AVIC-D3 Install Guide
Old Feb 13, 2008 | 03:32 PM
  #101
dhwang80's Avatar
dhwang80
quick question about the successful bypass in our cars.
So we pull up on the tab on the RCA harness to pull out the yellow/black mute wire. then reinsert the mute wire into the top space above it (still yellow on top and black on bottom I assume).
Then reinsert the RCA harness back into the headunit. Then what are we supposed to do? Are we supposed to ground the other end of that yellow/black mute wire to some steel part? What about the parking brake wire?
i want to try and do the bypass myself, but I have zero electrical experience and any help in this endeavor would be greatly appreciated!
the info on avic411.com seems pretty self-explanatory. Just a couple of questions about that mute wire and parking brake wire grounding thing.
Old Feb 13, 2008 | 10:13 PM
  #102
TayTaythatsme04's Avatar
TayTaythatsme04
ok guys need some help.
Did the install and the unit is powered up and working, but my amp is not powering on which powers my sub and when I put the car in reverse the rear view camera doesn't come up.
Any Help??
T
Old Feb 14, 2008 | 05:33 AM
  #103
clarkemtp's Avatar
clarkemtp
Yes and yes. Good Luck.
Old Feb 14, 2008 | 05:35 AM
  #104
clarkemtp's Avatar
clarkemtp
Any Help??
T
Well, you need to start your troubleshooting by ensuring:
1) The remote amp turn-on lead connection is connected. lol (And solid)
2) The reverse-sensing lead is hooked up so the AVIC-D3 knows you've shifted to reverse. (Assuming your camera is hooked up correctly?)
Let us know.
Old Feb 14, 2008 | 12:06 PM
  #105
6894kevin's Avatar
6894kevin
Question
I have been thinking about getting this unit but i want to get an idea of everything i need.
I know the HU (duh), the Metra 70-7550 harness, i-pod wires, where do i get the trim piece? Is that all I need?? and where can i get all of this??
Also I want to keep my wheel controls so how do i do that and what will i need?
O.. and one last thing can i play my I-pod and load Nav information at the same time or does everything come to a hault to use the Nav?
Thanks for the help guy's
Cheers
Kevin
Old Feb 14, 2008 | 12:26 PM
  #106
deviljon's Avatar
deviljon
you can buy your stuff from a number of places... sonicelectronix.com, amazon.com, ebay, circuity city, best buy, etc...
i purchased my d3 off amazon for $615 shipped, bought the ipod adapter for ~$35 shipped, picked up the wiring harness from circuit city, and bought the dash kit off crutchfield.com
the total came out to be around $700 for everything.
to keep your steering wheel controls i believe you need to buy an adapter from pac-audio.com.
as for your ipod, you can do everything with the navi while the ipod is playing in the background. you also have the option of muting the background when the navi voice plays or just simply having the voice speak over the music.
hope that helps!
Old Feb 14, 2008 | 12:45 PM
  #107
6894kevin's Avatar
6894kevin
Thanks man that helps alot! I'm planning on just leaving the Nav CD in the unit and only useing my i-pod.
Old Feb 14, 2008 | 12:48 PM
  #108
deviljon's Avatar
deviljon
thats EXACTLY what i do. you never have to worry about scratching/skipping cds again and you can have all your mp3s to choose from. AND you don't have to play with your ipod while driving, just use the d3's ipod interface. i dont think i could ever go back to cd's!
Old Feb 14, 2008 | 04:35 PM
  #109
TayTaythatsme04
Let us know.
I will double check tonight but Im pretty sure I have the amp turn on connected correctly and for the reverse camera I went off the DIY in the Audio section to locate the reverse wire. It is green and white correct??
Thanks
T
Old Feb 15, 2008 | 09:35 AM
  #110
TayTaythatsme04
anybody know which wire is the reverse signal wire that runs to the back of the car.
I checked https://my350z.com/forum/audio-video-and-electronics-diy/273813-diy-rear-view-camera-install.html but that wire that is talked about in this thread doesn't seem to work on my 04'
Any ideas??
Thanks
T
Old Feb 15, 2008 | 12:56 PM
  #111
dirtmcgurt's Avatar
dirtmcgurt
Man I had my d3 installed by a "professional" yesterday. It looks perfect but the sound just isn't loud. I think I will actually have to get the damn OHm leveler talked about earlier.
Old Feb 15, 2008 | 03:14 PM
  #112
clarkemtp's Avatar
clarkemtp
Not to "preach" but I try to tell you guys. So, is it easier to do it over or to have just done it right? Hey, on the bright side, live and learn.
Good Luck.
Ask questions.
Oh, and if someone answers, use the info.
Old Feb 15, 2008 | 03:22 PM
  #113
deviljon's Avatar
deviljon
get the pac-audio adapter. TRUST ME. if you're going to do it, do it right. don't go cheap! listen to clark!
Old Feb 19, 2008 | 11:24 AM
  #114
ak350enthus's Avatar
ak350enthus
I recently had an Avic-D3 installed but for some reason the radio only seems to work right in the middle of the city but when I get away from the area, the signal fades and I pick up 0 stations. My stock headunit had no trouble with any stations anywhere. (Any ideas?) Also, I was able to pair my cell up with the D3, but when I make calls neither I nor the caller can hear each other.....any ideas on this?
Old Feb 19, 2008 | 12:13 PM
  #115
clarkemtp's Avatar
clarkemtp
Yeah, you don't have your stock antenna module getting any power with your new wiring. Guaranteed. In the new harness, even though we don't have a power antenna, you still need to ensure you connect the "power antenna" lead to switched +12v. Otherwise, or antenna amp doesn't get juices and we don't get (many) signals. lol
Old Feb 19, 2008 | 12:15 PM
  #116
ak350enthus
Wait, where should the power antenna lead be connected to?
Old Feb 20, 2008 | 05:25 AM
  #117
clarkemtp's Avatar
clarkemtp
On the D3 side of the harness there should be a blue lead labeled: "Antenna Control". On the Nissan-adapter side of the harness there should be a solid blue power antenna lead.
Strip. Twist. Solder them together. Shrink wrap the connection when you're done.
Old Feb 20, 2008 | 11:17 AM
  #118
ak350enthus
So you need to sodder wires even with the easy wire harness's?
Old Feb 20, 2008 | 03:36 PM
  #119
CobraZ's Avatar
CobraZ
So I installed my d3 today and when i was finished my gas gauge isnt working. It says I am out of gas, and the service engine light is on. Eveything else is working fine. I didnt run anything on that side of the dash??
Any ideas?
Old Feb 20, 2008 | 06:18 PM
  #120
dirtmcgurt's Avatar
dirtmcgurt
Disconnect the battery and plug back in. Once its disconnected wait like 5 min before reconnecting. That took my engine light off. As for the gas gauge make sure everything is plugged in. I accidently unplugged my three little oil, batter, and info center thing and that fixed it.
