Suspension 101
Old Jan 24, 2012 | 07:42 AM
  #521
1Z4U2NV's Avatar
1Z4U2NV
Default The most important mod: coilovers
So after spending countless hours researching a myriad of different specs, reviews & prices, I am extremely informed but increasingly confused due to the amount of contradictory/incorrect information put out there. Also, I find it unhelpful when people a) ask for people's opinions on coilovers without detailing application information and b) when people provide information without knowing the desires of the inquirer...these don't help anybody.
I am looking for opinions on what you think are some of the best damping coilovers for a DD that will be lowered at least 2" below stock. I'd also like to keep results below the $2,000 price ceiling but for the sake of others, let's not entirely eliminate those that exceed...just please have your reasons. Personally I don't think there's any reason to drop more than $2,000 on coilovers that are exclusively for street.
On paper, it looks like the new Tanabe Sustec Pro Z40 has everything needed at the $2,000 range...
*40-way dampening adjustment
*damper made by KYB
*twin tube damper
*looks like a progressive spring in the rear
Looks like they're doing their best to try and manufacture a performing coilover while trying to maintain comfort for the street.
Opinions from everyone especially those who have used this setup on the street would be much appreciated although may be tough to come by given that they are new.
Other systems that have great specs and great feedback would include the KW Variant 1/2/3 however I don't think they go lower than 1.5" which in part I'm sure contributes to the positive feedback regarding ride qulaity. I also hear good things about Cusco Zero2 (slightly expensive), Bilstein PSS9/10 (again may not go low enough), Tein Flex seems great on paper however I hear as much bad as good. Same goes for the infamous Stance GR+. Confirm or contrast
If anyone can contribute from experience, I would really appreciate it and although I know there have been threads like this in the past, I don't think any of them have been up to snuff. Also, so that others who are looking for coilovers for a different application may benefit, please provide feedback regarding first hand experience with coilovers used for circuit, drift, etc etc.
Old Feb 14, 2012 | 06:42 AM
  #522
xman2yman's Avatar
xman2yman
Hey whist the weight difference between the spring bucket and the toe arm?
Old Feb 14, 2012 | 08:19 AM
  #523
JasonZ-YA's Avatar
JasonZ-YA
Toe arms do weigh less....i did weigh mine, but dont remember the exact number....
The physical advantages (alignment ease, etc) are worth more than the weight savings....
-J
Old Feb 14, 2012 | 10:12 AM
  #524
xman2yman's Avatar
xman2yman
Yeah I figure that I was just curious how much of a difference, Ill be getting this all installed within the week I hope. Im trying to figure out how to make my own lock out washers? Where did you go to make them or get them?
Old Feb 14, 2012 | 08:02 PM
  #525
JasonZ-YA's Avatar
JasonZ-YA
Just measure twice and cut once....
measure oem bolt, buy same metric equivalent, etc....its easy...
aside from that many vendors sell them....SPL parts.com, etc.
-J
Old Feb 19, 2012 | 05:24 PM
  #526
ac419's Avatar
ac419
Originally Posted by AdvanZ33
Just installed Stance coils and I'm getting this creaking noise from the driver's front. It seems to be happening when I hit protruding cracks in the asphault but remains silent during dips. The car is only lowered about a quarter to a half inch lower than my S-Techs were. The first video is in first gear through a parking lot, the 2nd is at highway speed. Any ideas?
http://www.youtube.com/watch?v=E0L7GnPtvHk
http://www.youtube.com/watch?v=tmYv244JMQU
did you ever figure this out? i have the same problem
Old Feb 19, 2012 | 05:27 PM
  #527
Chi-TownWarrior's Avatar
Chi-TownWarrior
Sounds like the top plate on your coils. I had the same problem.
I tightened down the nut on the top of the coils with an Impact per Stance's recommendations. Problem went away.
Could also be your endlinks if you have the stock ones.
Old Feb 19, 2012 | 05:31 PM
  #528
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
The problem was in the coilovers but I took them off and sold them. I tried to tighten the top nut but it was difficult w/o an impact wrench.
Old Feb 20, 2012 | 08:34 AM
  #529
ac419's Avatar
ac419
i'll try to have the top of the coilovers impacted. i know my mechanic hand torqued
i do have spl front endlinks as well
i also heard the top plate of the coils go bad (oem piece) would you recommend replacing them as well?
thanks!
Old Feb 20, 2012 | 12:22 PM
  #530
Chi-TownWarrior
It wouldn't hurt.
Old Feb 20, 2012 | 10:21 PM
  #531
koren's Avatar
koren
Originally Posted by JasonZ-YA;
I dont recommend them as they will cause friction, limit the movement of your compression arm...this is hard to explain, but here goes:
- if you have the Z in the air and compression arm attached only with the other end free, try pulling up and down on the compression arm - yup, you will be fighting the poly bushing......tons of friction and push back from the bushing.
- spl compression rod bushings are free to float and move....no adverse friction or steering input from a compression arm thats fighting you.
Here you don't recommend them for a lowered car or just any car?
I'm planning not to lower the car and I already got a full front set of the ES bushings. I already installed them in the LCA and there is a compression rod bushing set and upper control arm bushing set also...
I was thinking of installing them also but after reading this thread I'm in two minds. As far as compression rod, I think I would buy SPL bushings instead.
But there is no info on replacing the upper control arm bushings. I figured If the car is not lowered then you don't need to replace your front control arm with aftermarket one. But since I got ES polyurethane bushings in the lower control arm, there is a bigger pressure applies to the rest of them, which make me replacing upper control arm and compression rod bushings. Is that right?
Old Feb 21, 2012 | 04:52 AM
  #532
critic's Avatar
critic
I know this noise but mine was comng from my rear, but mine was from a loose control arm that just needed tightening. It is either your sways or your oem camber arms. I had to get camber kit because of wheel hop on the oem setup is not that good with aftermarket coilovers and you will get feathering overtime.
Also you should replace all other arms in your supension and get new sway bars. Get control arms, camber front and rear, and get traction arm. Traction arms is important because your grip greatly improves under acceleration. These arms are much stronger than oem setup but to answer the question about the noise I think it is you got a loose bolts that need tightening. Now the squeak could be from the coilovers breaking in, but I would get under the car and check for any loose bolts or have your mechanic take a look.
im having an issue very similar sounding to yours but in the passenger rear...zman when you say your rear control arm was loose are you referring to the rear camber arms or was your actual spring bucket loose? I did upgrade my rear camber arms to SPL a few months back maybe they got loose after that. Ill try checking both.
http://www.youtube.com/watch?v=T8ktL...1&feature=plcp
Old Feb 23, 2012 | 09:35 PM
  #533
ac419's Avatar
ac419
thanks for the input everyone. my mechanic tightened the nuts on top of the coilover mounts, the big coilover nut 18-21mm one, and sprayed down my bushings in the front.
NOISE WENT AWAY
Old Feb 24, 2012 | 05:48 AM
  #534
xman2yman's Avatar
xman2yman
In regards to the true style coil overs, I read a couple times that the rear upper mount can be destroyed, is this true? I'm trying to located any information about it but I am unable to find it.
Old Feb 25, 2012 | 01:53 AM
  #535
nismo_ninja's Avatar
nismo_ninja
Not sure how much truth there is there as I know of quite a few race teams using the true style rear set up
Old Feb 25, 2012 | 06:01 AM
  #536
xman2yman's Avatar
xman2yman
Yeah, I am not sure either. A lot of people say that the ca rid not meant for it but I don't think I found a single story that verifies those comments. Plus I won't be tracking it either.
Old Feb 25, 2012 | 07:37 AM
  #537
Gsedan35's Avatar
Gsedan35
And those race car's have modification's to the rear suspension that no average car owner knows to do or more importantly WILL do. Has nothing to do with the upper mounts or anything near their.
Yeah, I am not sure either. A lot of people say that the car is not meant for it but I don't think I found a single story that verifies those comments. Plus I won't be tracking it either.
No it's not ment for it. And it has zero to do with the upper mount or upper mount area. It is basically a geometric issue. Nissan got the suspension design right in the first place.
Old Feb 25, 2012 | 05:49 PM
  #538
nismo_ninja
Good to know, I was just saying I hear of it being done...
Old Mar 2, 2012 | 02:30 PM
  #539
xman2yman's Avatar
xman2yman
well too late I have True style installed lol.
Old Mar 5, 2012 | 11:10 PM
  #540
ALO8's Avatar
ALO8
2 questions for anyone that can answer.
1. i have spc camber arm and toe bolt. Im going with true type rear and will get an spl toe arm. is there any modifications i need to do since i had the spc toe bolt in place and had the hole elongated for the toe bolt?
2. the lockout washers i can use to secure what exactly? the toe arms? camber arms?
