no power when i gunning it. HELP
Old Dec 15, 2005 | 04:35 PM
ekoms31's Avatar
ekoms31
Default no power when i gunning it. HELP
after a friend put in a stillen valve body i am getting little power when i push the gas pedal complete down. the rpm just rises slowly very slowly. i was told that everthing was put in right. when he was putting in the transmission fluid some of it spilled out, could that be the problem. i also reuse the same fluids.
i have a 05 35th anny auto
Old Dec 15, 2005 | 05:23 PM
booger's Avatar
booger
Take it back to who did the install . If you did it...ummm...call stillen
Old Dec 15, 2005 | 05:29 PM
ekoms31's Avatar
ekoms31
we called stillen and they said never heard of the problem n we will call bak later. could it be the ecu need to be reseted????
Old Dec 15, 2005 | 05:55 PM
Cannysage's Avatar
Cannysage
it was be installed incorrectly
Old Dec 15, 2005 | 05:58 PM
ekoms31's Avatar
ekoms31
are u sure. and how would it be install incorrectly, it can only go in one way and the car shifts fine
Old Dec 15, 2005 | 06:04 PM
booger's Avatar
booger
I would say...if it was installed right . Check the fluid . And I hope you filtered the used fluid before putting it back in
Old Dec 15, 2005 | 06:09 PM
ekoms31's Avatar
ekoms31
the fluid is very pink and cleaned, i put in wat i took out, problay lost a some oil. could it cause the lost of power tho
Old Dec 16, 2005 | 06:53 AM
Zivman's Avatar
Zivman
check this thread Seems he is having a similar issue
Old Dec 16, 2005 | 09:14 AM
zparts's Avatar
zparts
If the torquing of the bolts is done improperly, fluid will leak out where the valve body seals against the trans housing.
Old Dec 17, 2005 | 04:15 AM
ekoms31's Avatar
ekoms31
ty for helpin me, ur the only one.
Old Dec 17, 2005 | 11:33 AM
overZealous1's Avatar
overZealous1
thats some funny stuff, hahah
Old Dec 17, 2005 | 12:36 PM
350z bra's Avatar
350z bra
do u hav a intake? it mite be loose?
Old Dec 17, 2005 | 01:00 PM
XBS's Avatar
XBS
Veteran
I have the SAME PROBLEM except my car is a 6MT the dealer just replaced my tranny under warranty a few days ago then my car started doing this but its intermentitnt, sometimes it does work normally but it usually just is like 50% throttle wierd!!
Old Dec 17, 2005 | 01:15 PM
DavesZ#3's Avatar
DavesZ#3
No need for two of these. Let's continue it in his other thread...
https://my350z.com/forum/engine-and-drivetrain/159480-big-power-lost-after-mod.html
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
codek
Sep 28, 2015 03:03 AM
