My $100 like OEM fit NAVIGATION setup
Old Aug 26, 2009 | 07:13 AM
  #41
o2sys's Avatar
o2sys
Originally Posted by kris c
Does the GPS face down, when placed?
How does the GPS stay forward instead of moving back and forth because there's a room behind the GPS when placed.
its secured with 3M tape.
Old Aug 26, 2009 | 07:26 AM
  #42
knils's Avatar
knils
Originally Posted by burner
There is guy on eBay selling these right now, he has several for $89.
They are used and open customer returns
Old Aug 26, 2009 | 07:56 AM
  #43
burner's Avatar
burner
If you want to pay double to get a new one, by all means. And, for $89, what do you expect?
Old Aug 26, 2009 | 09:22 AM
  #44
o2sys's Avatar
o2sys
i paid $89 for mine, looked new, all in original packaging, works fine. No other PNA is that cheap regardless of it being refurb or not.
Old Aug 26, 2009 | 04:52 PM
  #45
mw9's Avatar
mw9
How did you wire the power. Is it hard wired in?
Old Aug 26, 2009 | 06:45 PM
  #46
o2sys's Avatar
o2sys
you need fuse the 12V. You can either buy an extra cigarette adaptor or hard wire it with an in-line fuse.
Old Aug 26, 2009 | 07:40 PM
  #47
Spike100's Avatar
Spike100
^^ I would suggest that you should keep the device’s low voltage in-line adapter in place, and plug this into a power receptacle (the “cigarette adapter” you mention).
Doing this is wise since the device may not be exactly 12v. If the device is 6v to 10v (and that is likely), it needs its step-down adapter for safe operation.
--Spike
Old Aug 26, 2009 | 09:23 PM
  #48
o2sys's Avatar
o2sys
i bought an extra cigarette adapter. I wire it along with my radio and just plugged in my Plenio's charger to the new cigarette adapter. So it turns on and off with the car.
Old Aug 26, 2009 | 09:59 PM
  #49
Asian Invasian's Avatar
Asian Invasian
Can you post a link of the extra wires and stuff you bought to hardwire this up? I just ordered one of these and would like some help installing it if you don't mind telling me how you hardwired it (im a noobie at this stuff).
Old Aug 27, 2009 | 02:54 AM
  #50
mw9's Avatar
mw9
Well, I just bought one. Stay tuned for updates. Maybe we can keep this thread going with updates from everyone who bought one.
Old Aug 27, 2009 | 06:04 AM
  #51
o2sys's Avatar
o2sys
You need buy something like this:
http://www.dcpwr.com/shop/images/Cig%20Adapter-F.jpg
Then you need to find any 12V and a ground near where you want to hide the adaptor in the picture above.
Then plug in the a/c adapter that came with your Plenio.
Old Aug 27, 2009 | 03:47 PM
  #52
Asian Invasian
So just so I know I am reading this right here is what I need to do:
- buy that adapter
- Take apart center consol
- splice my chord going to my 12v outlet and connect it with the adapter I need to buy
- run the normal plenio chord down through my center console and plug it into this adapter
Old Aug 27, 2009 | 04:33 PM
  #53
mw9's Avatar
mw9
Can you tell us what version of iGo8 you have and what torrent site. Thanks again for all the help, mine should be here on Monday.
Old Aug 28, 2009 | 10:14 AM
  #54
burner's Avatar
burner
I ordered one too...I am going to post a full DIY when I get mine in with the install to help out. I should be getting it in on Tuesday.
Old Aug 28, 2009 | 11:02 AM
  #55
o2sys's Avatar
o2sys
i got the torrent from www.demonoid.com but currently the registration is closed.
Old Aug 28, 2009 | 11:03 AM
  #56
o2sys's Avatar
o2sys
- buy that adapter
yes that is correct. But i think if you connect to a constant 12V, the plenio will not shut off unless you unplug the cigarette adapter. Find a ACC 12V source.
I will try to post better pix this weekend.
Old Aug 28, 2009 | 12:37 PM
  #57
Asian Invasian
which source did you use? and thanks for all your help man.
Old Aug 28, 2009 | 05:40 PM
  #58
nismo_nate's Avatar
nismo_nate
yay i just got the navi in the mail!
there isn't any play with the navi mounted in the cubby, it fits pretty snug.
question for the op, how did you wire the navi. what did you use for power and how did you turn on the navi once its mounted?
thanks
Old Aug 28, 2009 | 06:34 PM
  #59
o2sys's Avatar
o2sys
just plug it in you ac plug outlet. Leave the switch to on position and it will just turn on and off with the car...
For a more stealth look, purchase a new ac plug and hid it under the dash!
Old Aug 28, 2009 | 07:52 PM
  #60
burner's Avatar
burner
As for power: the best way to route power for this would be to tap into your cig lighter wires. Pop out the plug and get some wire taps, red is positive and black is ground. You'll probably have to run some new wire. As the OP said, it will power on and off with the car. Another option is to tap into the ACC line on the back of the radio and ground the other wire.
I just wired up my own fuse box system in my car, which allows me to tap into power for any new accessories. You can check out the thread here: https://my350z.com/forum/audio-and-v...-my-setup.html if you are interested.
