Another Powerlabs DIY and picture diary
Old Sep 21, 2009 | 06:58 PM
idanielsan's Avatar
idanielsan
Default Another Powerlabs DIY and picture diary
Here is another DIY 350z post for the powerlabs kit. I am getting all the down so I can get my thoughts together and ask for help too.
its a 2004 base silverstone, with the only previous mods being and LSD, Motordyne 5/16 spacer, and floormats.
Using these threads for reference:
https://my350z.com/forum/forced-indu...o-install.html
https://my350z.com/forum/forced-indu...-complete.html
https://my350z.com/forum/forced-indu...b-install.html
I'm going to post as many pictures as will be allowed to keep my mind organized.
It seems like the best way to do it is in sections. So far this is where I am at:
Most of the kit. Stupid rat wouldnt get out of the way
Last edited by idanielsan; Oct 17, 2009 at 04:20 PM. Reason: updated links for everything posted
Old Sep 21, 2009 | 07:10 PM
idanielsan's Avatar
idanielsan
Default Winshield Washer Reservoir
This is the windshield reservoir, it took me forever to remove these 2 bolts
Old Sep 21, 2009 | 07:22 PM
idanielsan's Avatar
idanielsan
Default Coolant Reservoir replacement
I didnt see any pictures or instructions about where or how to place this, so I called and talked to Han at Intense Power, he gave me the above ideas. I would have never figured this out. The L Brackets are oriented just in a way that its tight but it works.
Old Sep 21, 2009 | 07:34 PM
idanielsan's Avatar
idanielsan
Default Stock Exhaust removal
Adding AAM 3 inch exhaust
Getting these out were a pain due to the piping in the way
Getting the exhaust out alone can be a pain, I finally just pull the hanging bracket off its rubber grommet by force and let the exhaust fall to the concrete.
After getting the exhaust in I decided to do the "bumper tuck"
Not sure if I like the sag, but it looks way better than the open spot on the passenger side with no exhaust there
Old Sep 21, 2009 | 07:39 PM
ttuberz's Avatar
ttuberz
subsribed. good luck
Old Sep 21, 2009 | 07:45 PM
idanielsan's Avatar
idanielsan
Default Cat Removal
Using the extension trick from the Jeffie7 (sp?) thread was a great idea
Getting to the back end of it was awkward, so I used the FSM method and it actually worked. Glad the bolts werent totally siezed up.
Had to prop up the whole assembly to take it out without it landing on me
left over stock pieces
Old Sep 21, 2009 | 07:57 PM
idanielsan's Avatar
idanielsan
Default Exhaust Wrapping
my first wrap, Zip ties are just until it dries. I will be putting the alum wraps on there after.
Letting the pieces dry before applying the silicone spray
Completely forgot about the up pipe, had to go back and wrap this one later.
After spraying with the silicone spray.
Old Sep 21, 2009 | 08:14 PM
jeffie7's Avatar
jeffie7
Tape FTW! =)
Having the right tools + tape sure does make the job easier!
Old Sep 21, 2009 | 09:11 PM
SlideFox's Avatar
SlideFox
Awesome!!!
Old Sep 22, 2009 | 01:36 PM
sublimemoment's Avatar
sublimemoment
Subscribed.
Old Sep 22, 2009 | 02:42 PM
chinabean's Avatar
chinabean
sweet, i like where this thread is going
Old Sep 22, 2009 | 02:51 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
WOW, great work so far!
Nice job wrapping the piping sir!
Subscribed!
Old Sep 22, 2009 | 02:53 PM
ATX350's Avatar
ATX350
Good luck with the build bro! Call/pm if you have any questions. Just got done with this install about 2 months ago. That AAM exhaust is a beast but beware MUCH louder than stock.
www.youtube.com/txrado
Old Sep 22, 2009 | 03:31 PM
gotagetmyZ's Avatar
gotagetmyZ
Good Luck with the build man. So far everything looks really good.
Old Sep 22, 2009 | 03:37 PM
ATX350's Avatar
ATX350
^GTFO David :P
Old Sep 22, 2009 | 03:41 PM
cdoxp800's Avatar
cdoxp800
Looking good so far. Keep the photos coming
Old Sep 22, 2009 | 03:43 PM
Ghost_shift's Avatar
Ghost_shift
Good Job!!!
Old Sep 22, 2009 | 05:23 PM
idanielsan's Avatar
idanielsan
Here goes the second round of pics. If anyone sees anything off or could put in a good comment please post! Alot of this is a first for me.
Old Sep 22, 2009 | 05:42 PM
idanielsan's Avatar
idanielsan
Default Mid pipe, Crossover pipe
Mid pipe in place with Vband clamp
Driver side view
Passenger side view
bigger view, Not sure what is the best place to route the o2 lines yet.
will be referring to Jeffie7's thread
Was able to get the Up pipe into place without removing the sway bar
With the heat wrap on there its REALLY close to the AC compressor. Its loose fitted right now, so hopefully Ill be able to adjust once the turbo is in
Old Sep 22, 2009 | 05:51 PM
2k6-z33's Avatar
2k6-z33
Subscribed
