Tire Shop screwed up my hubcentric rings QUESTION?????
Old Oct 29, 2009 | 10:43 PM
deezz's Avatar
deezz
Default Tire Shop screwed up my hubcentric rings QUESTION?????
Tire shop installed two rear tires for me about 1 month ago. Today while driving, another driver told me that one of my rear wheels was wobbling.
Took it to the nearest shop and they told me that two rings were installed on the "wobbling" wheel and none on the other wheel.
Can having two rings on a wheel that are not centered warp your wheel?
Old Oct 29, 2009 | 10:46 PM
JasonZ-YA's Avatar
JasonZ-YA
dammn hard to tell with out seeing it? any pics...but ya two rings usually are not used.....
however, are you sure one wasnt a hub centrinc ring for the spacer and the other a wheel ring??
-J
Old Oct 29, 2009 | 10:48 PM
JasonZ-YA's Avatar
JasonZ-YA
see this link just for quick reference, see the pics at the bottom of the ebay link, see how he points out the use/need of a wheel ring?? did you have both hubcentric rings and wheel rings by chance??
http://jbrlsr.com/?aid=5336108632&bi...item518aa14ac8
-J
Old Oct 29, 2009 | 11:26 PM
pchio's Avatar
pchio
Tire shop sometimes screwed up without taking a good look on the hubcentric rings. They took out the tires and swapped them from left and right without checking if one of the ring is sticked on the wheel. It happens!
Old Oct 29, 2009 | 11:58 PM
deezz's Avatar
deezz
I may be calling the part the wrong name. It's the small rubber piece you set on the hub then place your wheel on it to make certain it's centered. Basically there were two of these small rubber rings on one wheel and none on the other.
My issue is once they corrected the problem, the pass. rear wheel still has a slight wobble. Not very noticeable, but looks to be a warped wheel none the less.
Old Oct 30, 2009 | 04:14 AM
duro78's Avatar
duro78
If another driver pointed it out to you it must of been pretty bad how did you not feel it while driving
Old Oct 30, 2009 | 04:41 AM
rtiid22's Avatar
rtiid22
Worn out wheel bearing? Got mine replaced last week after just 40k miles on my 08' Z.. Left Rear
Old Oct 30, 2009 | 04:52 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Two hub rings will cause the wheel not to get flush with the rotor. So the stupid tire shop should have noticed that.
Old Oct 30, 2009 | 05:25 AM
Brrcats's Avatar
Brrcats
is there any damage? mistakes happen and if nothing was broken/damaged/no one got hurt and you are able to rectify it, whats the problem?
Old Oct 30, 2009 | 07:49 AM
rtiid22's Avatar
rtiid22
Here's his problem.. and I quote "My issue is once they corrected the problem, the pass. rear wheel still has a slight wobble. Not very noticeable, but looks to be a warped wheel none the less."
Old Oct 30, 2009 | 08:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
hubrings are only useful when youre mounting the wheel. Once you tighten the lugs down properly then the hub ring is no longer necessary.
Old Oct 30, 2009 | 08:05 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
^^ Not exactly correct. As the wheel can adjust itself when it is tightened to the surface of the rotor. The 5 lugs will not keep it in the exact spot for long and will cause it move without a hub ring, in turn will cause it to start to vibrate. The hub ring helps keep it in the same spot all the time.
Juztin
Nov 22, 2015 07:03 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
rizzla
Sep 29, 2015 03:58 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
