Official Aggressive Wheels & Fat Tires Thread
Old Mar 23, 2012 | 08:20 PM
  #3401
SoCal07HR's Avatar
SoCal07HR
Originally Posted by maximariceboi
Need some help picking tires for new set up.
Currently running:
19x9.5 +22 255/35
19x10.5+22 285/35
Lowered with Greddy coilovers less than a finger gap in the rear with a minor fender roll, spl rear camber arms, spc toe bolts, spl toe arms and spc front camber arms.
My new set up will be:
19x9.5+22
19x11+15
What tires should I run next? I plan to stick with 255/35 front or go wider?. Will 285/35 be safe to run in the rear or will need some more negative camber or roll the fender more? At the moment I found out there is some bondo on 1 quarter panel but I do plan to get body work done soon but need to take care of a few other things... Can I go larger tires without out rolling the fender more? More negative camber?
Any help would be appreciated. Thanks in advance!
Eric
You could go 275/30 and 295/30 without any problems. I'm running a 18x11 +30 with 295/35 in the rear and I have lots of room I know I could get a 15mm spacer in easy. Your front wheel is very common and I've seen 275/30's on the same offset. Since you have all adjustable suspension you shouldnt have anything to worry about.
Old Mar 23, 2012 | 09:05 PM
  #3402
maximariceboi's Avatar
maximariceboi
Ah ok so fender roll isn't really necessary for the rear? Right now my current set up, it's pretty flush and it might seem the new wheels are going to poke a bit at its current stance. I don't remember the where the rear camber is set.. I will need to find my paper work to confirm. Thanks for the advice and will look into the 295 rears now should I be leaving the vdc off since the diameter will be off?
Old Mar 23, 2012 | 09:10 PM
  #3403
SoCal07HR's Avatar
SoCal07HR
You might need to roll them a bit more or run a little more camber. VDC should be good, I don't have VDC though so I'm not really an expert on that. I'm sure someone will chime in on that.
Old Mar 24, 2012 | 04:30 AM
  #3404
rps13drift's Avatar
rps13drift
18x10.5 +22 / 275/35/18 - all around
Old Mar 24, 2012 | 08:34 AM
  #3405
maximariceboi
Ok thanks for te help!
Anyone with vdc running 295/30/19 rears?
Old Mar 24, 2012 | 09:45 AM
  #3406
Kulwiec's Avatar
Kulwiec
Originally Posted by fhumphrey04
Thanks guys!
The rear doesn't look as aggressive because it isn't as low as the front, but it is. Regarding the rear bumper- it's definitely wild and quite a controversial piece on here. Some days I think about changing it for an OEM + TS diffuser, but this is a Nismo and the rear bumper is a signature piece.
Not trying to poop on the wheel thread, but if you were to go that route, voltex diffuser is sick and you could pull it off with nismo front/sides
Picture from previous owner, same wheels/ no bodykit now.
Photo by Myacreative.com
Old Mar 24, 2012 | 10:49 AM
  #3407
terrasmak's Avatar
265/30 or 275/30 front and you will have ZERO issues.
Old Mar 24, 2012 | 11:15 AM
  #3408
-Trav-'s Avatar
-Trav-
Had 295/30 with 265/30 front, no problems.
I like 275 though. 265 is small on a 9.5, IMO
Old Mar 24, 2012 | 01:26 PM
  #3409
maximariceboi
Ok cool I'll look into the 265/30 for the fronts. Thanks!
I like 265 is small on a 9.5 though, IMO
Thanks for the reply! What size wheels were you running on the rears and did you have to roll the fender?
Also I would like to know what kind of tires are you guys are using. I'm planning to pick up bfgoodridge kdw2 tires. Any other suggestions? Thanks!
Old Mar 24, 2012 | 04:34 PM
  #3410
-Trav-'s Avatar
-Trav-
10.5 +22 rear and I had rolled the rear previously, but not necessarily because of that setup, so Im not sure if its absolutely required. I had no issues with mine. Rear tire was pirelli Pzero which fit PERFECT, no bluge just a square fit. Brands make a huge difference if youre picky.
Front was falken whech blew...to skinny and stretched in comparison.
I had the kdw2 on stock wheels and loved them. Excellent grip in wet or dry. Only downside was the noise, nearly deafening when coming to a stop. Some say its alignment but mine was good, others would agree theyre freakin loud. Tire rack has em worst in noise rating... I havent looked recently but I didnt know they made 30 profile KDWs?
Old Mar 24, 2012 | 06:49 PM
  #3411
maximariceboi
Ah ok yea I had to roll a bit on my fenders but 1 side I have some bondo on there so I couldn't roll too much. I guess I'll just roll it more till I get body work done. Wow didn't think kdw are that noisy... What other tire would you suggest? I have hankook v12 Evo and hate them
Old Mar 25, 2012 | 08:53 PM
  #3412
G4nismo's Avatar
G4nismo
275/35
Old Mar 25, 2012 | 08:58 PM
  #3413
805350z's Avatar
805350z
Old Mar 25, 2012 | 10:06 PM
  #3414
maximariceboi
How's 265/35/19 for the front? It's slightly larger overall diameter than stock.. The 265/30 is a smaller tire diameter wise. Anyone running 265/35? I know this should clear with out an issue but I want to see of anyone is running those. Not a lot of selection of tires though.
Just looking at tire selection for 265/35/19, 285/35/19:
-Bridgestone potenza s-04 pole position (280 tread)
-Bridgestone potenza re-11 (180 tread)
-continental extreme contact dw (340 tread)
-Yokohama advan sport (180 tread)
Also 265/35/19, 295/30/19
Anyone experienced the Bridgestone potenza s-04 pole position or continental extreme contact dw? Thanks!
Old Mar 26, 2012 | 01:07 AM
  #3415
-Trav-'s Avatar
-Trav-
If you run 295/30 rear then it would be best to keep the front at a 265 or 275/30. 265/35 would be too tall and might throw off your traction control, if you have it. If you want the 265/35, go with 285/35 rear.
Old Mar 26, 2012 | 03:32 AM
  #3416
maximariceboi
Just looking at 1010tires.com's tire calculator, 265/35 is 1.26% larger in diameter compared to stock. stock diameter 25.97" 265/35 is 26.3"
265/30 is 2.78% smaller than stock with overall diameter of 25.25".
295/30 is 2.7% , 25.96" diameter, smaller than stock rears 245/45/18 overall diameter of 26.68"
So you are saying if you run smaller rear diameter tire, stay smaller front diameter in the front as well so the traction control won't kick in?
Old Mar 26, 2012 | 04:30 AM
  #3417
-Trav-'s Avatar
-Trav-
bingo
Old Mar 26, 2012 | 05:02 AM
  #3418
maximariceboi
bingo
sweet. thanks for the help! now time to pick up some tires....I'm going to go with 265/35/19, 285/35/19. I hope the 285/35 will be ok for the 19x11 wheels.
Out of these 4...what would you recommend? I would like something with more tread life and have better traction than the hankook v12 evo. Only the 1st 2 offers >280 tread.
-Bridgestone potenza s-04 pole position (280 tread)**
-continental extreme contact dw (340 tread) **
thanks again!
Old Mar 26, 2012 | 05:53 AM
  #3419
Robert_K's Avatar
Robert_K
Didn't Go Cheap
thanks again!
I'm currently running BFG KDW 285/35-19 on my 11's.
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-dsc_00146.jpg   Official Aggressive Wheels & Fat Tires Thread-dsc00548.jpg   Official Aggressive Wheels & Fat Tires Thread-dsc00541.jpg
Old Mar 26, 2012 | 06:52 AM
  #3420
maximariceboi
Nice! whats the offset on your rears? what wheel/tire size are you running on the front? How you like the BTG kdw?
