ST/SU Build
Old Jan 6, 2016 | 12:31 PM
  #161
Dblock55's Avatar
Dblock55
Originally Posted by rustyschopshop
I apologize then, I thought it was sheet metal that you had used. 1/8" plate is plenty thick. Picture was apparently deceiving. How is the rest of the cooling system working out for you?
Yea, sheet would definitely bulge. 1/8 is probably as thin as you'd want to go. I used blockoff caps for the rest of the "open" nipples. Havent fired it up yet so ill let you know when I overheat my car
Old Jan 6, 2016 | 01:57 PM
  #162
90nissanS13's Avatar
90nissanS13
Originally Posted by Dblock55
Anyone chime in on the lw pulley?
From a reliability standpoint, I would suggest you avoid the LW pulleys.
It is a internally balanced engine, so it doesn't have a harmonic balancer. It is more of a "damper" and with that in mind, it's probably a good thing to have. All moving parts wear and break, vibration amplifies that. Dampers reduce that.
I don't think there is enough to gain with the LW pulleys to risk that kind of reliability.
I know you want to save weight and make power but, my opinion is not to go there. I suggest focusing on the manifold. There is much to gain from getting the air in and out of the engine.
Old Jan 6, 2016 | 02:00 PM
  #163
90nissanS13
-A good, free flowing exhaust. (headers & no cats)
-A proper manifold (ported and flowbench)
-Cams
-A proper tune.
As well as the lightweight flywheel and you are probably looking at 300-340whp from a 3.5L
Old Jan 6, 2016 | 04:16 PM
  #164
Dblock55's Avatar
Dblock55
^^^ Yea i was thinking that... flywheel, plenum spacer and exhaust came in today. Need to start researching cams and a place to get a tune.
Old Jan 6, 2016 | 04:31 PM
  #165
Dblock55's Avatar
Dblock55
The questions never stop....
Pulled the idler pulley off today, just for good measure , questions is do i need to install the 2 bolts that were holding the bracket in? The left bolt needs to go back in as it still holds the PS pump bracket, but the other 2 are pretty damn long and im not sure if theyre blind or not. Anyone know?
Old Jan 6, 2016 | 05:49 PM
  #166
90nissanS13
I don't have experience. Although, pictures would help.
For cams, I think the only good choices are Jim wolf and Tomei. Jim Wolf is way more helpful with communication and tech. feedback. They could probably help you find the cam with the best duration/lift for your set-up.
I spoke with them about Fuel injectors.
Old Jan 6, 2016 | 06:27 PM
  #167
Dblock55's Avatar
Dblock55
Ya I was thinking jwt, just not sure about the cam profile. Good to know they're helpful. Thanks for the advice.
Old Jan 6, 2016 | 07:44 PM
  #168
terrasmak's Avatar
I've been chatting with Jon at Z1 about going Tomei on mine , he has a bit of knowledge too.
Old Jan 6, 2016 | 08:26 PM
  #169
rustyschopshop's Avatar
rustyschopshop
I reused the bolts that came out if i remember correctly when i removed mine. Also cut the ear off the idler that was behind the ps to use that as a filler. There was a DIY on this somewhere on here but not sure where it is. I possibly could have dug through my parts bin for different bolts but did the mod almost 2 years ago so it is a bit foggy.
Old Jan 7, 2016 | 04:25 AM
  #170
Dblock55's Avatar
Dblock55
Yea i cut a piece off of the bracket to put behind the PS bracket... it was quite surprising how porous the metal was... super cheap casting. One part broke off when i put it in my vice I heard it crackling as I tightened it.
Anyways I was just wondering if oil will start spewing out when I start the engine. The bolts are pretty long and definitely thread into the block... might go to the store and get some aluminum replacements.
Old Jan 7, 2016 | 04:26 AM
  #171
Dblock55's Avatar
Dblock55
I tried contacting Z1 about LW pulley info, never got back to me Maybe he doesnt like me... time to end it all (i joke)
Old Jan 7, 2016 | 07:59 PM
  #172
rustyschopshop
no seeping oil from mine
Old Jan 7, 2016 | 08:00 PM
  #173
rustyschopshop
Old Jan 8, 2016 | 06:50 AM
  #174
Dblock55's Avatar
Dblock55
Perfect, out they go. Thanks
Old Jan 8, 2016 | 10:40 AM
  #175
Dblock55's Avatar
Dblock55
My neighbor signed for this, he said he had to think twice when he saw the box
Old Jan 8, 2016 | 10:52 AM
  #176
rustyschopshop
I wish they would change the name just for that reason....lol. Always nice when new parts arrive and a nice neighbor to hold it for ya.
Old Jan 8, 2016 | 11:41 AM
  #177
90nissanS13
They changed it to ISR. It would be smart if they ate the cost a dumper all the old labels and boxes!
Old Jan 8, 2016 | 11:43 AM
  #178
90nissanS13
I ran the same exhaust with an HR-type y-pipe. It was a very good combo. Mid range to redline felt significantly better. It was too loud and annoying for a daily driver so I went to the Invidia Gemini.
Old Jan 8, 2016 | 03:33 PM
  #179
Dblock55's Avatar
Dblock55
This... dunno y they haven't gotten mew boxes.
Old Jan 8, 2016 | 03:36 PM
  #180
Dblock55's Avatar
Dblock55
MOAR
