bought for the rear as a test-fit up front before buying another set. Maybe 5mm shim-type spacer would be enough up front, or maybe you'll want the 10mm.
Old Jul 5, 2011 | 09:00 PM
  #2202
2004Black350z's Avatar
2004Black350z
Exhaust Whore
well right now the front sticks out but the rears dont. Idk if thats due to the stretch up front or what
Old Jul 5, 2011 | 09:01 PM
  #2203
scotts300's Avatar
scotts300
on an 18x10 +25? Weird, I've seen 18x10.5 +15, which sticks out 16mm more than your set-up, barely poke up. Camber plays a role of course.
Old Jul 5, 2011 | 09:04 PM
  #2204
Waiz's Avatar
Waiz
Sounds like the same problem that 370z on blue TE's had, he definitely needs more camber if it's sticking out that bad.
Old Jul 5, 2011 | 09:05 PM
  #2205
2004Black350z
Exhaust Whore
yea idk. I still havtn had an alignment in a while. Fronts have been on car for wow idk 30k miles. Now i have a weird slight shake from the front right tire that iv been told is unusual wear. Kinda like a knot in the tire. So until i get springs and new fronts i was gonna wait for the alignment
Old Jul 6, 2011 | 01:12 PM
  #2206
Looch's Avatar
Looch
Nothing insanely meaty but definitely no stretch
18x9.5/10.5 +15
285/35 255/35
Old Jul 6, 2011 | 01:32 PM
  #2207
03threefiftyz's Avatar
03threefiftyz
Fat enough.....?
Old Jul 6, 2011 | 02:07 PM
  #2208
scotts300's Avatar
scotts300
Fat enough.....?
18x9s on the right with 285s and 18x10.5s with 285s on the left? I did the same sort of comparison with 18x10s vs 18x10.5s, and the stacked-difference was noticeable. Yours is VERY noticeable. What's that - 3 or 4 inches over 4 tires?
Old Jul 6, 2011 | 02:08 PM
  #2209
03threefiftyz
Actually ~4.5". The tires are on a slope. The smaller ones start about an inch higher.
Old Jul 6, 2011 | 02:59 PM
  #2210
scotts300's Avatar
scotts300
Ah, just saw that in your NorCal AX post. 4.5" of width - you should notice that! That kill any thoughts I had about using my 9/10.5 SSR Comps with 285/315 for autox. I just nabbed a set of 315 scrubs, and will try them on the 10.5 +15s, maybe cut the fender lip.
Old Jul 6, 2011 | 08:12 PM
  #2211
-Trav-'s Avatar
-Trav-
18x9.5/10.5 +15
285/35 255/35
Clean n simple.. what type of suspension and how much camber are you running?
Old Jul 6, 2011 | 08:41 PM
  #2212
ChriZTT's Avatar
ChriZTT
He posted in the ENKEI wheel thread that he was running -2 degrees camber all around.
Old Jul 6, 2011 | 08:48 PM
  #2213
jkim824's Avatar
jkim824
18x9.5/10.5 +15
285/35 255/35
Attachment 317658
Very nice! Similar to my setup. Do you have more pics of different angles?
Old Jul 7, 2011 | 01:46 AM
  #2214
350Zdj's Avatar
350Zdj
maybe this would help...
rear: 18 275/40 +10mm
front: 18 275/35 +25mm
I've already auto-x'ed this setup and i got no rubbing issues at all.
I could probably use some 5mm spacer upfront. Im gonna give it a try when i get the chance.
Old Jul 7, 2011 | 08:46 AM
  #2215
2004Black350z
Exhaust Whore
so its def my alignment. Since idk crap about suspension what should i make sure the shop thats doing my alignment? specs etc. Thx btw for replies
Old Jul 7, 2011 | 09:35 AM
  #2216
lgear080's Avatar
lgear080
**** spacers... your car looks great.
Old Jul 7, 2011 | 01:44 PM
  #2217
03threefiftyz
Very dirty car and poor pics, but you get the idea. Shocks are off being rebuilt. Ride height is actually about .5" lower in the front and .8 lower in the rear.
Yes my headlights need a restoration...
Old Jul 7, 2011 | 01:53 PM
  #2218
scotts300's Avatar
scotts300
[/IMG]
New Hoosiers look gummy!
Old Jul 7, 2011 | 02:03 PM
  #2219
03threefiftyz
It doesn't look like the 315's would fit on the front without a small spacer. Even the 285's are fairly close to the LCA. Also, the 285's on 9" wheel stack was 43.3". The 285's on 10.5" were 47.6". 10.8" per vs 11.9". Do like.
Old Jul 7, 2011 | 02:25 PM
  #2220
scotts300's Avatar
scotts300
Yeah, I think the 315 up front will be tough without some fender modifying. The 315 rear should be easy, and I will find out soon (will test fit the 315 up front just for sh00ts and giggles though).
