My $100 like OEM fit NAVIGATION setup
Old Sep 23, 2009 | 03:15 PM
  #201
striker27's Avatar
striker27
Can I use another External GPS antenna?????
I have found one but it comes with out the GPS antenna
Old Sep 23, 2009 | 04:37 PM
  #202
JasonZ-YA's Avatar
JasonZ-YA
^ someone post the antenna connection? could possibly use another if the connections are identical maybe? no way of knowing till you try it..
-j
Old Sep 23, 2009 | 07:37 PM
  #203
striker27's Avatar
striker27
I wish it did not use such a fluky connector to hook up the GPS.. I think I am out of luck making mine work!!!
DAMN!!
Old Sep 23, 2009 | 07:38 PM
  #204
JasonZ-YA's Avatar
JasonZ-YA
boo....contact the manufacture and see if you can order parts???
Old Sep 23, 2009 | 11:11 PM
  #205
striker27's Avatar
striker27
Cannot seem to find the manufactures site... Looks like the number is no longer in service as well!!! Hmmmm. Any help guys????
Old Sep 23, 2009 | 11:34 PM
  #206
quakerroatmeal's Avatar
quakerroatmeal
Mines came in yesterday...
I need to find a memory card reader so I can update and change the software on it.
Thing looks BRAND new still and untouch. Turns on and works flawlessly.
Old Sep 24, 2009 | 03:26 AM
  #207
JasonZ-YA's Avatar
JasonZ-YA
^ i have an SD card reader...
-J
Old Sep 24, 2009 | 06:06 AM
  #208
o2sys's Avatar
o2sys
Their site was up until couple months ago, seems to have gone down. You can still email them i think.
Old Sep 24, 2009 | 07:51 AM
  #209
striker27's Avatar
striker27
Do you have an email address for them????
Thanks!!!
Old Sep 24, 2009 | 10:12 AM
  #210
o2sys's Avatar
o2sys
You can't use another antenna. The reason is the connection between the GPS to the unit is a special connector (looks like the S-Video kind).
I dont have their email at the moment, have to search around.
Old Sep 24, 2009 | 11:20 AM
  #211
o2sys's Avatar
o2sys
+1
__________________
Also, in my OCN8 folder, I have other things in there that weren't in the pdf file's step #5 ("tts_loq", "LoqEnglish6.9.dll", "LoqGerman6.5.dll", "loqmsx.dll", "LoqTTS6.dll", and "LoqTTS6_util.dll"). I don't seem to have Lang_English-us.zip there either, but I did find that file in \content\lang. So, do I follow the pdf file exactly and delete the extra files I have and add the English file to the root?
__________________
In the pdf file step #6, it talks about the "content" folder. Am I correct in assuming that in each of the 6 folders (building, lang, map, poi, speedcam, and voice) I only need the file with the necessary state and not every single file? I ask because I see that the entire OCN8 folder is 1.4GB as I obtained it and the memory card only has a 1GB capacity.
1. You can delete all the TTS files if you want too. Are these in your "tts_loq" folder? They are Text-to-Speech files but my OCN8 doesn't have this. I was under the impression that OCN8 doesn't have TTS and only iGo8 does but again you can't run iGo8 on the Plenio anyways.
The language file must stay in the content folder sub folder lang. You can delete all other languages you dont understand.
2. Under the content folder you can only run the states you want to bring down the file size. For example I have all the states in the "map" folder but for "POI" I only have the tri-state area. Same goes for buildings, speedcams, and etc. BTW i have a 2GB card which is recommended to run OCN8
All zip files must remain compressed
Old Sep 24, 2009 | 11:28 AM
  #212
quakerroatmeal
The link in the pdf for the os update to v1.62 is broken can someone send me the updated os or link me somewhere that would have it?
  #213
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Sweet, that's what I figured. Even if I don't install this soon, I'm still going to mess with it when it comes in. I'll update with any issues, should there be any.
Old Sep 24, 2009 | 11:30 AM
  #214
quakerroatmeal
Nevermind re-read that you did not need to upgrade os.
Old Sep 24, 2009 | 01:09 PM
  #215
striker27's Avatar
striker27
Company appears to be folded up. No website or contact info around. Anyone want the screen I do not have a power adapter or gps unit for it.. Was a waste for me I guess.
Old Sep 24, 2009 | 01:21 PM
  #216
o2sys's Avatar
o2sys
Stricker sent PM
Old Sep 25, 2009 | 10:55 AM
  #217
quakerroatmeal
Almost done installing OCN8...hoping it works first try this usb sd memory card reader I have only transfer at 905kb/s...ouch
Old Sep 25, 2009 | 10:57 AM
  #218
jtabraham's Avatar
jtabraham
transferring everything to my SD card was the slowest part of the whole process!
Once you start the software, don't forget to go into the OCN8 settings to enable the GPS...I did NOT, and thought I had a bad receiver.
Old Sep 25, 2009 | 11:02 AM
  #219
quakerroatmeal
Thanks for the heads up.. I really did not know transferring would be this slow. It's slower then USB1.1. 30minutes to transfer 1gig is ridiculous.
But I'm pretty excited now after this I need to either find an 03 cubby hole or just install it into my 04 until I find an 03 in the feature.
Old Sep 25, 2009 | 12:24 PM
  #220
quakerroatmeal
Of course ran into a problem.
I double checked and of course I do not have this file in that folder. Can anybody send it to me please?
Thanks
