oil change
Old Jun 8, 2008 | 04:51 PM
Zstealth's Avatar
Zstealth
Default oil change
sup guys well im bout to change my oil and i was wondering what should i use? im thinking about getting the Motul 8100 Synthetic Motor Oil,should i use 5w/30 or 5w/40? and should i just use the nissan oem oil filter or the greddy oil filter? noob here guys.oh btw how much oil bottle can i use on the z?
Old Jun 8, 2008 | 05:03 PM
krnzzang84's Avatar
krnzzang84
Motul is fine, 5w30 with nissan filter is good. 5w40 might be little thick for n/a
Just don't get framd filter, mobile one is also goood filter and oil!
Good luck
Old Jun 9, 2008 | 10:53 AM
chaparro78's Avatar
chaparro78
I use mobile1 synthetic oil/filter. Only oil I've ever put in my Z, I also use it on my 71 Olds 442 W-30. My father uses it on his 69 Mach1Good oil, good reputation. Same oil that comes in and recomended for Vettes and many other high performance cars. (sounds like a commercial, lol)
Old Jun 9, 2008 | 12:52 PM
Done Deal DR's Avatar
Done Deal DR
I've used it since I got my Z a couple of years ago, as well as my boosted Honda's in the past. Never had any sort of engine failure whatsoever (knock on wood).
Old Jun 9, 2008 | 01:52 PM
Z04's Avatar
Z04
5w30. any brand will work fine.
Old Jun 10, 2008 | 08:22 AM
WhiteNoiz's Avatar
WhiteNoiz
Check out the VQ oil analysis sticky and make the decision for yourself. You will see that Mobil 1 (correctly spelled) doesnt have very impressive wear numbers. I used Mobil 1 synthetic for years until I ran across that sticky, very good info there. I have switched to the European formula Castrol synthetic. You will find the wear numbers on that oil are GREAT. The above poster is correct, any oil will "work", some just work better than others. Depends on how much you love your car, how much you care, how long you want it to last. So check out the sticky, and decide from there...
Old Jun 10, 2008 | 08:26 AM
blasian's Avatar
blasian
+1
Old Jun 10, 2008 | 08:57 AM
mistico's Avatar
mistico
Mobil 1 0w-40 has shown excellent results on the UOAs.
I'm running that right now and will do my own UOA to confirm.
Old Jun 10, 2008 | 10:26 AM
WhiteNoiz's Avatar
WhiteNoiz
I just went back and looked at the UOA for that oil, not bad, but not excellent. the TBN # was good, that was the best number. Iron was high for the 32xx mile change. A little better than the other Mobil 1 though. There are DEFINATLY better oils than Mobil 1 0-40w.
Old Jun 10, 2008 | 12:05 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
thread discussed a million times
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
