First time wheel buyer
Old Dec 11, 2022 | 06:00 PM
Guzman427's Avatar
Guzman427
Default First time wheel buyer
So today I finally bought some new wheels and tires for my 2007 350z.
Went with a set of Avid1 AV6. Rocking a 18x9.5 on 235/40R18s on the front and a 18/10.5 on 275/35ZR18s
Today when I went to install them I ran into some fitment issues. This old on my break discs seem to be in the way. Wondering if this thing is needed or if people have had issues on the past getting wheels to fit with that bolt in the way. The stock wheels obviously fit fine, but I don’t see where it would be an issue on the newer wheels.
see photo for reference.
Old Dec 11, 2022 | 06:31 PM
travlee's Avatar
travlee
Master
That is there to keep idiots from putting the oem back wheels on the front. If I remember correctly, you can wedge a flat tip screwdriver under it while backing it out, or worst case cut it off
Old Dec 12, 2022 | 06:27 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Use a (12mm?13mm?) wrench and some WD40 on that threaded stub to remove it.
Old Dec 12, 2022 | 07:00 AM
Heel Til I Die's Avatar
Heel Til I Die
10mm should work.
https://my350z.com/forum/wheels-and-...nt-wheels.html
https://my350z.com/forum/wheels-and-...-6th-stud.html
Old Dec 12, 2022 | 10:17 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
What is a concern leads to my asking "who recommended those tire sizes?"
A 235/40 front is 0.47" shorter than stock and the rear 275/35 is 1.1" shorter.
It'll work but will throw off speedo (not a big deal) but creates a large amount of wheel gap as well.
Also (and this is key), if you have VDC, you'll likely run into slip errors given that the ECM is looking for a 3% (+/- 0.25%) delta in F-R tire sizes and the delta is much less than that with these sizes. (If no VDC, not too big of a deal.)
Old Dec 12, 2022 | 10:23 AM
iideadeyeii's Avatar
iideadeyeii
255/40/18 x 275/40/18 would of made everything even.
Went up an inch and a half wheel diameter to add 10mm of tires in the front
Old Dec 12, 2022 | 03:47 PM
MicVelo's Avatar
This^^ Most common setup for upsized (width) 18s. (Or 245/40 front)
Old Dec 15, 2022 | 12:00 PM
terrasmak's Avatar
Originally Posted by MicVelo
This^^ Most common setup for upsized (width) 18s. (Or 245/45 front)
correction, 245/40-18 front
Old Dec 15, 2022 | 03:19 PM
MicVelo's Avatar
Age mistake. Corrected! Thanks Len!
Old Dec 16, 2022 | 05:02 AM
Heel Til I Die
Lock it up, old man river.
Deedilus
Jun 3, 2024 05:09 AM
Cmull96
Aug 31, 2016 10:53 AM
antonb1985
Aug 15, 2009 08:46 AM
gcoupeturbo
Jul 13, 2007 04:22 PM
zachcrosen
Feb 12, 2006 09:51 AM
