ls6 350z build thread!
Old Feb 24, 2012 | 08:43 AM
  #81
04.350z's Avatar
04.350z
I might want the starter I'm gonna check mine this weekend when the heads come apart
Old Feb 26, 2012 | 02:47 PM
  #82
04.350z's Avatar
04.350z
ok after a long week it is finally time for my Sunday update.
made quite a bit of progress on the tear down.
got alot of stuff cleaned up and ready for paint.
and got a ton of stuff ordered and on the way.
on to the pictures.
first off was removing this bad boy took me and another tech and a 24" snap on breaker bar to bust her nut.
then removed the harmonic balance which was equally as difficult
removed the heads to check out what was going on underneath
a tad dirty that i was hoping but not a big deal.
after i removed the heads i cleaned off the old head gasket. with a razor and a vacuum.
removed the front cover and the oil pan so i could gain access to remove the oil pump and pick up.
dont forget to line up your timing marks
remove the cam cover and cam
i did alot of cleaning this week with scotch brite and brake cleaner to get ready for paint and just to be cleaner.
i was going to paint the block but i took a wire wheel to the block and a few cans of brake clean and there was no need to paint the block
i cleaned up the water pump assembly and re painted the water pump pulley a semi gloss black
sanded and ready for paint
here are a few goodies that came in the mail this week.
GM performance spark plug wires
lokar throttle cable
GM Performance clutch assemly
also this past week I have been looking for the wiring diagrams for the ls1/ls6 harness along with the 350z harness. if anyone has acess to these i would love to have them.
all next week i should be getting in shipments of parts.
sikky mount kit headers ps line and master cylinder
ps bracket
alternator bracket
alternator pulley
texas speed torquer v3 cam kit
texas speed deluxe gasket kit
and a few others
goal for next sunday is have the heads rebuilt, cam installed,sikky installed along with the clutch assembly.
hopefully i will have the wiring diagram mapped out
and i hope i can get the t56 trans ordered sometime next week.
also my brand new matco 6s 3 bay tool box will be here tomarro woot !
ENJOY!
Old Feb 26, 2012 | 05:27 PM
  #83
bbs350z's Avatar
bbs350z
^good stuff! word of advice, when slipping on the sikky headers, have the motor raised up off the sbframe and sneak those badboys in. this way you dont need to disconnect the steering column, or unbolt the front brace.
Old Feb 26, 2012 | 05:48 PM
  #84
04.350z's Avatar
04.350z
nice good info
Old Feb 27, 2012 | 06:49 AM
  #85
Royal_T's Avatar
Royal_T
very nice, I have that same Lokar cable..
Old Feb 27, 2012 | 02:31 PM
  #86
04.350z's Avatar
04.350z
I think I am going to use the oem radiator with spal fans. What did you guys do and which fans did you go with ? Part numbers
Also I ran into a small issue I have a return system that I was using with my boosted z and the ls6 rails are returnless :/ are ls1 returnless as well or? Any suggestions?
Old Feb 27, 2012 | 06:46 PM
  #87
Quamen's Avatar
Quamen
All the LS rails I know of are returnless like the OEM Z rails.
Old Feb 28, 2012 | 04:31 AM
  #88
04.350z's Avatar
04.350z
So what am I to Do convert back to a returnless system ? What do you do about fuel pressure ? And such?
Old Feb 28, 2012 | 07:47 AM
  #89
bbs350z's Avatar
bbs350z
^id just go buy an aftermarket rail. the setup is easy. feed to the passenger side rail, crossover up front to driver side, regulator at the end of the driver rail, and return line from regulator to your tank. if you have a regulator and lines coming from you pump then the rail is a simple cost effective upgrade, and it looks good too.
Old Feb 28, 2012 | 07:56 AM
  #90
04.350z's Avatar
04.350z
I was going to buy fast fuel rails but which one are setup like this ?
Old Feb 28, 2012 | 08:39 AM
  #91
Royal_T's Avatar
Royal_T
This is my exact setup from Vengeance Racing
https://www.vengeancerd.com/ecart/products.php?product=Vengeance-Racing{47}FAST-LSXR-Billet-Fuel-Rail-Kit-%252d-Complete#
Old Feb 28, 2012 | 10:11 AM
  #92
Cass007's Avatar
Cass007
https://my350z.com/forum/9547474-post469.html
Ask and you shall receive... if you use the stock rails just plumb the regulator like you see in my pics here. Feed in on the left (facing the car), out to rails on the right, and return out the bottom
I'm still running dual walbros right now so I doubt pressure is an issue with this setup.
Old Feb 28, 2012 | 10:22 AM
  #93
04.350z's Avatar
04.350z
Can't see the set up in those pics :/
Old Feb 29, 2012 | 03:11 AM
  #94
Cass007's Avatar
Cass007
The regulator is on the firewall.
Old Feb 29, 2012 | 05:33 AM
  #95
04.350z's Avatar
04.350z
I can see that but everything else. I figured it out thanks for all the help!
Last night no parts came in which was sad.
But I laid out the harnesses and stared at them for two hours thinking.
I found allege wiring diagrams I need for the ls but I am still at a loss to find the wiring diagrams for the z engine harness and the body control module. Can anyone help?
Old Mar 4, 2012 | 02:40 PM
  #96
04.350z's Avatar
04.350z
so today is sunday and is update day.
ill be honest i didnt get anythign done this week been sick and busier than i have been in a long time.
and every tech at toyota came over and got drunk in the garage.
but this week this is what came in
texas speed cam kit with torquer v3 cam, dual valve springs, stem seals and titanium retainers.
texas speed deluxe gasket kit.
alper motor sports alternator bracket and power steering bracket.
still waiting for the sikky kit to be delivered.
heres the small update on what i got done
dual valve springs installed
all 16 in and man were they a Son of a B+@$% to install
I install the cam and cam gear and put her in time so the rocker arms can be installed along with the push rods.
but on a lighter note this cam into work last week as well.
matco 6's three bay with hutch and stainless steel top. out with the old and in with the new!!!
this week i plan to get the motor rebuilt and ready to be installed for when the sikky kit comes in.
Parts that will be ordered tonight or possibly in the AM:
vengeance fast fuel rail kit
harmonic balancer
krc power steering pulley
SPAL ultra thin fans
idle air control valve
throttle position sensor
idler pulley
spark plugs
also i put some thought into my intake, exhaust and coolant hoses.
and speed source inc in mahomet il will be making most of my stuff.
Carl makes amazing welds and his work never dissapoints.
enjoy
Old Mar 4, 2012 | 05:39 PM
  #97
bbs350z's Avatar
bbs350z
^solid setup! and damn that box is a beast!!
Old Mar 13, 2012 | 06:37 PM
  #98
04.350z's Avatar
04.350z
ok guys finally i had time to getting around to updating this thread.
work has been hectic the past week
but here we go
left and right heads bolted down with ARP head bolts
intake manifold mounted up
throttle body with new IAC and TPS
thats about all the physical progress on the engine side of the build
we tracked down all the wires on the ls6 harness and have them labeled.
next we will do the same to the z harness and salvage as much as possible.
this harness needs to not only look oem but be oem spec.
Parts that came in this week.
drive belt
asp balancer
ARP crank bolt
lokar throttle cable bracket
had some issues with mounting this because the ls6 intake manifold is not tapped for a throttle cable considering the drive by wire setup.
i got a couple ideas to make it work but havent 100% figured out how i want to do it
parts on order
sikky products ... still waiting
fast fuel rail kit
ENJOY
Old Mar 13, 2012 | 06:43 PM
  #99
graffkid732's Avatar
graffkid732
Looking good.
Old Mar 13, 2012 | 06:58 PM
  #100
Rambo's Avatar
Rambo
Slow Down!!! you are making my build look like a gradma build. Looks good!!!
