RevUp Oil Consumption TSB and discussion
Old Jun 29, 2008 | 07:48 PM
  #3221
9kFever's Avatar
9kFever
Originally Posted by antennahead
It could be 3/4, could be just 1/2, who knows. They are oblivious to the issue. As most have stated, the oil light virtually never comes on, you have to have practically no oil for it to show, and sometimes even then it doesn't. so who knows how many are affected.
Mine was once 3 qts low with no oil light or anything. If most of the owners ust go somewhwere to get their oil c hanged they would never know.
Old Jun 29, 2008 | 08:21 PM
  #3222
antennahead's Avatar
antennahead
Exactly! I was 3 1/2 low and no light either. I started noticing the oil pressure doing weird stuff that was outside the norm, was a tip off to me.
John
Old Jul 1, 2008 | 09:54 PM
  #3223
06CPV35's Avatar
06CPV35
That's the thing about the oil light and/or pressure gauge. It only alerts you when you lose suction from pump pick-up tube = fluctuating or no oil pressure or light illuminates. We all know how low oil has to be to loose suction to oil pump. By that time damage is probably done or borderline to damage.
And speaking of recalls...I think Nissan did recall with their 2006 4cyl Altimas and 2.5 Sentra SE-R's due to OC issues. And those affected customers were also automatically given extended powertrane warranties. Nice huh
The info below doesn't directly say recall, but does say NNA informed NHTSA. I'll bet it was the other way around. NHTSA can and has mandated recalls in the past when manufactures don't step up to the plate. I did a thread a long time ago stressing the importance of filing a complaint with NHTSA with our OC issue.
Amsoil's TSB about the 2006 Altimas and Sentera SE-R's:
TSB_Nissan_oil_consumption.pdf
Old Jul 1, 2008 | 09:58 PM
  #3224
06CPV35's Avatar
06CPV35
Default And my current V2 Update
Just changed my oil again with 1240mi on that oil interval (1740mi total on new V2) and was 8mm down. That = 1qt/3720mi. Hope it improves better than that. I normally change oil at 5K when I run 100% Synth which I plan on doing later on. I could live with 1qt/5000mi OC I guess but this V2's not there yet. Hope time, a song and a prayer gets me to that threshold. Been very nice to engine and still not going over 4K on rpms.
Old Jul 2, 2008 | 08:02 AM
  #3225
SCARECROW BEATS's Avatar
SCARECROW BEATS
Originally Posted by MikeyG
Definately find a new dealer. I brought mine in and they changed the oil and filter and said to bring it back in 1000 miles. It was outside the TSB so they ordered the new engine. Didn't even have to go back for multiple reads.
+1, SAME THING WITH ME... GETTIN NEW ENGINE INSTALLED ON MONDAY...
w00t!
Old Jul 2, 2008 | 08:57 AM
  #3226
Mosi's Avatar
Mosi
Originally Posted by surfcity40
Did you check your VIN to see where the motor falls?...Might try another dealership or get the regional rep involved if you're getting hosed.
I did a search and didn't find anything to do with VIN ranges for this prob. I just got my 06 2 1/2 weeks ago and want to know what to expect. Is there a published range of VINs for the possible effected motors?
Old Jul 2, 2008 | 09:17 AM
  #3227
06CPV35's Avatar
06CPV35
Only VIN cut-off is to midyear for the 07 G35 coupes on their TSB.
Z's have no VIN number ranges for the 05 and 06's affect for models listed on that TSB.
Old Jul 2, 2008 | 10:55 AM
  #3228
SCARECROW BEATS
JUST WATCH THE OIL CLOSELY... CHECK IT EVERY WEEK OR SO FOR A WHILE TILL YOURE SURE.
HOPEFULLY YOURE STILL UNDER WARRENTY IF YOU RUN INTO ANY PROBLEMS.
GOOD LUCK!
Old Jul 2, 2008 | 11:02 AM
  #3229
Mosi's Avatar
Mosi
Thanks guys.... it only has 15k miles on it and I went ahead and bought the decked out extended warranty till 100k miles.
Old Jul 3, 2008 | 08:19 PM
  #3230
leozim's Avatar
leozim
this is my second replacement engine. just got an oil change today after 3000 miles and i scheduled for a oil consumption test. this would be the second test for this engine. but anyways before they replaced my engine oil, they measured the old oil and they said the engine burn about 1/2 qt of oil after 3000 miles. for me it seems that its still too much for a new engine. any input?!
im going back after 700-1000 miles for the OC test.
Old Jul 4, 2008 | 01:19 PM
  #3231
06CPV35's Avatar
06CPV35
That consumption falls in the 'good' range on TSB chart, so don't be surprised if dealer says you have no issue with that OC after testing completed.
NTB07-088c.pdf
Still too much for a new engine? IMHO....yes, though I've heard this can be normal with some of these and does improve over time. Perhaps this may be your case, hopefully. Some don't have that issue at all and some still complete failures...why is that?
Know two V2 owners personally that has improved over time with basically no further OC issues and better than your current OC + one that hasn't. Hoping mine improves as well for you and others in the same boat.
Now, being mine just drank 8mm (1/3qt) in the last 1240mi with 1740mi total on fresh V2, have to say I'm not all warm, fuzzy and smiling with my current V2 replacement yet. Would be feeling a lot better if I were one of those V2 owners with apparently no OC at all with their fresh V2.
G/L with your OC testing.
Old Jul 4, 2008 | 04:46 PM
  #3232
camaross's Avatar
camaross
Default My V2 follow up so far...2nd oil service
Greetings,
I had 2nd oil service with 3880 miles on the oil. Presently have 7025 miles on the new long block. The oil level only went down 2 or 3 mm. Driving included trip to San Diego and some serious high speed mountain driving in AZ.
So far it looks good, but I'm still checking the oil level every other weekend!
Good luck to you all, talk to you later...
Joe
Old Jul 4, 2008 | 04:57 PM
  #3233
cheshirecat79's Avatar
cheshirecat79
Originally Posted by camaross
Greetings,
Joe
Good to hear your success so far!
Out of curiosity, how did you break in the engine and what kind of oil are you running? Also, at what mileage was the first oil service?
Old Jul 4, 2008 | 06:00 PM
  #3234
Shift__Z's Avatar
Shift__Z
hey guys quick noob question. I just bought y 35th anniversary and it may be consuming oil, Im going to take it in ASAP, but my question is being the non original owner is that going to be a problem...BTW I also have the axle ticking
Old Jul 5, 2008 | 05:31 AM
  #3235
cheshirecat79
No, it doesn't matter if you're the second owner. If you're under factory warranty everything follows the car, not the buyer.
If you have an extended warranty, you may need to get that transferred into your name.
Old Jul 5, 2008 | 01:35 PM
  #3236
Shift__Z's Avatar
Shift__Z
ok thanks ya i didnt think it mattered but i just wanted to make sure...
Old Jul 6, 2008 | 11:12 AM
  #3237
mgnchakar's Avatar
mgnchakar
anyone notice the v2's redline is at 6500 instead of 7k? Mine is like that; engine revs stop at 6500 for me
Old Jul 6, 2008 | 11:20 AM
  #3238
kacz07's Avatar
kacz07
it doesn't rev higher? i don't get
Old Jul 6, 2008 | 02:52 PM
  #3239
06CPV35's Avatar
06CPV35
That's usally controlled by the ECU. Don't understand either.
Old Jul 7, 2008 | 03:13 PM
  #3240
luvZcar's Avatar
luvZcar
ok guys so I got my oil change today after 3100 miles my car was only 1/2 qt low things are looking good
