aftermarket wideband gauge for use with oem wideband
on
ive been searching this topic all night and ive run across some conflicting information and want to try to get all this sorted out... my goal is to use an aftermarket 52mm gauge (aem, autometer wb, etc) to read the factory passenger side wbo2 output. i want to avoid welding on the factory exhaust if possible. I will be using the Cipher logs to keep track of afr and tune with, so buying another standalone, datalogging wbo2 system seems like a total waste of money. I am using this gauge as an " intelligent warning light" to let me know if i go rich or lean for some reason while spraying. my questions are...
1) poster: iyho, what is the best way to integrate an aftermarket 52mm gauge into the g35's factory wideband system? (or should this not be done?)
2) its my understanding that the zeitronix box can do this (read and display the factory signal). is this true?
3) does anyone know the type of signal does the oem wbo2 sensors output? (0-2V, 0-5V, etc)
In my research I came across this thread here:
AEM Wideband
4) If the sensor has to be heated by the controller, and the factory ecu handles this on the factory system, and the aem gauge handles this for its own independent system (all based inside the gauge), are you not connecting two heater circuits to the same sensor when connecting it like described in the thread?
AEM Wideband
'04 and up has dual widebands from the factory. I am dubious as to how you would calibrate it to an aftermarket gauge and no, you can't connect the heater circuits together (unless you like blowing up your ECM). Seems way overkill for N/A with stock cats and exhaust. If you at least had test pipes or HFC's you could put an extra bung on it.
on
bbs... do you think it would be possible to connect the oem wbo2's to the aem controller box and then the aem's serial output to the factory ecu? i thought the factory widebands had a non-standard signal (not 0-5V), so the aem output wouldnt be capable of generating the correct output to the ecu? would it just be simpler to run their all in one gauge on the passenger side bank and use that for my visual aid, and use the factory stuff along with cipher for datalogging and tuning? im starting to think thats a much simpler solution... and likely cheaper!
I'm not too sure on that, I have yet to double check, but I'd recomend leaving your factory o2 sensors in place and getting the dual channel kit and welding on 1 flange per bank to get the most accurate reading
