Which sub? instead of bose
Currently the dumbass who had the car before me has a 8" sub that does not work and a 150 watt amp that needs replacing he really got screwed on the deal. Here is a list of subs that i found on crutchfield anyone recommend a good one?
pioneer ts-w258d4
kicker compvr 07cvr102
kicker compvt 07cvt102 shallow mount
jbl power series p1024
pioneer ts-w258d4
www.sonicelectronix.com is where i get my stuff. since crutchfield is overpriced
what's your budget btw?
So it's in the bloze hole? No wonder. 99% of sub-woofers are not meant to be mounted in free space but rather in a sealed box of a given volume. Mounting a sealed box subwoofer in free space is a sure fire method of getting distorted and sloppy base.
Put a sub into an enclosure. There are no free air subs worth a crap. Depending on what you want out of the sub, whether your focus is on SQ or SPL, as well as your budget, that's going to give people a better idea of what to recommend.
spl budget around 300 want it to be clean and dont wanna add anything to trunk.
If you don't want to put an enclosure in the hatch, then you will need to get a custom enclosure built for where you want to place your sub and you might not necessarily get enough airspace to drive them. Not to mention, it'll probably end up costing more.
going to cost you more than $300 to have the sub sit in the OEM Bose location and for it to sound good. i know people on here have dynamatted the stock sub location and had decent results. do a search.
m_0g
Jun 3, 2021 10:05 AM
