Hawk HPS Pads making noise when rotating.
Old Apr 8, 2007 | 06:21 PM
cferraro85's Avatar
cferraro85
Default Hawk HPS Pads making noise when rotating.
I bought a set if hawk hps pads because it seemed that everyone was recommending them as a good set of pads with low dust. I installed them on new rear rotors, and bedded them properly. The problem is that they are making a scraping noise when the wheels are rotating. When i drive by a wall or house at low speeds, i can hear them rubbing against the rotors. I have no frozen slider pins on the rear rotors and everything was installed perfect. IS this a characteristic of these pads? Has anyone had this experience. I am thinking about changing them out for Nismo pads that are orange(i think r-tune).
thanks
Old Apr 8, 2007 | 06:43 PM
Not good. Whether stationary or driving, the pads clear the rotors.
a. Are you certain that the pads properly sit in the calipers?
b. The pads are the correct size?
c. Something else is rubbing the rotors, wheels or tires?
d. Wheel bearings are OK?
Old Apr 9, 2007 | 04:41 AM
cferraro85's Avatar
cferraro85
i reinstalled them 2 or 3 times just to make sure thay they were right. The size is correct. All i know is that the stock ones before didnt make any noise. i have the stoptech oe replacement rotors offered by centric parts that are double disc ground, which gives them a crosshatch pattern. Do you think that is what is making them noisy?
here is the rotors:
javascript://www.zeckhausen.com/images/product_icons/Centric_rotor_description.jpg
Old Apr 9, 2007 | 07:59 AM
Q45tech's Avatar
Q45tech
Did you index the rotors to the hubs and check that the installed rotors are not warped and meet oem specification for trueness.
Oem specs are tight and must be measured with a dial indicator.
Many times hubs are out of spec [excessive or differntial lug torque or corroded [rusted]] which gets muliplied by rotor diameter.
Old Apr 9, 2007 | 04:32 PM
cferraro85's Avatar
cferraro85
um...no. i just took the old ones off, cleaned up everything real good. Replaced the pads and rotors per the specs on the 350z forums, and reisntalled everything. i did not use a dial for thickness. I assumed i ordered from a reputable company when i bought them. MAny people on here have used them with no problems. The caliper sits over the rotor with perfect clearances on each side. I honestly cannot find where the defect may be coming from. even when i jack the car up and spin the wheel by hand i can hear the scraping of the pads on the rotors. Is it just the difference in material from stock that is making them noisier?
Old Apr 10, 2007 | 05:00 AM
Q45tech's Avatar
Q45tech
Anytime you have a runout greater than 0.0015" you will hear the the shish, shish sound as the high spot comes around and contact the pads.
Warped hubs or poorly made or damaged from stacking or in shipping rotors can be fixed with brake align runout correction plates between rotor and hub............these plates are tapered in zero to 0.003" increments.
http://www.brakealign.com/pages/diagram.htm
The plates for Infiniti G35 work on Z
Brake perfection often requires a lot of extra work. Check your FSM for the proper proceedure if you are not using an on the car brake lathe to correct the runout at time of installation.
Old Apr 10, 2007 | 05:11 AM
Kolia's Avatar
Kolia
I knew you'd be around soon with some good stuff!
Old Apr 14, 2007 | 11:42 AM
cferraro85's Avatar
cferraro85
there doesnt seem to be any high spots. its a constant "SHISH" sound it doesnt sound intermittent.
Old Apr 14, 2007 | 12:05 PM
cferraro85's Avatar
cferraro85
Old Apr 15, 2007 | 07:06 AM
Q45tech's Avatar
Q45tech
When ever you change pads or compounds A FILM must be transfered from the pads to the clean rotor.............commonly called bedding in or just normal braking eventually 250-500 miles. Until this is accomplished correctly things may be noiser.................also different pads have their own different individual noise signature.
Old Apr 15, 2007 | 07:48 AM
cferraro85's Avatar
cferraro85
that explains some things.... thank you
Old Apr 15, 2007 | 10:11 AM
702Fairlady's Avatar
702Fairlady
Sorry to thread jack, but has anyone had a burning smell after installing ew Hawk Pads. Is this just the pad wearing itself in, and will this go away?
Old Apr 15, 2007 | 01:30 PM
cferraro85's Avatar
cferraro85
its just the pad breaking in, its normal. i had it too
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
