Incident that happened today....SLP?
Old Sep 15, 2010 | 01:00 PM
cityslick43's Avatar
cityslick43
Default Incident that happened today....SLP?
Hello everyone, I was driving my automatic 350z today and then i was making a left turn and accelorated quickly, i totaly felt the car "drift" but wasnt making and noise with the tires.. it was kind of wet not very and then on my dashboard I saw "SLP" blinking... i put the car in neutral and accelerated thinking i just need to give gas any ideas what happened im kind of nervous to drive.. it has popped up about 4 times this week...
Old Sep 15, 2010 | 01:18 PM
DavesZ#3's Avatar
DavesZ#3
Turning, accelerating and wet - that the perfect formula for a disaster.
The Slip light comes on when the wheels slip. Try reading the owners manual for an explanation of that particular indicator.
If it happens in dry weather when you're not accelerating, then you might have the problem described here... https://my350z.com/forum/showthread....1&postcount=45
Otherwise, lay off the gas so much.
Old Sep 15, 2010 | 04:35 PM
cityslick43
Dave i preplaced my tires with 4 all season so idk if thats it but it was wet and i put a lot of gas is it anything to worry about with a lighter foot? I'm worried about winter but i plan on getting winter tires
Old Sep 15, 2010 | 05:22 PM
What size tires?
Old Sep 17, 2010 | 03:30 PM
Spike100's Avatar
Spike100
Some reasons you see the SLIP light:
  • Incorrect tire sizes (the basis for davidv’s question)
  • Excessively worn tires
  • Slippery roadways (meaning frozen roadways since good tires will hold on wet roadways)
  • New tire’s can be slippery until they are “scrubbed-in” (but this is more a problem with summer performance tires than all-season tires).
  • Excessive acceleration through turns (not something that should happen during normal street driving)
A very common reason for excessive TCS activation (you see the SLIP light) is incorrect tire sizes (the question davidv asks in Msg. #4 on your thread). David asks a very good question, especially in light of your recent tire replacement. So… I will repeat David’s question:
What size tires?
--Spike
Old Sep 18, 2010 | 06:43 AM
SQBassHead's Avatar
SQBassHead
spike and dave nailed it.... listen to them op, info don't come easier than that
Old Oct 21, 2010 | 10:32 AM
cityslick43
245/40r18
Old Oct 21, 2010 | 01:31 PM
terrasmak's Avatar
245/40r18
All 4 are the same size?
Old Oct 21, 2010 | 06:52 PM
omsin523's Avatar
omsin523
he's probably running the 245/40's all around if so, then that would cause that
Old Oct 22, 2010 | 05:46 PM
Spike100's Avatar
Spike100
Yes... 245/40-18" all around will cause the problem he describes. I've seen this firsthand.
What's interesting is 245/45-18" all around seems to work. I've run this setup without any problem on a VDC-equipped car.
--Spike
Old Oct 22, 2010 | 09:05 PM
245/40r18
This is a square set up? I do NOT see a problem with TCS.
Old Oct 23, 2010 | 03:09 PM
Spike100's Avatar
Spike100
^^ 245/40-18” is short for the rear tire. If you drive aggressively with a short rear tire you may see the SLIP light with a TCS-equipped Z. This is especially true on wet roadways (which cityslick43 mentions: ”it was kind of wet not very and then on my dashboard I saw "SLP" blinking...”)
--Spike
Old Oct 27, 2010 | 07:45 AM
cityslick43
Yes, I am running them on all four, Just bought some Contiwinter sport m3 winter tires all four winter tires for $240 they were 70% tread and made in 2005 so not that old of a tire.. otherwise I would have went wider but I couldnt pass up this deal being a college student and all. Thank you very much for input everyone I really appreciate it.
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
