DIY: 06+ Base with Cruise Control using Uprev + OEM Parts
Old Feb 4, 2013 | 06:35 AM
  #161
e30cabrio's Avatar
e30cabrio
Originally Posted by seymore4
You could also use Uprev to disable NATs, but either way you're out a couple hundred bucks
If he has UPREV he does not need the new ecu.
Old Feb 4, 2013 | 06:43 AM
  #162
seymore4's Avatar
seymore4
Professional
That's why I said "either way"... there were two options presented, both require either Uprev or a dealer reprogram for NATS
Old Feb 4, 2013 | 07:26 AM
  #163
e30cabrio's Avatar
e30cabrio
Right but the point of his question was to avoid UPREV
Old Feb 4, 2013 | 09:34 PM
  #164
LB350z07's Avatar
LB350z07
subscribesd
Old Feb 5, 2013 | 09:45 PM
  #165
Depravity's Avatar
Depravity
I cannot for the love of God align my steering wheel properly because it won't lock. It's to the point where I can completely remove the wheel in about 5 seconds because i've done this about 1000 times lol
Old Mar 7, 2013 | 12:20 PM
  #166
GreyZ's Avatar
GreyZ
Sub'd, about to attempt this on my 03!
Old Mar 8, 2013 | 08:53 AM
  #167
bigchieftaco's Avatar
bigchieftaco
Will this method only work with 06 and up? I have an 05 base I'd love to try it on.
Old Mar 8, 2013 | 08:55 AM
  #168
The_Laughing_Man's Avatar
The_Laughing_Man
Come on, man. Dont just skip to the last page. My Z is a 2005 base and it now has cruise control. Yes, it will work.
Old Mar 12, 2013 | 12:08 PM
  #169
bigchieftaco
Thanks for the reply. This will be my first project with the Z
P.S. Take your own advice man, don't be a douche bag. I didn't have time to sift threw all the posts when I posted that.
Old Mar 14, 2013 | 08:12 AM
  #170
The_Laughing_Man
And that's exactly why we have the same things posted and asked over and over around here. Wait to ask your question until after you've made time to read this thread. Simple as that.
Old Mar 31, 2013 | 05:53 PM
  #171
Depravity's Avatar
Depravity
For those of you who installed the steering wheel controls on both sides, would you please post up a picture? My left panel doesn't sit flush with the airbag, so I tried fiddling around with it but..no success
My OCD with my Z is driving me nuts
Here's what i'm talking about
Old Apr 2, 2013 | 02:42 AM
  #172
ian99rt's Avatar
ian99rt
I had a similar situation. Did my best by losening all the screws and shifting around but could not get them symmetric.
Old Apr 2, 2013 | 10:53 PM
  #173
Depravity's Avatar
Depravity
Looks like we're screwed! Does it bother you much, or not really?
Old Apr 3, 2013 | 09:07 AM
  #174
The_Laughing_Man
Mine is like that as well. I just try to ignore it.
Old Apr 4, 2013 | 01:08 AM
  #175
Depravity's Avatar
Depravity
I've tried adjusting it, but hmm..there's gotta be a way to close that gap somehow
Old Apr 4, 2013 | 06:08 AM
  #176
ian99rt's Avatar
ian99rt
Having my z of 2 years now I've come to terms with their garbage interiors. I pretty much see my car as a really fun to drive tub that is still street legal. Wife hates it but when you have a pretty no compromise approac to chassis and suspension mods no regular driver will like it.
Old Apr 4, 2013 | 04:52 PM
  #177
Depravity's Avatar
Depravity
That's an interesting approach. This is going to sound sad, but my last car was a Hyundai Tiburon. Talk about a cheap korean plastic interior..lol
The Z interior feels so luxurious compared to that piece of junk
Old Apr 9, 2013 | 08:00 AM
  #178
jes1888's Avatar
jes1888
hi guys, i have a 06 base model with 6MT I would like to implement cruise control in my car, for the cruise option but more importantly for the map switching for the osiris, i havent bought anything yet, i saw in the 1st posts the switches needed for the clutch/brake pedals and the plugs for them, but on the steering wheel side, does it also contains the plugs for the cruise and audio switches so technically, its like plug and play, no hard wiring at all?
Also what about the light on the cluster? It does has the graphic of the cruise control options but there is no led soldered behind it right?
Please let me know and thanks in advance!
Old Apr 9, 2013 | 08:05 AM
  #179
e30cabrio's Avatar
e30cabrio
The wire harness is on the steering wheel for both controls. With nothing but the CC switches you can switch maps the cluster in my car did not work with the leds soldered in. I had to get a cluster from a model that had it.
Old Apr 9, 2013 | 08:07 AM
  #180
ian99rt's Avatar
ian99rt
All physical hardware is plug and play. To get the cruise control light you have to swap clusters with a cruise enabled car's cluster. The gauges clusters microcontroller are flashed with a different ROM depending on model. If switching you need to cover / removrd the tcs led as it will light up.
