Question about 19x10.5 all around
Old Sep 10, 2010 | 02:35 AM
siberian57's Avatar
siberian57
Default Question about 19x10.5 all around
Hey I'm looking at a set of SSR type c's right now that are in a 19x10.5 +15mm offset all around with 265's all around. Are these too wide for the fronts? I know the rears will be alright but I've never actually read anything from someone talking about the 10.5's up front saying it's good or bad (it's usually 8.5 or 9.5) and if I did, they had staggered tire sizes and modified the suspension and I didn't know if that's because they had to in order to make it work or not. I was wondering if this was maybe to wide for my stock suspension 07 enthusiast?
Old Sep 10, 2010 | 03:13 AM
DavesZ#3's Avatar
DavesZ#3
Didn't search, did ya?
https://my350z.com/forum/wheels-and-...nd-issues.html
https://my350z.com/forum/wheels-and-...up-issues.html
https://my350z.com/forum/wheels-and-...und-setup.html
https://my350z.com/forum/wheels-and-...all-fours.html
https://my350z.com/forum/wheels-and-...ll-around.html
Old Sep 10, 2010 | 03:30 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
These are 18x10.5+15 but you get an idea of how much the fronts will stick out:
Old Sep 10, 2010 | 07:45 AM
scotts300's Avatar
scotts300
10.5 +15 fronts are biggins, but they certainly can fit with the right tire and suspension geometry. Are they a 265/30/19? A 265/35/19 is a pretty tall tire for the front (with a 10.5 +15 wheel that is). Shown below are 285/30/18 tires (all around), which are 1.6" shorter than your 265/35/19.
Old Sep 10, 2010 | 09:58 AM
siberian57's Avatar
siberian57
Tires are 265/30/19 all around. I'm just not sure if I need to change the suspension in anyway just to run these, because if so it's just not worth it at this point. Not only that but I know 10.5's have run all around but the tires have been wider out back a lot of the time from what I've seen too so I don't know if that was done for a reason of if this really isn't a great idea.
Old Sep 10, 2010 | 10:02 AM
siberian57's Avatar
siberian57
I did a quick search last night and I found a little about 10.5's all around but I didn't find much about needing to change suspension (because I'm completley stock suspension) or if wider tires out back was a smart idea. I had to leave for work but once I get back I'll do some more research.
Old Sep 10, 2010 | 05:03 PM
It has never been done before in the course of human history.
Old Nov 5, 2010 | 03:15 PM
Z33_kid's Avatar
Z33_kid
if i was you id keep it 19x10 .5 will probably rub im using a 19x10 up front
Old Nov 5, 2010 | 04:55 PM
stinky350z's Avatar
stinky350z
maybe 255-35-19 for the front? goodluck
Old Nov 8, 2010 | 07:09 AM
GenX350z's Avatar
GenX350z
Im riding 18x11 in the front witha slight stretch and i have no problems at all.
Old Jan 12, 2011 | 10:02 PM
How did 19x10.5 all around work out?
Old Jan 30, 2011 | 11:10 AM
Nothing happening here folks. Move along.
Old Feb 5, 2011 | 06:25 PM
StreetGeeks's Avatar
StreetGeeks
Hey scotts300 what exactly are you running with those set of wheels? Are you running a camber kit or just straight up the tires? What kind of suspension are you using because I am lowered on coilovers and was jus wondering if I can run 10.5x25 without a problem and not needed to get a front camber kit please let me know thanks
Old Feb 6, 2011 | 05:26 PM
scotts300's Avatar
scotts300
My mods are listed in my profile. When you lower a Z you should get the camber put back into spec. You want to run an 18 or 19 x 10.5 +25 wheel? What size tires? It can be done.
Old Sep 15, 2011 | 02:58 PM
JeffJohnries's Avatar
JeffJohnries
Will a 19x10 +20 rub up front?
Old Sep 15, 2011 | 03:09 PM
jduet's Avatar
jduet
My set-up is 19x10.5" +18 up front and -2 rear. Tires are 255/35 and 265/30
Old Sep 15, 2011 | 03:43 PM
AdvanZ33's Avatar
AdvanZ33
No.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
