Custom Engine Grounding/Earthing Kit
Inventor
Z-Xtreme.com
Z-Xtreme.com
Once again my shortsightedness and self-centeredness reveal themselves!
Who knew that everyone doesn’t have an Injen CAI!
Anyway, I tried to remove the driver’s side factory ground cable with NO luck. There was no way to get a socket on the bolt and it is at such an angle that a 10mm wrench will not get it either.
Here are some alternatives to mount to the chassis. If any of these mounting points are used, it is likely that a shorter wire would be necessary.
This last one may still be behind the factory air box - I can't remember
Please keep the feed back coming!
Originally posted by 350xcloud
insaneamine,
just got the 6th wire today, will put on tomm or friday and will let you know if it makes difference. Thanks
insaneamine,
I'm going to pick up an eye today after work, and see if i can cut the ground wire and put a new end on it. Then i'll try to find a good place to drill so i can put both the ground and the 6th wire together. I'll let eveyone know how it goes. Probably shouldnt be that hard. The only thing holding me back, is i just got this car 3 weeks ago, and im already cutting wires and drilling holes.
-DrCold
-DrCold
lemans- what you said... "If only car dealerships were run by folks like Guy. To quote the BB's "Wouldn't it Be Nice"" how true, how true.
6th wire came today- just installed. Will post my impressions this weekend.
Hey guys!
First, great community you guys have here! lots of awesome information!
Second, I don't have a Z, I do have a G, but my questions involve my other vehicles. Will a grounding kit help with any car or truck? If I were to try and design one myself, what kind of mount points should I look for and what should be connected to what?
TIA,
Dan
TIA,
Dan
Had a chance to put some miles on today.
I can't say that I can discern a difference between the 5 wires and the addition of the 6th- still much smoother than without the kit and about the same with 5 or 6.
Looks nice, though!!!
Next installation is on my Chevy K1500HD !!!
Clue me in, I bought the kit long ago, pics at website.
What is all this new stuff about the "6th wire."
Is it free to exsisting customers? Do I need it?
Another wire couldn't hurt!!
What's all the hubbab bub? (as my old work partner used to say)
RIP Clark, you are missed
March 20, 2003
Just installed the Earthing Kit to my new Z that has 300 miles on it. I DEFINATELY noticed a smoother engine at RPM's over 4K and the idle dropped slightly when the engine reached normal operating temperature.
I'm shifting this sucker at 7K and having a blast!
Need MORE HP! Basically would like the R's to come up a lot faster. ANy ideas????????
Hey, Insaneamine. I have tried to e-mail you but for some reason my e-mail came back not wanting to go through. If you see this reply. Please e-mail me @ pkhang123@netzero.net . I like to get a red set of the grounding kit. Send my info of how you want me to send the money...Thanks a bunch Pao
Originally posted by Midilink
March 20, 2003
March 20, 2003
Originally posted by ddee06
I'm curious what color wires did you get for the Superblack?
I have done a few searches in the forums on the topic of grounding and earthing kits and have read this entire thread and I appreciate everyone's input.
However, what I'm looking for is information on this topic by automotive publications.
I searched Sport Compact Car's web-sight for the article that some of the dyno results were cut/pasted from but all it comes up with is car articles that mention this mod in passing or simply list it as a mod.
Any links to publications reviewing or discussing this topic would be very much appreciated.
Thank you.
(I'm also posting a new thread w/ the same question for those who may not read 14 pages
Thank you.
Thanks Guy
I installed the 6th wire on my G35 Coupe today. On the G35, it is EASY to get to the factory ground location, so that is where I attached it. I routed it next to existing earthing kit wire - then under air intake hose - over to factory ground on drivers side of car. I can not provide pics because my camera is no more.
I'll drive a bunch to see if I notice anything. As far as idle goes, exactly the same.
Second kit from Guy installed tonight on a friend's DB Performance. No problems other than slippery fingers dropping a bolt down onto the plastic shroud below.
Good thing I had my fishing license!!!!
I'm sure he's already enjoying the smoothness by now...
