RevUp Oil Consumption TSB and discussion
Old Apr 16, 2007 | 07:03 PM
  #641
dbasal's Avatar
dbasal
Originally Posted by bremboboy
I have put 1000 miles on the car since the oil change, and the oil level is between the L and the H. Is this normal?
(I still have no idea how to use the dipstick so this measurement was probably wrong anyway)
The best time to check is first thing in the morning before you start the car.
Pull the dipstick out and wipe it clean. Then re-insert it and pull it back out and see where it reads. You can repeat this a few times if you want to be sure.
Old Apr 16, 2007 | 09:02 PM
  #642
bremboboy's Avatar
bremboboy
Does the dealer fill it all the way up to "H" during an oil change? Im reading right between the L and H after 1000 miles...what does this mean?
Old Apr 16, 2007 | 10:04 PM
  #643
Bevo's Avatar
Bevo
If you put in 5 qts, it should be around H mark.
that means your engine consumes oil...
Old Apr 17, 2007 | 05:05 PM
  #644
4SHIZZIL's Avatar
4SHIZZIL
Add a 2005 G35 6sp to the blown engine due to massive consumption...replaced under warranty, thank God. Thanks for the post. The information gathered, deffinately helped to build a rock solid case against Infiniti Corp.
Old Apr 17, 2007 | 05:14 PM
  #645
bofa's Avatar
bofa
You actually blew the motor? Damn.. I was pretty sure I was going to blow mine a few times but I didn't want to delay the lemon law proceedings by having to let them install a new engine under warranty and wait for new testing all over again. I haven't driven it as hard as I normally would since I had engine pinging. BTW, the new engine isn't the solution yet.. you're still in the game.
Old Apr 17, 2007 | 05:29 PM
  #646
4SHIZZIL's Avatar
4SHIZZIL
Default Yeah I know a guy on his 3rd..
VA law = 3 times changing the same item equaling a certain % of the car...or something like that..so I figured...get the oil checked every 1,000 miles with is a pain because the dealer is like 45 min away with no traffic...then every 3K miles get a new engine...lol
Eventually they will get sick of me....I have a long way to 7yr..70,000 miles...plus I just racked up 2600 on the 07 G35X loaner..trust me, they will give me a M35X by the before I get tired....lol.
thanks again...funny thing is that I heard funny noises all day and I kept turning down the radio and listening ...I thought I was being paranoid...then with no warning..no smoke..no leakage...the dash looked like St. Nick designed it ..lol...called AAA.
Old Apr 17, 2007 | 05:37 PM
  #647
bofa's Avatar
bofa
LOL.. that's awesome... sorry that you have to deal with it, but at least you're taking it in stride.
Old Apr 17, 2007 | 06:05 PM
  #648
bremboboy's Avatar
bremboboy
when the heck are they going to figure out the solution?
Old Apr 17, 2007 | 06:10 PM
  #649
bofa's Avatar
bofa
The last I heard was June or July... lol.. but if it's as close as their January 07 estimate I wouldn't get my hopes up.
Old Apr 17, 2007 | 07:42 PM
  #650
bremboboy's Avatar
bremboboy
What pissess me off is that if they dont find some sort of solution these engines are going to completely die once warranty expires and then the 06 revup owners will be screwed!
Old Apr 17, 2007 | 07:47 PM
  #651
bofa's Avatar
bofa
That's why I encourage all of you to press the lemon law issue. It costs you nothing butvisits to the dealership. You can get attorneys that will do the hard work for free.
Old Apr 17, 2007 | 07:55 PM
  #652
350zx6r's Avatar
350zx6r
i need to check it out!! cause it concernes me a lot. i mean the car runs strong but what happens after warranty? im going to look into it.
Old Apr 17, 2007 | 08:02 PM
  #653
dbasal's Avatar
dbasal
Actually with my last two oil changes the dealer overfilled mine by about 1/4 qt, but yes, most other times it would be filled to the H.
Old Apr 17, 2007 | 08:08 PM
  #654
dbasal's Avatar
dbasal
Very true. An engine cosuming oil used to be the first sign that it was a good time to start looking for a new car. Now it seems that things are just being brushed aside as "That is normal". What's next? "We are sorry, but since the flames coming out of the engine did not exceed 8 feet in height, that is within spec".
Keep in mind that the rev-up was only in full production for the 06 model year. That was one of the shortest lived engines ever. They must have realized the mistake they made.
Old Apr 18, 2007 | 04:57 PM
  #655
4SHIZZIL's Avatar
4SHIZZIL
Default Just noticed your AVATAR
FYI...the G 35's dont have an oil low light....I had it 2 quarts low with no engine light....engine blew 1,400 miles after an oil change.
At least you guys have an oil light on the Z!
Old Apr 18, 2007 | 05:16 PM
  #656
dal2kvvisp's Avatar
dal2kvvisp
hey, i read through this entire thread, and remember seeing the answer before, but i cant remember the answer now. When your doing an oil consumption test, are they only going to test it for the first 1000 miles? Or are they going to want to get readings every 1000 miles for that oil change? Because i have a feeling im not going to be burning much oil till the oil gets to about 2000-2500 miles, then the consumption picks up.
Old Apr 18, 2007 | 06:25 PM
  #657
bofa's Avatar
bofa
They will test every 1000 miles for 3 intervals.
Old Apr 18, 2007 | 06:26 PM
  #658
bofa's Avatar
bofa
We don't have a low oil light but we have a low oil pressure light.. you have one of those, right?
Old Apr 19, 2007 | 10:35 AM
  #659
aren21's Avatar
aren21
500 miles so far, a mix of hard driving and normal driving and it hasnt burned a drop. Im clueless.
Old Apr 19, 2007 | 11:23 PM
  #660
Wraith's Avatar
Wraith
i have got to keep tabs on my oil. bofa if you win the lemon law case do you get an 07????
