Suspension 101
Old Jun 19, 2012 | 01:42 PM
  #621
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
If they are coming loose then they weren't properly torqued to begin with. Tighten them up properly and you'll be good.
Old Jun 19, 2012 | 02:07 PM
  #622
tbruner's Avatar
tbruner
While mounted to the car or must I take the the shock out to do this?
Old Jun 20, 2012 | 03:48 PM
  #623
tbruner's Avatar
tbruner
What ft/lbs should they be torqued to? I read somewhere that they should be in between 40-60 ft/lbs but thats quite a difference between the two...
Old Jun 20, 2012 | 04:34 PM
  #624
JasonZ-YA's Avatar
JasonZ-YA
whenever u need the torques....refer to the fsm:
https://my350z.com/forum/maintenance...anual-fsm.html
whenever a torque range is big, its usually because its on a dynamic part, adjustable part, part that flexes or say a bushing. ive seen subframe mount flange ranges be high too, flange flex...etc.....most engine bolts have usually a small range, due to the parts being solid, stiff, and only coefficients of thermal expansion due to heat cycles as the main factor.
-J
Old Jun 21, 2012 | 01:34 AM
  #625
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
You should be able to get them tight without removing them from the car. With factory shocks I get them as tight as I can by hand and then hit them with my electric impact.
Like Jason said check the factory service manual. On the other hand, this is one part that I've never really worried about a torque number for. I'm usually a stickler for getting everything at the proper torque setting, but this isn't one that I've worried about.
Old Jun 21, 2012 | 08:24 AM
  #626
tbruner's Avatar
tbruner
Thanks guys I'll let you know how it goes this weekend!
Old Jul 5, 2012 | 01:39 PM
  #627
Row2K's Avatar
Row2K
can anyone comment if the SPL rear camber links make any noise? SPL parts are notorious for being noisy and I want to know if these are as well.
Old Jul 5, 2012 | 01:54 PM
  #628
Neimad's Avatar
Neimad
Skip a minute or two and I turn the radio off.
SPL camber arms and mid links; I've learned to love the noise.
Old Jul 5, 2012 | 02:10 PM
  #629
Row2K's Avatar
Row2K
I'll have to listen to it at home (no sound at work), but I'll take it that they aren't quiet.
Thanks to the info
Old Jul 5, 2012 | 02:18 PM
  #630
Neimad's Avatar
Neimad
Also those are Ohlins coilovers, if there is a better street damper, I couldn't find it. But really the noise is fine, especially if you keep your radio on. With the windows down its ok too.
Old Jul 31, 2012 | 03:36 PM
  #631
ALO8's Avatar
ALO8
on spl front arms, does the arm have to be removed completely to adjust caster?
Old Jul 31, 2012 | 05:26 PM
  #632
350zeed's Avatar
350zeed
Default Suspension 101, still a couple of Q's...
I have read that Suspension 101 prob about 5 times. I could be missing something. But I am about to order...
Top Speed Pro-1 Coilovers
Eibach rear camber/toe kit
My only question is or add if need to my list... is I read the part about Lockout washers. Do they take place of them Oval egg shaped washers? I make a set of lockout washers but trying to configure what they are for.
I am really trying to understand this. Am I on the right road?
Old Jul 31, 2012 | 06:04 PM
  #633
ian99rt's Avatar
ian99rt
No, but you will need to take both pivot bolts out, move the heim jount end(s), then reinstall bolts.
Old Jul 31, 2012 | 07:25 PM
  #634
Voboy's Avatar
Voboy
you use lockout washers when you are no longer using the OEM eccentric bolts for adjustment... get it?
soo if you're installing camber arms... you remove the oem bolts and use lockout bolts... all adjustment is on the new arm now.
new toe bolts just replace the oem ones.
/thread lock
Old Jul 31, 2012 | 10:00 PM
  #635
ALO8's Avatar
ALO8
so this requires the coilovers to be loosened as well to access the pivot bolts right? then loosen jam nuts to thread rod end. seems like a lot of work but i dont think i will adjusting caster much just wanted to know if there was an easier way.
Old Aug 1, 2012 | 03:30 AM
  #636
JasonZ-YA's Avatar
JasonZ-YA
Yes
ya, its not so bad....caster is usually somehting you dont adjust too often...
-J
Old Aug 1, 2012 | 03:53 AM
  #637
350zeed's Avatar
350zeed
So if your using the lockout washers, how do you adjust the toe? Isn't that what the eccentric washers are for? I understand going to the lockout to prevent slippage. I'm not going to the track, just your occasional street races
Old Aug 1, 2012 | 04:03 AM
  #638
JasonZ-YA's Avatar
JasonZ-YA
There are two points per side of the car that OEM factory eccentric bolts are used.
1. The camber arm to subframe mount location AND 2. The toe arm (spring bucket) to subframe mount location. So:.. that means there are a total of 4 oem factory eccentric bolts mounted to the rear aluminum subframe to suspension arm locations....get it? get a flash light, go look!
Toe w true coilovers:
SO, if you purchase true coilovers, and eliminate the use of the oem spring bucket THEN you can purchase toe adjustable arms and use lock out washers at the NEW toe arm to subframe mount location.
Toe with factory suspension, aftermarket lowering springs or aftermarket "oem style" coilovers:
you must use eccentric bolts, either oem or aftermarket SPC or other available 3 degree eccentric bolts.
Camber:
if you purchase any aftermarket camber arm, then you can use a set of lock out washers to eliminate the need of the oem factory eccentric bolt and just the newly purchased aftermarket adjustable camber arm to make all the needed camber adjustments.
get it?
re-read my thread from beginning, get a flash light and look under your car at the same time, print it out, or take your lap top with you....
-J
Old Aug 1, 2012 | 04:00 PM
  #639
ALO8's Avatar
ALO8
are coilovers on a 350z side specific in the front or rear?
Old Aug 2, 2012 | 06:01 AM
  #640
Chi-TownWarrior's Avatar
Chi-TownWarrior
Just front and rear
