Clutch Replaced with JWT
Old Jun 14, 2007 | 09:11 AM
JoeyFyed's Avatar
JoeyFyed
Default Clutch Replaced with JWT
So my stock clutch has gone to crap, guess i was a lil too rough?
So, now time to upgrade to the JWT combo. However, i did a self diagnosis and figured my clutch was out since its slipping horridly. Before i order my JWT, is there anything else i need besides the clutch and flywheel. Im thinking of going to the dealer but have to get a day off work so thats kinda lagging the process. So if any of you know exactly what i need it'll be great. Search function brought back that i might as well get a new clutch slave cylinder while im in there. Anyone care to chime in, im stuck driving around the beater truck =/
Thanks, Joe
Old Jun 14, 2007 | 09:12 AM
PFunk124's Avatar
PFunk124
How many miles did you get on your clutch b4 it went out.?
Old Jun 14, 2007 | 09:14 AM
mario23's Avatar
mario23
I'd get a SS clutch line while your at it.
That should be all you need...
JoeyFyed's Avatar
JoeyFyed
17k miles. Lol, dont ask. I already know...
Old Jun 14, 2007 | 09:16 AM
JoeyFyed's Avatar
JoeyFyed
Sounds good, C/F, Slave cylinder, and new SS clutch lines. Hoping for some more information people, i greatly appreciate it since im at work now, and have had my car sitting at home for 2 weeks because im so damn busy!
PFunk124's Avatar
PFunk124
Well I have like 35k on mines and I can tell its getting worn a bit. Thinking about getting a Nismo Clutch and a light flywell. Any suggestions on the flywheels?
Old Jun 14, 2007 | 09:29 AM
JoeyFyed's Avatar
JoeyFyed
Well, i've heard great things about JWT for street driving. Ive taken my car only once to the 1/4 and drive somewhat spirited. I'm sure there are other brands out there (ACT) that are better than JWT performance wise, but i wanna keep a somewhat tame clutch being that i'm NA and i don't see it necessary to have a really stiff clutch (Drive in traffic from Pasadena, to Hollywood everyday). Also everyone seems to love the combo, and with a 15lb difference in the flywheels, this is a great performance mod. Should shave a few tenths off the times.
Old Jun 14, 2007 | 10:25 AM
hotshothenry's Avatar
hotshothenry
How can you guys tell when your clutch is about to go?
Old Jun 14, 2007 | 10:32 AM
JoeyFyed's Avatar
JoeyFyed
Well, for me. I put it in 6th on the highway @ 70. Gun it, rpms shoots from 3k to 6k, then while still gunning the car, the rpms falls down back to 3k. In a sense, slipping....
Old Jun 14, 2007 | 11:08 AM
DJMatrix1067's Avatar
DJMatrix1067
i wondered the same thing myself.
when i burned my first one the easiest give away was the smell and higher engagement point. that was before i realized that you cant rest ur foot on the clutch pedal lol. noob i know.
but it was obvious when the car started to slip while at full throttle. its a feel thing. you will notice it. its like you get used to a certain sound at a certain speed while the throttle is open. and all of a sudden u notice that the rpms dont match the wheel speed. its like having the clutch partially engaged while driving.
Old Jun 14, 2007 | 11:54 AM
cheshirecat79's Avatar
cheshirecat79
Just like the last guy said, the RPMs will not match the wheel speed.
When your clutch starts slipping it's usually in high gears under full acceleration. It feels you're gunning it with the clutch pushed halfway in... RPM stays up there but the car takes a bit for it's speed to increase to match the engine.
The problem will exaggerate if you're sitting in traffic and working the clutch heavily, causing it to heat up and lose grip.
Rob
Old Jun 14, 2007 | 12:07 PM
Changvi's Avatar
Changvi
JWT flywheels...thats what i have. It works wonders with Nismo Clutch.
Old Jun 14, 2007 | 05:47 PM
TuckandTwist's Avatar
TuckandTwist
Good thread. Thanks!!
Old Jun 14, 2007 | 08:01 PM
k3silk's Avatar
k3silk
Im on my stock clutch with 22+k on my car with 12k boosted and my clutch is fine Im just changing mine for pc of mind.
Old Jun 15, 2007 | 03:46 AM
TuckandTwist
I found an article on how to choose a clutch:
http://www.specialtyz.com/choosing.htm
and:
http://www.uucmotorwerks.com/CLUTCH/
In summary, the latter site comments:
"To repeat the important point, do not buy more clutch than you need.
A simple organic disk will handle a wide variety of use - including street use, auto-x, and even true racing. In fact, SCCA ITS racing rules require a standard OE-spec organic disk. UUC has tested organic disks to reliably handle up to 475hp in long-term street use. M3s regularly run through several auto-x seasons without problems.
A kevlar disk is a good choice for a heavily-tracked or road-raced cars, especially with forced induction.
Carbon/ceramic should be left to high-power cars that see lots of drag racing, or are dedicated track/drag cars.
Sintered iron clutch disks are strictly for endurance racing
Old Jun 15, 2007 | 06:54 AM
03mEWuse350Z's Avatar
03mEWuse350Z
Good find Tuck. I found the UUC article simple to understand and very informative.
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
