New NASA Class for 2012: Spec Z
Old Jan 14, 2013 | 05:59 PM
  #1161
Palmettogasman's Avatar
Palmettogasman
Thanks for the info Laze. I've been running 38 psi hot so I'll try the higher pressure. Checking ride height this weekend; installing brake ducts and the longer ARP studs up front due to the massive spacers needed for the RPF 1's. Should be interesting...
Old Jan 15, 2013 | 01:50 AM
  #1162
laze1's Avatar
laze1
review this Tuning Guide from BFG
http://www.tirerack.com/images/tires...ce_R1_care.pdf
Old Jan 15, 2013 | 01:57 AM
  #1163
laze1's Avatar
laze1
Also, I have been informed that the new 2013 Spec Z rules will be out soon and they will include provisions for brake ducts...and with a defined air intake hole that can be cut into the bumper...so you might wait a week on the brake ducting or install it today with the option of changing it soon
But we will not know for sure until the rules are published!!!!
Old Jan 15, 2013 | 06:44 PM
  #1164
laze1's Avatar
laze1
EXCELLENT DEAL ON SPEC Z WHEELS
http://www.nasaforums.com/viewtopic.php?f=90&t=99797
Old Jan 16, 2013 | 08:55 AM
  #1165
KNS Brakes's Avatar
KNS Brakes
Vendor - Former Vendor
Just wanted to drop in a little reminder, we know the season is going to be starting up quickly soon, and everyone will be preparing. But I just wanted to remind everyone that that we will be doing wholesale discounts for those who are running Spec Z, feel free to shoot us a PM or email at sales@knsbrakes.com
-Nick
Old Jan 16, 2013 | 09:51 AM
  #1166
laze1's Avatar
laze1
Nick, If you want to come to a NASA-SE event I will be happy to help you Organize a demo/sales area and maybe host a technical seminar...u can give away some Hats/Tees...get some "mind share" with the NASA-SE crowd. Maybe Sponser a Spec Z race and give away a $100 Coupon to the Spec Z winner or something...
Road Atlanta always has the best attendence on the schedule...with spring and fall events being highest.
Lemme know if this makes sense for you.
Old Jan 16, 2013 | 10:01 AM
  #1167
mhoward1's Avatar
mhoward1
John,
Ken and Nick are right by me, and they can be at CMP many times. I can vouch for their service.
Old Jan 16, 2013 | 01:02 PM
  #1168
laze1's Avatar
laze1
Cool! As you can see I am attempting to get Sponsers involved in Spec Z...I have some other things I am working on..like a "East Coast" National Spec Z weekend @ Road Atlanta in September for those not going to F-ing Utah...more to follow
Old Jan 16, 2013 | 01:26 PM
  #1169
KNS Brakes's Avatar
KNS Brakes
We have been trying to work w/ Jeremy from National but nothing has happened yet.
Old Jan 16, 2013 | 01:29 PM
  #1170
laze1's Avatar
laze1
Understood...I can tell you NASA-SE is happy to do something that is on the appropriate scale...I will be in touch.
I find it amazing what a couple hats/tees give aways and FLAG GIRLS will do
Old Jan 16, 2013 | 01:38 PM
  #1171
KNS Brakes's Avatar
KNS Brakes
I still know some college girls that I'm sure will be some flag girls
-Nick
Old Jan 16, 2013 | 01:41 PM
  #1172
laze1's Avatar
laze1
Excellent! We are gonna get along very well!
-Nick
Old Jan 16, 2013 | 02:00 PM
  #1173
mhoward1's Avatar
mhoward1
-Nick
Hey wait...that was never offered to us!!
Old Jan 16, 2013 | 05:13 PM
  #1174
laze1's Avatar
laze1
you never asked...
Old Jan 17, 2013 | 07:30 AM
  #1175
scotts300's Avatar
scotts300
Originally Posted by laze1
you never asked...
Man, you guys get it all. We don't even get trophies.
Old Jan 29, 2013 | 06:29 AM
  #1176
laze1's Avatar
laze1
2013 Spec Z rules posted
http://nasaproracing.com/rules
Old Jan 29, 2013 | 06:39 AM
  #1177
laze1's Avatar
laze1
17 Brake System
17.1 Brake System
a) Brake pads are unrestricted.
b) Brake rotors must be the same type, material, and dimensions as OEM. Brake rotors from
alternate companies may be used. Brake rotors may be cryogenically treated.
c) Steel braided brake lines may be used.
d) Disc brake backing plates may be removed.
e) The emergency brake level and/or cables and associated must remain functional.
f) Anti-lock braking systems (ABS) may be disabled.
g) Manual brake bias valve is permitted only in the event that ABS system is disabled. The valve
must not be driver adjustable during competition.
h) Nissan Motorsports front brake duct cooling kit part #99996-Z3350 may be utilized.
i) Two holes, no larger than 3.5”x5.75” or 2.53” in diameter may be cut in the front bumper cover for
the sole purpose of
Old Jan 29, 2013 | 06:41 AM
  #1178
laze1's Avatar
laze1
Year Make Model Motor Note Weight (lb)
03-04 Nissan 350Z VQ35DE Engine must be intake only variable
timing controlled 3175 lbs
05-06 Nissan 350Z VQ35DE Engine must be intake and exhaust
variable timing controlled 3250lbs
07-08 Nissan 350Z VQ35HR Any dual Throttle Body engine’ed
car must run as 07-08 3400 lbs
  #1179
laze1's Avatar
laze1
13.3 Differential
a) OEM Open and viscous differentials may be replaced with either Nissan Motorsports unit, 38420-
SS370 or 38420-RS141. Refer to Appendix A for recommended Nissan Parts. Axle stub part
number 38220-AR011 must be used on right and left side of differential with either Nissan
Motorsports unit. If either optional differential unit is used, Motul Competition 75-140 (101161) is the
only recommended fluid for use in the rear end per the manufacturer.
b) OEM final drive must be retained.
c) Differential cover may be replaced with Nissan Motorsports unit. Refer to Appendix A for
recommended Nissan Part.
d) Differential cooler may be added and utilized. Size and location is unrestricted.
Limited Slip Unit Spec
Wave Trac or NISMO (Must
use correct short stub axles
and Motul Fluid 101161)
38420-SS370 or
38420-RS141
Old Jan 29, 2013 | 10:33 AM
  #1180
scotts300's Avatar
scotts300
Thanks for sharing. I guess I'll need to add some weight now!
17 Brake System
the sole purpose of[/I][/B]
3.5 x 5.75" = 20sq in
2.53" dia = 5sq in
13.3 Differential
38420-SS370 or
38420-RS141
Grrrrrrrrrrrrrrrrrrrrrr. This is going to cost me. $%^*@#$*@#
