Custom Engine Grounding/Earthing Kit
Old Jun 20, 2003 | 06:04 PM
  #461
DavidD's Avatar
DavidD
Default G35 vs Z
Cool!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-g35vszimg.jpg
Old Jun 22, 2003 | 08:45 PM
  #462
12SecZ's Avatar
12SecZ
Default Better Blues
No broken bolts
Attached Thumbnails Custom Engine Grounding/Earthing Kit-final640.jpg
Old Jul 9, 2003 | 09:55 AM
  #463
jckolnturn's Avatar
jckolnturn
I just installed mine in less than an hour with no broken bolts, the only hitch was i had to go back and loosen some of the bolts again and adjust the wires because i wanted as neat of a look as possible. It definately idles lower and smoother, and they look great too.
Old Jul 10, 2003 | 08:30 PM
  #464
jckolnturn's Avatar
jckolnturn
here's a pic
Attached Thumbnails Custom Engine Grounding/Earthing Kit-wires.jpg
Old Jul 11, 2003 | 02:11 PM
  #465
BlueDragonZ's Avatar
BlueDragonZ
Originally posted by jckolnturn
here's a pic
That looks AWESOME!!! My DB is jealous. I need to quit procrastinating and order it.
Old Jul 11, 2003 | 03:19 PM
  #466
12SecZ's Avatar
12SecZ
Yeah that is nice and clean, I forgot what a stock engine looked like it has been so long! That blue is perfect!
Old Jul 11, 2003 | 04:16 PM
  #467
DavidD's Avatar
DavidD
Talking MaxHat 6th wire
MaxHat love the engine. Great job. I would like to see where
you put the 6th wire. Thanks.
Old Jul 11, 2003 | 04:17 PM
  #468
DavidD's Avatar
DavidD
Unhappy MaxHax
Sorry MaxHax not MaxHat
Old Jul 11, 2003 | 06:35 PM
  #469
12SecZ's Avatar
12SecZ
It's gonna go from the driver side mainifold to the frame or tranny.
Can't hurt. I'm gonna wait until after SC install though.
Old Jul 11, 2003 | 09:35 PM
  #470
johnsZ's Avatar
johnsZ
Default wires
i have seen a lot of pictures- it looks cool to have a bit of color running around the engine.
But... I would love to see how grounding to ground has any impact on performance.... By the way, the resistance from most of the points on my engine and to any other point is between 1 and 4 milliohms (that is thousanths of an ohm... right at the limit of my test equipment). I do see some ground loops on some of the pictures- a definite no-no for a signal-handling system, but no effect on the engine. If the radio is noisy at the low end of the FM band, and you use a phone with an RF transmitter, you may find the signal is a bit noisy.
Curious. Opinions??
Old Jul 12, 2003 | 12:47 AM
  #471
DavidD's Avatar
DavidD
Default Hp gains
This was posted prior in tread of dyno with grounding kit on 350Z
Attached Thumbnails Custom Engine Grounding/Earthing Kit-turbomag_5.jpg
Old Jul 12, 2003 | 02:06 PM
  #472
johnsZ's Avatar
johnsZ
Default hyper ground website
I just went to the hyperground website
I am truly amazed- LOL!!!!!!!!
They claim 10 times lower impedance- well, based on the measurements I did in my engine, this would put the bulk resistivity in their copper wires at less than 20% of the purest oxygen-free high conductivity copper ever produced... a pretty amazing feat, I think. (they confused impedance with resistance- most of the signals in the engine compartment are DC or very close to DC, (other than the spark and speed sensor signal)) so impedance is essentially the resistance, but this is a minor point. The ECU does not know anything about the existence of these wires- it has it's own ground-signal pairs.
I would be concerned with the crappy little tin-plated battery clamp that they include, relative to a low resistance gold plated unit that you can get at any decent auto audio place- that alone would have as much "effect" as their wires.
Sorry to be a skeptic but this kit goes along with the magnets on the gas line increasing mileage by "aligning the gas molecules"...
BTW-I do not discount the cool factor in having some color in the engine compartment- makes for good showing. A low resistance air filter will have a much greater effect on the high end power and perhaps a bit on mileage (like a K&N) for about 25% of the cost of the wires.
Old Jul 12, 2003 | 02:43 PM
  #473
DavidD's Avatar
DavidD
Default Other statistics
I will also let you know that an unofficial pole was taken and a high percentage of grounding kit users also use magnetic shoe inserts and magnetic bracelets. And, on Car Talk this morning Click and Clack stated that the human chin can diffuse IR signals. So there you have it.
Old Jul 12, 2003 | 03:00 PM
  #474
12SecZ's Avatar
12SecZ
Earth ground your car while it is parked. Use copper to a water pipe that goes into the ground,
What measurment do you get on your voltmeter now
Old Jul 12, 2003 | 08:40 PM
  #475
johnsZ's Avatar
johnsZ
Talking to DavidD
I listened to Click and Clack this morning too
They were laughing so hard they couldn't do the credits.
A buddy of mine came over for dinner- between us we have more than 70 years experience on cars. He read some of these threads and he almost busted a gut too.
But anyway, if they look cool and people believe... what harm is it, and someone makes $125US on every set sold... By the way, read the hyperwhatever website, and count the grammatical errors...
Old Jul 13, 2003 | 03:53 AM
  #476
Z'd's Avatar
Z'd
This thread isn't about Hyperground or HKS. It was started by fellow member InSaNeAmInE who builds and sells these kits for far less than the JDM option. He counts many of us as satisfied customers. My installation was 4000 miles ago and I experienced a smoother idle and the loss of the "dead spot" when first touching the gas. Hardly anyone believes they are experiencing an increase in horsepower but it does seem that the ECU operates with a "clearer head".
Interestingly enough, when I looked at my Chevy HD pickup, they already had a set of wires run to various points around the engine and the ground from the battery exited with 2- 4 ga. wires to different points. There has to be a reason why GM would go to this extra expense and it seems obvious that Nissan chose to save the $$.
Anyway, if you want to flame other grounding kit producers, please start a new thread- this one belongs to InSaNeAmInE and his current and potential customers.
Old Jul 13, 2003 | 04:38 AM
  #477
DavidD's Avatar
DavidD
Thumbs up Seriously, johnsZ.
Many are skeptics at the concept but racecars, from what I understand, have them. They are a dealer option in Japan and other countries. And prior to the installation of my kit another Z owner videoed his tachometer before and after the installation. Prior to the installation my own tachometer would vary a few hundred RPMs when the engine was cold and when the engine was warm. After the installation the tachometer barely moves when the engine is cold or when warm. I have to stare at it to even see it move at all. It varies less than 50 RPMs. This is what I can tell you. I can’t explain it but I am a believer and I don’t have magnets in my shoes or wrists. If you would like to see for yourself than get a kit from InSaNeAmine (Z-Xtreme.com) I think that he offers a money back guarantee if you are not completely satisfied and he is a great guy and is very honest.
Old Jul 13, 2003 | 06:43 AM
  #478
lowrider's Avatar
lowrider
Ditto. I was a skeptic too. My dead spot off idle is gone, the idle is also smoother, and as others have noted the tach barely moves. I don't know if it adds more power, I can't feel it, but the engine is much smoother. Glad I did it.
Lou
Old Jul 13, 2003 | 12:14 PM
  #479
12SecZ's Avatar
12SecZ
Exactly,
**No one** is going to come in 24 pages late on a 5 star thread and discredit Guy (InSaNeAmInE) after all the good dealings we have had with him and the compliments on his kit.
I love mine, I didn't buy it for HP, I bought it because I learned it was a factory option in Japan was improving idle and smoothing out acceleration (on Auto's) I researched it bought it installed it and gave it a thumbs up. Since then I have even redone my color and kit. All thanks to Guy who is in in my very short section of trusted poeple at my web page (under links.)
Don't hate congratulate or if your not from Kali "don't knock it till you have tried it."
Old Jul 13, 2003 | 05:45 PM
  #480
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Talking I love you guys!
You guys are a riot! Thanks for everything!
Hey someone sent this in today...
Attached Thumbnails Custom Engine Grounding/Earthing Kit-purplekit_on_cs.jpg
