Rear Differential Question?
Old Aug 20, 2008 | 09:25 AM
dragon11689's Avatar
dragon11689
Default Rear Differential Question?
Hey what's up guys...quick question. I know its 2 quarts of oil for the rear diff when replacing fluid but thats conventional oil. Since I'm putting synthetic, it may require more. I couldnt find any info on this so I would like to know what the amount of quarts with synthetic would be for the rear diff. Thanks in advance.
Old Aug 20, 2008 | 09:33 AM
JasonZ-YA's Avatar
JasonZ-YA
i thought you just filled it up till you couldnt anymore through the fill plug....synthetic or not, you need to put the same amount...
not possible to add more past the fill plug...
-j
Hold on. I thought 2 quarts of
water equals 2 quarts of
milk equals 2 quarts of
regular motor oil equals 2 quarts of
synthetic oil.
So 2 quarts is not 2 quarts?
Old Aug 20, 2008 | 09:35 AM
JasonZ-YA's Avatar
JasonZ-YA
^^ exactly.....
your not adding stronger fluid which requires less or anything like that.....your just adding better fluid....use same amount..
-j
Old Aug 20, 2008 | 10:50 AM
dragon11689
Gotcha, just making sure that was the case. I had someone bring that up and thought I would check on that to verify. Thanks for the info guys.
Old Aug 20, 2008 | 10:57 AM
WhiteNoiz's Avatar
WhiteNoiz
synthetic oil.
I just changed mine again last weekend, and the fill hole started puking back after give or take 1.75 qts.
...and yea, it was the mysterious synthetic fluid that warps the laws of physics
Old Aug 20, 2008 | 04:53 PM
terrasmak's Avatar
Big difference between you need 2 quarts and you going to use 2 quarts.
Old Aug 21, 2008 | 03:34 AM
Z04's Avatar
Z04
synthetic oil.
you sir, are correct. and just when you thought you had heard it all, somone comes along with something else.
Old Aug 21, 2008 | 05:10 AM
gothchick's Avatar
gothchick
Mine took about 1-3/4qt. Amsoil 75w90.
416blueZ
Jun 11, 2024 10:56 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
